Results 1 to 16 of 16
    Veteran Member Three Rings tate182's Avatar
    Nov 06 2016
    Minnesota
    Coolant/oil leak around oil filter housing
    I read that it is a common problem for the housing to leak but I am wondering if it would usually cause an oil and coolant leak at the same time. The car is leaking more coolant then oil also there’s no coolant in the oil as far as I can tell.
    2001 b5 s4 stock
    Feb 15 2016
    Cambridge,Ontario
    i thought i had this issue too .. but what actually happened was i had a OFH leak for a while.. and like most ignored it .. then the water pump started leaking , ran down the front of th eoil pan and was mixing with the oil that was leaking out of the OFH ..
    so i pulled the front end and did the OFH water pump , belt and tensioner.... done and dusted , zero leaks.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Account Terminated Four Rings
    Oct 15 2013
    You may have a coolant leak at the rear flanged fitting. Common problem. The oil filter housing is also known to leak at around the same time. I had both leaks around the same time.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    The oil cooler is right at the oil filter housing. If you’re leaking coolant and oil, replace the filter housing with a genuine Audi housing. Don’t use aftermarket. The new housing might come with a new oil cooler gasket, I forget, and you’ll fix both problems at the same time. Or just buy a new oil cooler gasket if it’s not included with the oil filter housing.
    Don’t just replace the gaskets or you’ll be leaking again real soon.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Feb 11 2018
    Unionville, CT
    Agree 100% with this ^^ ....just spend the extra $$ and get the OEM housing.
    2015 Q7 Ice Silver Metallic
    2007 A4 2.0T Cabrio Dolphin Gray
    2006 A4 2.0T Sedan Dolphin Gray
    May 20 2017
    New Hampshire
    Quote Originally Posted by esandes View Post
    They’re on 2 different sides of the motor. What would the coolant flange have to do with the oil filter housing and oil cooler? 🤣
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Quote Originally Posted by Plxa4q7 View Post
    X2 had first hand experience with this. The old housing warps because it's goddamn plastic so the seals won't sit right and cause it to leak again.
    I really wish there was a company out there that makes a metal design... Only reason I assume it hasn't been done yet is because of heat soak but I'm no engineer.
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    Quote Originally Posted by EvolutionArmory View Post
    I had a coolant leak at the oil filter housing that was from the coolant flange....path is all hidden. I originally thought it was water pump......popped off the cover and it was dry. Then replaced the oil filter housing ...it was due.....still had a leak finally stuck my fingers under the flange and found it wet. Changed it and resolved my issue.
    I didn't think it was the flange because the last time the flange was leaking to went straight down onto the tranny and since there wasn't anything there I started elsewhere.
    It's one of those items.....wouldn't hurt to feel around the flange and see if its dry.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by mcpcartier View Post
    ie do an old fashioned reach around ?
    1976 Yamaha XS 360
    May 20 2017
    New Hampshire
    I had a coolant leak at the oil filter housing that was from the coolant flange.....
    Read this out loud and tell me in what world that makes sense.
    You didn’t have a coolant leak at the oil filter housing/oil cooler if it’s coming from somewhere else🤣🤣😀
    Oct 15 2013
    Quote Originally Posted by Cyrik View Post
    No heat soak issue as there's an oil cooler/radiator. I think there's a huge aftermarket potential for metal parts on audi and bmw.
    Oct 14 2011
    Ha.....you'd never know English is my first language....
    Guess I should have stated........I had leaking coolant at my oil filter housing that came from my coolant flange..... or something to that effect.
    Feb 15 2016
    Cambridge,Ontario
    Guess I should have stated........I had coolant visible on my oil filter housing that actually came from my coolant flange.....
    1976 Yamaha XS 360
    Oct 14 2011
    That works......not too particular about the phrase, whatever helps get the message across.
    Feb 15 2016
    Cambridge,Ontario
    its just funny .. but yeah ur right ..
    1976 Yamaha XS 360
    Oct 14 2011
    yep....for some reason, not matter how I say it......it sounds wrong when I look back.
    I tried....I'm done trying with this one.
