Originally Posted by
AnthraciteA4
Ive had bad luck dealing with Alibaba by itself. I like the protections eBay provides and the $200 worth of eBay store credit doesn't hurt. I was more wondering if the housing was an improvement over the F23L. I'll need a turbo muffler either way. I was planning to do the same as you and get everything ported, polished and coated. Depending on your success with the forge waste gate, I'll probably go that route too. It'll be a while before I install a new turbo regardless of what it is.
I didn't mean to change the subject though. Sorry.
Sent from my Pixel 3 XL using Tapatalk
Hard to say it’s better without using it as is for a direct comparison to the eBay turbos. This thing comes with a 9 blade turbine that’s a bit wonky and 8/0 billet compressor wheel That has beautiful machining so probably not an apples to apples comparison.
PnP will definitely change the outcome as well as the cartridge I am running and the fact I’m custom tuned.
The f23l / k04-106 are more widely available and known to work out of the box on off the shelf k04 software.
TBO is unproven in that regards.
With all that said there are some advantages to the TBO housing. Because the muffler delete is removable it allowed a lot more thorough port job and a lot of material was shaved from that outlet
The seller is quick to ship on Ali and is a trade assurance backed seller
I actually applied for a full refund tho because it’s basically a non functional turbo out of the box
Packaging and fitment on everything else has been quality tho. It’s almost nicer than my real Borg Warner turbo 😂 since it came without a crack and the inner diameter on the muffler delete is 0.1” larger than loba before the porting
