    Jun 17 2018
    Eagan, MN
    Tune Cables vs VCDS Cable?
    Can someone clear up a question on cable connections needed for ECU tuning from the the various companies that allow flash at home(EPL, 034, etc)? Can the VCDS cable be used or is each company have a proprietary cable which must be purchased through them?
    Established Member Two Rings Aries_27's Avatar
    Sep 28 2016
    Michigan
    Quote Originally Posted by Daavikes View Post
    Each company has their own that you would have to purchase from whichever one you decide to go with
    IG: sq5_igor
    2016 SQ5 P+ Florrett Silver w/ Black Optics
    Current Mods
    - APR Carbon Open Intake-034 Silicone Intake Hose-Vast Performance Custom Stg 1 Tune-KW Street Comforts-Powerflex Front Bushing Upgrade Kit-Uniden R7/Blendmount/Mirror tapped-NemesisAutosport 15/20 Spacers
    Coming very soon -JHM 187mm Pulley-Vast Performance Custom Stg 2 Tune-034 X-Brace-034 Rear Sway Bar
    Jul 31 2016
    PA
    The protocols (how it's going to communicate with the car) for a VCDS cable are different than the flashing cables (more than likely). Depending on the company, the flashing cables may just be rebranded versions of the same thing, but couldn't tell you which ones. I'm up to 3 now, one for TCU, one for ECU and one for VCDS.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Jun 17 2018
    Eagan, MN
    Thanks! Had some misinformation that I could use my VCDS cable and save some money.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    For what it is worth, EPL has multiple cable options. For instance, I had a J2534 bi-directional OBD-II cable used with a different diagnostic and tuning software program. It is often called "Mongoose" or "MiniVCI" and is used by many different kinds of diagnostic equipment. It is an EPL option, so I didn't need to buy or rent a cable. New ones are less than $50.
    But, RossTech VCDS will not work with any flash at home tunes to my knowledge.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
