UPDATE (03-11-2020):
I replace both the fuel pump and fuel pump control module, but I get the same code with one difference
Before:
6170 - Signal Line for Fuel Pump Electronics
P3089 00 [173] - Electrical Malfunction
After:
P3089 00 [165] - Electrical Malfunction
UPDATE 2 (03-11-2020):
I feel like an idiot. Fuse was ok, so I didn't bother to check if the module or pump had power... They didn't....
I checked in detail the electrical schematics and got power up to the fuse at least but not into the fuel pump control module, so the problem is at some point between the fuse and fuel pump control module wiring.... I'll continue my search tomorrow...
At least I got a new fuel pump
2011 Audi S5 (B8) Sportback (3.0T)
I got the following fault code:
According to what i could find, i need to replace either the fuel pump or the fuel pump control module. Since i had to import replacement parts, I took the safe option and bought both fuel pump G6 and fuel pump control module J538. Parts haven't arrived yet, but I tried to remove the fuel pump and control module in the meantime following the workshop manual. No problems removing the fuel pump, but I can't take out the control module, it doesn't fit through the gap.
The only thing I can think of, is to remove the white threaded ring (just don't know how)... According to the manual, this shouldn't be necessary, but I don't see other way around it. On reddit someone recommended me to lower the fuel tank, but I think that is a bit out of my league right now.
Should I try to remove the ring? If so, how? If I break it, the only replacement i could find was from china and i'll have to wait a few months for it to arrive, so want to avoid removing the ring if possible. The procedure should be the same as of Audi A4/A5 from the same generation.
Thanks !
