    Senior Member Two Rings phunkfarm's Avatar
    Oct 02 2008
    Oakland
    Can someone please definitively tell me the center cap size of the 21" blades?
    I just ordered a set without caps or sensors and they will be here next week. Wanted to order my caps but the seller said the size is either 60 or 69mm, he wasn't sure...Anyone know definitively?
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by phunkfarm View Post
    Are the wheels OE blades? If so, the part # is 8T0 601 170 A AX1 (this is the gloss black) I do know there are 2 different sizes, 69mm 77mm is for the Q7/Q8
    The 60mm will not fit if your wheel is an OE blade. 60mm is old school Audi.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Oct 02 2008
    Oakland
    yes they are RS7 oem rims, coated black.
    Junior Member Two Rings
    Dec 21 2018
    Louisiana
    If in doubt, always go with the 69.
    Senior Member Three Rings wangao0316's Avatar
    Apr 03 2019
    2014 S7, 2017 Q7
    Las Vegas, NV
    69mm center caps work on 66.56mm center bore size wheels
    2014 S7 Prestige - | DS1 ECU Custom Stage 3 | BE TCU | RS7 Turbos | RS7 inlets + airbox | SRM E85 Sensor & LP Lines | RM Motors DPs | FL Taillights | RS Grille | OEM Key Fob Remote Start | Custom Carbon Fiber Steering Wheel | Uniden R7 | VCDS Mods | More to come ..
    0-60mph: 3.05s , 1/4 mile: 10.89s @ 128.37, DA~6000ft, full weight.
    2017 Q7 Premium Plus - Stock for now, Family Car
    2015 S3 - APR Stage 2 (Gone)
    2015 A3 - APR Stage 1 (Gone)
