Results 1 to 9 of 9
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    S3 rear brake piston tool
    Anyone knows if a "special" brake piston tool is needed to compress the rear piston back into the caliper after the parking brake is put into service mode using either VCDS or OBD11? If so, do you have any recommendation? What service manual are you using for the 8V S3? Thanks.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Senior Member Two Rings sj9ninety's Avatar
    Nov 03 2018
    2022 M240i
    Northern Virginia
    Yes, Amazon has a full set for around $30 or you can rent from Auto parts store.
    https://www.amazon.com/dp/B01FW3U26G...ing=UTF8&psc=1
    ShopDap DIY on YouTube.
    Don’t close the electronic parking brake with caliper off the rotor.
    Nov 02 2017
    CA
    Quote Originally Posted by sj9ninety View Post
    Thanks. I saw conflicting info regarding needing that specialty tool. Some say and showed that even though there are slots for the tool and looks like a tool is required, they were able to compress the piston without having to turn it in the process. I guessed it's just safer to buy or rent the tool since it isn't that expensive.
    Senior Member Two Rings normcaldwell's Avatar
    Jul 31 2016
    Quote Originally Posted by XMetal View Post
    I change my own brake pads.
    You do not need to rotate the rear brake piston, just compress it straight back in using a piston spreader tool like you would use on the front caliper.
    a. Parking brake off.
    b. OBDEleven: Brakes > Basic Settings > Start Lining Change Mode. Press and hold green check mark at bottom of screen. Listen for the EBC motor to run and retract the piston stops.
    c. Remove retaining spring, guide bolts, caliper and pads, compress piston straight back.
    d. Install new pads, caliper, guide bolts, retaining spring.
    e. OBDEleven: Brakes > Basic Settings > End Lining Change Mode. Press and hold green check mark at bottom of screen. Listen for the EBC motor to run and re-engage the piston stops.
    2016 Audi S3, Misano Red Pearl Effect, Prestige, Black Optic, S Sport Seats.
    United Motorsport, 034 Motorsport, Neuspeed, StopTech, APR, AWE, ECS, IE, Ferodo, Motul, BC Forged, SuperPro, CFS, Carbontastic.
    Apr 03 2020
    FL
    You just need to compress the piston after you retract the EPB. You can use C clamp or whatever other tools you have for it. The brake service kit from Amazon should also work as long as you use flat attachment that does not rotate the piston.
    This method is described in official Audi 8v service manual for a3/s3 which I can confirm working from experience and the only method I’d recommend after taking rear caliper apart and inspecting the piston mechanism.
    Nov 02 2017
    CA
    Quote Originally Posted by normcaldwell View Post
    Quote Originally Posted by Sv2k View Post
    Thank you both for the confirmation for not needing that special tool! I'll see if I'm lucky enough not having to take off the carrier in order to remove the disc => https://www.youtube.com/watch?v=j7ziAOmuc8E&t=342s
    Apr 03 2020
    FL
    Yes, avoid taking those off if you can help it. Huge pain.
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    On the S3 there is no need to remove the rear carriers due to the shape of the rear rotors - the hub portion is concave vs straight however on the A3 you have no choice but to remove the carrier.
    Nov 02 2017
    CA
    Quote Originally Posted by bakedcorn View Post
    Awesome - thanks for the clarification!
