Results 1 to 10 of 10
    Junior Member One Ring
    Aug 26 2020
    Milwaukee
    IE pulley alternatives?
    I am getting really tired of waiting for IE to restock the supercharger pulley. Is there any alternative pulley that'll work with my IE tune? It's been 2 months now.
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by ivou158 View Post
    Most aftermarket upper pulleys are around 57.5mm diameter. I’ve run EPL and IE tunes on non-IE pulleys.
    Jul 31 2016
    PA
    ^This, pretty much any aftermarket SC pulley is fine, they may very by a couple 10s of a mm, but there is nothing special about IEs particular pulley.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by djn876 View Post
    Truth. There is no meaningful difference in supercharger pulley diameters. They are pretty much generic items now. Any Stage 2 single pulley tune should work well with any of them.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Three Rings krwalkman's Avatar
    Jan 01 2018
    Thornton, CO
    Jokerz Performance just came out with one called a griptec pulley. It's supposed to be pretty great from what I have seen. It is not cheap, nor is it crazy expensive, but Jokerz has a pretty good reputation. They will also port your SC if you like haha.
    Jokerz Pulley
    Moonlight 2012 A6 Prestige FBO - SOLD
    Monsoon 2014 SQ5 Prestige
    4.0T Swap in Progress by @SPAutowerks
    Jul 31 2016
    PA
    Quote Originally Posted by krwalkman View Post
    Jokerz Pulley
    Only downside is they want you to use their install tool at 135 (can usually find one to rent for cheap for a normal pulley) and then you need the hub for another 60, so all in you are at 364. You can easily find one for 100 bucks and rent a tool for maybe 50?
    Not knocking the product as I'm sure it works great, but it is definitely a fair amount more expensive in the end.
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Looks like Brett clarified the tool is a 135.00 add on and you get 120 back once you return it. Still a little higher then a Standard pulley but I will say one thing it looks very cool
    Sent from my SM-N986U using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Senior Member Two Rings sQ5inSD's Avatar
    Apr 26 2020
    Las Cruces, NM
    Why even bother with the SC pulley - just get the correct diameter crank pulley for the final ratio / tune you desire and eliminate the potential for the OE damper failure...
    Jul 31 2016
    PA
    Quote Originally Posted by RoofRails View Post
    That's not bad then, I saw the discussion on the FB group about the install kit, sounds like you just pay the shipping then so not too bad.
    Apr 26 2020
    Las Cruces, NM
    Quote Originally Posted by STXA7 View Post
    from what i understand, belt slip increases when you spin the supercharger faster than normal and when you switch to smaller supercharger pulley because it has less surface area to grip. getting the jokerz with griptec in theory should help prevent some horsepower lost to inefficiency
    yes - what He said - best advice is to determine what final engine RPM to supercharger ratio your tune will support and then just replace the CRANK pulley do not bother with the SC pulley - reputable vendors such as JHM or 034M offer crank pulleys in various diameters
    Good Luck melting your cats!
