Results 1 to 19 of 19
    Junior Member Two Rings
    Nov 17 2019
    2015 Porsche Boxster GTS
    Question Timing Chain Service Help for 2014 B8.5 6MT
    Hey ya'll
    After a spirited drive last week my car started making knocking sounds at idle. Here's a video if you're curious:
    https://photos.app.goo.gl/X6uemhA4DWzYXNh46
    Mechanic diagnosed a faulty chain tensioner guide, as the ticking/knocking sound followed engine RPM and was coming from behind the driver's side cylinder bank. We put in some very viscous oil to boost oil pressure but the noise persisted. Crazy my car is at 53k miles and this is happening.
    Wanting to know:
    1. What is an estimated total cost and hours for this entire service? (looking for separate hours for engine out & hours for timing chain service)
    2. For those that have done this...what is your recommended service product that you went with? OEM or aftermarket? Is there a TSB?
    3. Is anyone interested in buying a 2014 6MT 53k miles, sport diff, black optics (rotors), magma interior, IE stage 1? hahaha . . . ahhh . . . *cries*
    Jul 31 2016
    PA
    That does not sound great, although curious as to where the oil came from on top of your coolant reservoir? You sure that's not just a bad exhaust leak or anything?
    Otherwise my guess would be north of 5k for parts and labor minimum. Probably more than that.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    I thought i read that Audi charge $4 to $5k for the repairs, so an indy shop would be less. Work can be done with the engine in the car, so no need to remove.
    Not researched enough to offer up any help with DIY. Good luck
    Sent from my SM-G970U using Tapatalk
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Indy shops in and around NYC charge dealer prices. I see absolutely no benefit in using them. Dealer gives a 12 month warranty on parts and will put you in a loaner for the duration of the work.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Established Member Two Rings onelowboi's Avatar
    May 31 2019
    bay area
    it’s an engine out job so minimum 13ish hours of labor in an out iirc. if you go indie or dealer i would use whatever they recommend you and to NOT bring your own parts. the reasoning is that if your part is faulty or didn’t fix the problem, they will most likely charge you more to fix it again since it was not their fault, at least that’s how the people i know run their shops. but as for the 3rd question, i am :)
    Established Member Two Rings sbw's Avatar
    Aug 26 2008
    2013 S4 White - 2012 Grand Cherokee Grey
    Quote Originally Posted by DarrenOman View Post
    The problem is a lot of dealers don’t approach this as an engine out job, which is what needs to be done to address all the components. I’ve been following the thread on AZ specifically on this and people have said the dealers were doing just the upper components to minimize labor and not have to pull the engine.
    I had mine done by an independent shop along with a clutch and flywheel job so it didn’t burn so bad. It was around 5k for all the parts and labor but I also had some labor mixed in that was not part of the timing chain job. I will say though, the noise never came back and the components seemed worn after looking at them once they were removed.
    Jan 04 2017
    El Monte/CA/United States
    I replaced my own tensioner with a INA brand ran me 130 for driver side.
    When I took the cover off I noticed the upper guide was broken my guess was that it was causing the noise I didn’t really notice a difference in pressure between old and new tensioner.
    After tensioner and guide was replaced never heard any sort of chain noise! I love starting up my car now lol.
    It took me about 8 hours it could of been done faster if I had all the tools vs working with what I have.
    Nov 17 2019
    Quote Originally Posted by djn876 View Post
    Good eye on noticing the oil. I don't know if it's associated with the timing chain issues I have, but I have small, random oil droplets spread out through the right side of the engine bay, on the same cylinder bank with the timing issues. Almost positive it's not an exhaust leak though after taking it into the shop.
    $4-5k seems to match up with what I've been quoted thus far.
    Nov 17 2019
    Quote Originally Posted by blackfunk View Post
    I agree, and I'm seeing the costs be about equivalent. Dealership will warranty service and will be about the same cost. Potentially less because they have done this service before and would take less hours to do it.
    Nov 17 2019
    Quote Originally Posted by onelowboi View Post
    Yeah, for sure. I want the job warrantied because I cannot imagine having to deal with this problem again within the next year if parts break. I will be getting this fixed prior to selling it (unless you're interested in taking the car on a trailer for around $20k haha). Might end up selling it this spring after I buy a Miata RF, keep an eye out for it on the Facebook B8/B8.5 ownership page!
    Established Member Two Rings tylerhays's Avatar
    Aug 06 2019
    Pensacola, FL
    I have an B8.5 S5 - similar issues. My timing chain jumped time by 2 teeth causing misfire on all of bank two. Luckily, no internal engine damage. Had to get timing chains and guides replaced - they did replace both banks chains and tensioners since they were in there. The motor does not need to come out, but the transmission, drive shaft and entire exhaust system does.
    All in all, $5800 out the door. Definitely a tough pill to swallow as I still have less than 55k miles. The luck of the draw, I suppose. If you would like, I could PM you my invoice for the job.
    Best of luck, my friend! I completely understand your pain and empathize with you!
    May 31 2019
    bay area
    Quote Originally Posted by tylerhays View Post
    how did they do the replacement without removing the motor? that's some god tier stuff right there. it looks like there's no space to do it!
    Aug 06 2019
    Pensacola, FL
    Once the transmission, downpipes and cats are removed, there is actually a lot of room. They had it up on a lift and even took me under the car to show me everything that was going on. Here is a shot from under the car with timing covers off and engine still in the vehicle.
    May 31 2019
    bay area
    [QUOTE=tylerhays;14337254]Once the transmission, downpipes and cats are removed, there is actually a lot of room. They had it up on a lift and even took me under the car to show me everything that was going on. Here is a shot from under the car with timing covers off and engine still in the vehicle.
    that’s quite amazing, thanks for sharing! most definitely cuts costs down from an engine out perspective
    Aug 06 2019
    Pensacola, FL
    [QUOTE=onelowboi;14337530]
    Absolutely! If my misfortune can help benefit others, it soothe the sting just a bit.
    Engine out would have definitely driven up the cost. The master tech (Indy shop) that worked on mine said that Audi actually recommends doing it this way. Although it does make me curious, because if the engine came out, trans would still have to be disconnected along with the exhaust system. I suppose it’s just easier to remove cats, tranny and drive train, as opposed to removing the entire engine and all attached components.
    Nov 17 2019
    Yeah, it's crazy to me to need this done at such low miles. Mechanic will be doing diagnostics tomorrow to confirm the problem before putting it under the knife. How hard did you drive your car before this issue? Is it tuned?
    I've read conflicting information on removing the engine or not for this. Is yours a DSG? I've heard the 6MTs don't have enough clearance to do the job without removing the engine.
    May 31 2019
    bay area
    Quote Originally Posted by Pugnacious View Post
    Checked, tyler is DSG
    Aug 06 2019
    Pensacola, FL
    I didn’t drive hard at all, to be honest. Some lightly spirited driving here and there, but no track days or excessive launches, etc.
    Ah, could very well be the case regarding work room with MT. I am DSG.
    Junior Member Two Rings scattamacroffit's Avatar
    Dec 23 2018
    carver, mass
    My 2013 with 60k is currently in for this same issue at indie shop. Also after a rare spirited drive. Was just going to do the upper tensioner, but there was a broken guide which he could not find without going to the lower cover. Engine is currently out and all chains and guides being replaced.
    I was told there was a TSB from Audi and a better replacement part was produced. $5k plus.20201021_153952.jpg
    Sent from my SM-G965U using Audizine Forum mobile app
