The front rings were surprisingly (to me, at least) the most difficult part of swapping out all the chrome badges/rings to black ones.
The clips that hold the front rings in place are no joke. It's extremely difficult to get even a thin credit card or plastic pry tool behind the rings to pry them away from the grill without damaging the grill area surrounding the rings.
After a few failed attempts with different pry methods/tools, I ended up taking a slightly different approach. I dremeled a small hole into one of the rings, just big enough to fit a narrow metal pry tool. That gave me the proper leverage to pull the rings away from the grill enough to then use a plastic pry tool to work my way around the back side of the rings, popping one clip out at a time. Once you get 1-2 clips free, it gets significantly easier.
It allowed me to remove the rings without breaking a single clip and without damaging/marking up the grill area surrounding the rings. The rings are obviously toast from the hole I dremeled. But those were going straight to the trash, anyway.
I hope this helps. GL!
