Originally Posted by
Smac770
I don't know anything about valve stem seals. If you remove the PCV from the cylinder head cover and remove the tube to the intake manifold and throw smoke into that intake manifold opening or into the front 02 sensor opening, one should not see any smoke out of the PCV opening, right? Or are the stem seals a dynamic thing that are loose cold and sealed hot?
Thanks all for your replies.
I’ll have to get this checked out professionally very soon by a mechanic. Ive been though a bit of a bump road with this car in the past year.
So I take it that it could also be faulty PCV valve can cause excessive burning of oil?
Here are the symptoms I’m experiencing:
• Only white smoke (definitely not coolant)
• Only happens if I let it idle for 1.5 – 2 minutes in (N)eutral or (P)ark. (never happens whilst driving or idling in (D)rive
• Very occasionally it may occur upon a cold start up
But in saying that, it doesn’t produce smoke in on downhill deceleration which is normally present with bad valve seal.
I don’t think it’s a Cylinder head, piston ring or head gasket as those normally cause oil consistently.
The Turbo/K04 that’s equipped is around 12,000 Miles, so I don’t think it’s a turbo hot seal. But - I did have a bad blockage in the exhaust, which could’ve potentially damaged the turbo or valve seal)
The PCV I have is also around 12,000mi , replaced at the same time with the turbo.
But – the ECS tuning catch can I installed earlier in June 2020, this symptom seems to have happened since then. Which their catch can works with the PCV valve (not removing PCV as opposed to other designs). I’m also wondering if the vacuum on this design has degraded the PCV, Stem seals or even being the sole cause of pressure coming back pass.
https://www.ecstuning.com/b-ecs-part...004136ecs01kt/
Perhaps the first step would be to reverse the catch can and see if that improves the issue. But I may have lost the two bolts for turbo vent and the ECS bolt is longer.
or ill just have to pass it to the workshop and get them to do a leak down test etc
