Page 1 of 6 123 ... LastLast
Results 1 to 40 of 201
    Senior Member Two Rings brandonbanana's Avatar
    Jul 14 2018
    2010 Lexus IS 250, 2023 Audi Q8, 2016 Audi S7
    Oahu, Hawaii
    Coolant temperature too high
    Has anybody experienced their coolant temperature getting too high? Had service flush out coolant and all. Still getting "Coolant temperature too high. Let engine run while vehicle is stationary." message on my instrument cluster.
    Established Member Two Rings Makes Centz's Avatar
    Nov 08 2018
    Goodyear Arizona
    Something i would do is leave it at the dealership and not take it back until fixed. If not under warranty, id look into changing the temperature sensor, if everything else checks out as good like the fan is running when its supposed to, the thermostat is opening etc.
    IG: @MAKES_CENTZ
    Veteran Member Four Rings z_wrecker's Avatar
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    How many miles on the car? Any modifications? Recent coolant service was done at the dealer? OEM coolant?
    2018 Alfa Romeo Giulia Quadrifoglio
    2014 Arctic White B.O. S5 Prestige manual w/ sports diff
    2002 Arctic Silver Metallic Boxster manual
    2018 Daytona Gray Q5
    2018 Daytona Gray B.O. S4 -Sold
    2009 Pearl White Ducati Monster 696 with Termi race kit, and a bunch of CF -Sold
    2008 Ibis White A4 s-line manual -Sold
    Jul 14 2018
    Oahu, Hawaii
    I have about 44k miles. I have JB4, FMIC, CTS Test Pipes, Custom Exhaust, and Cold Air Intake. Coolant was flushed yesterday at dealer. I was told that it might be faulty thermostat
    - - - Updated - - -
    Quote Originally Posted by Makes Centz View Post
    For sure man. Tryna replace what i can before warranty ends :(
    Senior Member Four Rings
    Apr 26 2019
    United Kingdom
    Sounds like the thermostat / water pump has gone. Very, very, very common on these cars.
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    Keep us updated and hopefully it is fixed very soon!
    Jul 26 2018
    Arizona
    Just had the same issue last week. Ugh. Seems to be trend the last two weeks with these cars.
    I got coolant warning and when I popped the hood the coolant had slashed all over the engine bay with nothing left in the tank.
    Towed it to the dealer and they said the thermostat was stuck therefore engine overheated and coolant overflowed from the cap! No areas of leaks from the coolant pipes.
    I feel like performance has decreased since that event but dealer said they aren’t going to do any more testing to check. At one paint he mentioned temps went up to 300F...
    Saw another guy on Audi world with a RS5 with the same issue last week.
    - - - Updated - - -
    I have 46k miles on the car btw.
    Jul 14 2018
    Oahu, Hawaii
    Quote Originally Posted by S5man24 View Post
    - - - Updated - - -
    We're on the same boat brotha!! I hope our cars get fixed. I will keep everybody updated! So far, thermostat has been changed. Still overheating.
    Jul 14 2018
    Oahu, Hawaii
    *UPDATE* Thermostat has been replaced. Car got a software update. Temperature reading high but the actual temps are not high at all. Something to do witht the ECU thinking that the car is overheating but it isn't.
    Jul 14 2018
    Oahu, Hawaii
    Quote Originally Posted by z_wrecker View Post
    Thanks bro!!
    Jul 14 2018
    Oahu, Hawaii
    UPDATE: Techs are ordering a new water pump. Part is on back order and will come in in about 7-10 days. Till then, I won't be able to see my car
    Jul 26 2018
    Arizona
    Dang man. That sucks. They only replaced my thermostat. I feel like the car is a little sluggish now but no way of determining if it is. ....
    Junior Member One Ring
    Dec 08 2019
    Florida Panhandle
    Quote Originally Posted by brandonbanana View Post
    I just went through this exact situation about a month ago. There's actually a TSB on it. They changed the water pump, thermostat, and re-flashed my ecu (and erasing my APR tune in the process). Said it was good, drove 5 miles down the road and overheated again. Long story short, it ended up being the coolant control solenoid.
    Hope this helps, good luck getting your car back on the road.
    Junior Member Two Rings
    Jul 31 2014
    Tennessee
    So, is anyone going to mention any actual temperatures?
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by sykokilla View Post
    It will just read an incorrect temperature. Essentially, if the coolant isn't at the 90-100c mark (if in remembering correctly) then there's probably something wrong.
    Feb 26 2011
    2016 B8 Allroad / 2017 SQ5
    I was just reading this thread yesterday night. And today I turn on my car (2018 B9 S4 with 14.5k miles) and got a coolant error on the screen and said to turn off the car. I went in my wife's Q5 instead. Got back and attempted to turn my S4 on again and got no coolant error this time.. wondering if these are signs of the coolant issue you all are having... I have the 034 intake, CTS turbo inlet, ECS intercooler w/charge pipes and Detuk piggyback.. I will take a picture of the error next time.
    Dec 08 2019
    Florida Panhandle
    Quote Originally Posted by metalslug View Post
    I was just reading this thread yesterday night. And today I turn on my car (2018 B9 S4 with 14.5k miles) and got a coolant error on the screen and said to turn off the car. I went in my wife's Q5 instead. Got back and attempted to turn my S4 on again and got no coolant error this time.. wondering if these are signs of the coolant issue you all are having... I have 034 intake, CTS turbo inlet, ECS intercooler w/charge pipes and Detuk piggyback.. I will a picture of the error next time.
    For me, it started with a low coolant warning. I checked the coolant and it was good. Cleared the code and the it came back 3 days later with a low coolant error again and an overheating error.
    Jul 14 2018
    Oahu, Hawaii
    Quote Originally Posted by Beagz_b9_s4 View Post
    Thanks bro. Just replaced the thermo and the water pump. Still having overheat issues. I will ask about the coolant control solenoid. I appreciate the help!
    Jul 14 2018
    Oahu, Hawaii
    Temps were hitting 114-117 celsius
    Nov 08 2018
    Goodyear Arizona
    water temp or oil temp?
    When i beat the shit out of mine the OIL temp goes to 235f-237f. The oil bypass to the cooler doesnt open until it hits like 250ish.......are you guys actually overheating or just reading high temps sporadically?
    Is the coolant actually boiling off or overflowing?
    I was concerned with temps until i read the manual and saw how hot the engine actually is designed to run oil temp wise. Normal oil temp is 176f to 248f.
    IG: @MAKES_CENTZ
    Dec 08 2019
    Florida Panhandle
    Yes, I know these engines run really hot. However, my water temps were getting up 240F. The overheating warning flashed up and the dummy gage showed hot too. I didn't want to see if it got any hotter, so I shut her down and had the car towed to Audi. Not my problem, it's under warranty. My particular situation ended up being the coolant control solenoid, which regulates vacuum going to the water pump and controls a sleeve around the impeller. The solenoid was stuck in the open position which continuously pulled vacuum on the water pump causing the sleeve to stay closed and not allow coolant to circulate into the radiator. Audi techs changed the water pump and thermostat thinking that was the problem. After the techs contacted the engineers, they realized the coolant control solenoid was bad. Hope this cleared it all up.
    Jan 03 2009
    Iowa
    Do you have a part number on the solenoid valve?
    Veteran Member Four Rings oc cc's Avatar
    Oct 14 2011
    OC
    Please keep us posted - every week I decide to bite the bullet on a tune, I see a thread like this that scares me.
    Current: 2019 S5 Sportback Quantum Gray
    Previous: 2012 A4 Avant Glacier White
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by oc cc View Post
    This is a stock failure, tune won't make any difference.
    Oct 14 2011
    OC
    Quote Originally Posted by Kondax View Post
    No I get that, and he did say it happened after the 50k like warranty anyways. I just would hate to get the time at like 6k miles then at 40k have a similar failure but denied warranty over it.
    Apr 26 2019
    United Kingdom
    That's very true.
    Jul 14 2018
    Oahu, Hawaii
    UPDATE: Techs replaced the coolant control solenoid. Car is back up and running. Water pumps opened up and the vehicle is operating at normal operating temperature! Thanks to @Beagz_b9_s4! Thanks bro!
    Dec 08 2019
    Florida Panhandle
    No problem! Glad I could help out!
    Jun 26 2021
    Romania
    I have the same problem with coolant temperature , but one day the car is running hot and next day all is fine , that happnes over 3 weeks , I changed the thermostat yesterday ,car is running normal and today same message coolant temperature high
    Jun 26 2021
    Romania
    Do you have any part number for that coolant control selenoid ???
    - - - Updated - - -
    Jan 03 2009
    Iowa
    It is actually called the switching valve. Pull off the vacuum (purple) line and plug that line. Leave the switching valve disconnected. See if your problem goes away.
    Nov 15 2018
    Nominating myself for potentially "the stoopid question of the day award", but here goes: How do you guys know what your coolant temp is? Unlike the oil temp digital readout, all I see for the coolant is the silly bar gauge. Is there a deeper menu display that I'm not aware of?
    DaveGee
    Jun 26 2021
    Romania
    I solved the problem after i changed switching valve (solenoid valve ) now the car is runing fine . Thanks for helping .💪🏼
    Jan 03 2009
    Iowa
    Thanks for updating!
    Dec 09 2020
    CA
    Quote Originally Posted by Alexfica04 View Post
    Did you replace this yourself or did the dealer do it?
    Jul 30 2021
    Fort Myers
    Quote Originally Posted by toxicxk23 View Post
    The valve is the correct solution however the part isn't listed correctly under any part distributor and is nearly impossible to find.
    The part number for the valve on the vehicle is 037906283. Which is listed as a secondary air injection valve on FCPEuro for $27. And you can also buy it from oriellys auto under interchange part number 667-108 for 149.99 and can confirm both parts are the same number, identical, and work.
    Part 037906283 has been used in tons of audi/vw vehicles over the years but still says it won't work when you put in anything 2018+for a vehicle search this is incorrect and it is the same part for the 3.0 Turbo sq5/s4 (not supercharged)
    Part is easily changed on top of the passenger cylinder head.
    May 13 2021
    Supercharged Miata
    Is the thermostat hard to change on these cars? I think I might need one as well.
    Edit.. the fans are going full blast as soon as I turn the car on and stay on for the duration of the drive.
    Aug 23 2017
    sf
    Do you mind giving some quick instructions on how to change?
    and i looked up the part number on fcpeuro but i couldnt find anything but i found this on audis site: https://parts.audiusa.com/p/Audi__/4...37906283C.html.
    Same thing right?
    Quote Originally Posted by Broke18SQ5 View Post
    Jun 26 2021
    Romania
    I have new problem ! Air leak admsion- another 3 weeks in audi service and nothing - Any help !?
    Jul 30 2021
    Fort Myers
    Yes that is the correct part. Yes I will get more information and pictures for you as soon as I get off work.
    Fcp euro part
    https://www.fcpeuro.com/products/aud...RoCaIwQAvD_BwE
