Results 1 to 7 of 7
    Junior Member Two Rings
    Nov 16 2019
    Lithuania
    Flywheel dual or single mass?
    Hello everybody,
    Has anyone replaced their DMF to SMF on 2.4/2.8 FWD engine? What it's like, is it even worth doing so? Recently my audi started shake/vibrate under acceleration. And always had this clunk and delay when letting the throttle go and back on. It's very noticable on stop-go traffic in 1st and 2nd gears. I checked all the mounts and driveshafts and everything is ok. Or should i just buy used or new DMF? The new flywheel costs a lot, over 400 euros. And didn't have any luck finding used one yet.
    Sent from my STF-L09 using Tapatalk
    Veteran Member Four Rings idotavant's Avatar
    Jan 20 2016
    wv
    Single mass if you ask me, but I’ve never had the dual mass, as it failed before I owned the car—if that tells you anything
    05 Allroad 4.2 ao3 swap; jhm v3 kit
    06 Dakota 4x4 long travel v8 6spd
    03 Tuono 1000
    04 MB c240 4motion wagon (gf’s)
    02 a4 avant 3.0 tip (defunct; part-out or sale)
    Nov 16 2019
    Lithuania
    Quote Originally Posted by idotavant View Post
    So you had the same C5 with 2.4? And it already had single mass flywheel? How was the gear changes, any out of the ordinary things? Like vibrations etc.
    Jan 20 2016
    wv
    Quote Originally Posted by Radvis View Post
    Yeah my car is a one-off 4.2 allroad with a manual swap from an s4). It now has a single mass lightweight aluminum flywheel and r-type jhm clutch
    It is a tad chattery when hot, and shudders some when cold
    Light weight flywheel makes it easy to stall
    The dual mass you had is for driveability and smoothness. If you were to get a single mass steel and standard clutch, it would be heavier and more user friendly than my set up, but not as buttery smooth as the dual mass. Its more robust than the dual mass too. That’s my understanding
    I may be wrong but the oe dual mass fails more on the high powered cars that get some abuse (s4).
    Given the cost of the dual mass, I would skip it, but it would probably be fine for 100k miles on a N/A v6 if you are good to it
    03 Tuono 1000
    Nov 16 2019
    Lithuania
    Thanks for your reply! I guess i will look into single mass flywheel conversion kit. As it's quite cheaper.
    Jan 20 2016
    wv
    Any time, pal
    Let me repeat that I don’t have first hand experience driving the oe clutch or flywheel. All this info is dubious second hand knowledge
    03 Tuono 1000
    Sep 16 2010
    Central Wash
    I'd just add that to be safest find a single mass flywheel that is ONE PIECE- Billet. And close to same weight as stock for best driving. Those lightweight units with the separate ring gear and friction surfaces aren't known for being really forgiving and driveable. Odds are they work well usually, but they can fail in ways that a billet FW can't, and if you trim weight you it can be harder to drive and have chatter.
