Results 1 to 40 of 43
    Established Member Two Rings Popperoni's Avatar
    Oct 18 2020
    2002 Chevrolet Malibu
    Minnesota
    New Owner of a 2013 B8.5 Audi A4 74k miles, first day of owning it's giving me a P029
    Was hoping you guys can help me out. Today was the day I finally ditched my old Chevrolet Malibu and joined the super awesome luxurious Audi gang. Well, so far I'm not impressed at all. So, I am hoping that this isn't a very serious/expensive fix. From what my Verizon Hum is telling me it's something to do with the turbocharger being underboosted, If anybody has experience with this error code please let me know your experience and any tips that solved it for you. I bought the fucking car "as-is, no warranty" so my last resort is going to the dealership for a fix. My friend is a mechanic but I won't be able to call him for a couple more days so I'm just hoping to get some peace of mind from this community.
    I've loved Audi all of my life and couldn't wait for the day that I would be able to own one. It's just not going the way I imagined. :(
    Also, if long time owners would also like to input what they had to fix after 75k miles, 100k, etc would be incredibly helpful as well so I can get an idea of how much to put aside for this car.
    Thank you.
    Junior Member Two Rings
    Oct 09 2017
    Saratoga
    I’m guessing it’s code p0299, you need to check for boost leaks. Also check the diverter valve, lastly check the wastegate for play.
    Veteran Member Four Rings Traptalk's Avatar
    Oct 14 2018
    Buffalo, NY
    Don’t forget the n75 valve which controls the opening of the wastegate
    ig: @wastegate_warriors
    i like meth
    Feb 15 2016
    Cambridge,Ontario
    Throwing profanties out on your first post..... nice...
    Good luck...
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    You should probably take it back to wherever you bought it and have them deal with it and fix it. No point in you doing anything on a car you just bought. Unless you bought it privately, then my condolences.
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Oct 09 2017
    Saratoga
    He says he bought the “fucking car as is”. He’s probably buying a turbo soon or going back to Chevy.
    Jul 25 2016
    California
    Quote Originally Posted by Flight930 View Post
    Ah, I got bored and stopped reading but the last part of my comment does the job 👍
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Oct 18 2020
    Minnesota
    Quote Originally Posted by Traptalk View Post
    Is this the "diverter valve"? or is that a different part? I took a look today. Diverter valve wasn't leaking oil. The actuator rod was working fine when I put pressure through a compressor. Cleared the code and I will see if it pops up after a while again, if that happens I will start taking apart the turbo.
    Oct 18 2020
    Minnesota
    Quote Originally Posted by Nano909 View Post
    I got in touch with my salesperson. Will see if she can work something out. Just kinda seems bogus that something would go wrong within 24 hours of owning it lol... Thank you
    Nov 20 2016
    Quote Originally Posted by Popperoni View Post
    The N75 valve is the electronic boost controller, its just above the diverter valve, where that other connector goes.
    - - - Updated - - -
    lol I drove my car home from the dealer, 89k on it, and the water pump failed immediately. Took me a month before the dealer paid to fix it.
    Oct 18 2020
    Minnesota
    Hopefully I won't have to go back to Chevy :) love everything about this car expect for this one issue. I can see why Audi has such a passionate fan base, they ride so nice compared to what I've driven in the past.
    Jul 25 2016
    California
    So it was a dealer? They have a legal obligation to fix anything wrong with before 30 days or I think 1000 miles.
    Oct 18 2020
    Minnesota
    That was my initial thought was too, and im hoping that is the case. But after doing some research I saw that in the state of Minnesota if the car is over or 72k miles a dealer does not have to uphold that warranty. Again, its on the internet and who knows if it's true. I pray to God it's wrong. I'm just going to have to sit tight until my salesperson calls me tomorrow about what they can do. If they deny something like this I feel like it will just look plain wrong and not a good image for that dealer.
    Jul 25 2016
    California
    In California they'll take care of it no problem because you can sue them so hard.
    May 12 2017
    Any dealer worth their salt should take care of this for you. Unless you bought it from those small independent dealers, then you're prob screwed.
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    I’m seeing used B8.5 turbos on ebay for around $300. If you can do the work yourself shouldnt be too bad.
    Some humble mechanic info: https://m.youtube.com/watch?v=7fk6cSDE3hE
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Oct 14 2018
    Buffalo, NY
    They are different valves that are located right next to each other on the front of the turbo
    N75 has the 3 vac lines and a harness, dv is just bolted to the front with 3 bolts with the harness
    i like meth
    Senior Member Two Rings BrianVan's Avatar
    Apr 03 2015
    Naperville, IL
    Please search the forum first before bashing the car and looking for free advice before doing any research. There is a lot of experience on this board and willingness to help. Google the code p0299 and find out what it means and search the forum. Just be sure to either want to pay to fix, or do it yourself. Just as Flight930 and Traptalk stated, start with that. Those are basic maintenance. If tackling those two items are above your skill level, take it to a euro shop that knows Audi’s.
    2013 B8.5 A4 Quattro Auto| Ice Silver | RS4 Grill and Fogs | Painted Calipers Gunmetal | R1 Concept Rotors Drilled\Slotted | Ceramic Pads | Audi Puddle Lights | LED Interior Lights | RS4 Pedals | ECS Drivetrain Mounts |Luft-Technik Intake | Red Coil Paks | Plasti-Dip Rear Emblems | Carista | Spacers 12.5Front 25Rear | ST Coilovers | Ceramic Paint Protection | Lamin-X Tail Light Tint GunSmoke |
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    My 2013 came out code P0299 at 100K, turbo replaced and everything back to normal. As I read, those updated diverter valves and hoses should last over 100K miles, I think your one is the turbo wastegate issue. may cost turbo $1600 + labor.
    B6 Noggy Avant, B8.5 Allroad
    Oct 18 2020
    Minnesota
    Quote Originally Posted by audrobotic View Post
    Thank you!
    Oct 18 2020
    Minnesota
    Quote Originally Posted by BrianVan View Post
    You're right, I'm sorry I was just stressed out and felt like my old man was right about "those foreign cars are meant to waste money, yada yada", after collecting myself I started digging around under the hood. May or may not have fixed the problem, cleared the check engine light we will see if it pops up again. Thank you!
    Oct 18 2020
    Minnesota
    Ah okay, I think I know which one you are talking about. It was higher up into the engine bay, had the same color wire connector, I will look at it this weekend... What should I be looking for on it to know if it's faulty? Thanks!
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    OP, owning an Audi or pretty much any other German vehicle is a Love/hate relationship and your A4 is a great automobile but will need repairs you are not used to with owning other cars.
    My 2 cents is when you have a problem don't fix it half ass, fix it right the first time and take your time diagnosing the problem before just throwing parts at it.
    A few years ago I bought my first Audi (09 Avant) with 109K miles and cut my teeth quickly learning how to deal with the problems that came up and getting them fixed so I didn't have to worry about them coming back and like you within a few months of owning I was getting the infamous low boost code that eventually lead to me getting a rebuilt turbo and having it installed when my timing chain skipped and destroyed all but one of the vales in my head which allowed me the opportunity to replace the turbo and deal with the carbon build up in the upper intake. After that engine ran like new.
    I drove this A4 to 150K miles and it put a smile on my face every time I drove it, you need to understand the ups/downs of owning an Audi and be prepared to deal with the problems calmly. There are some great resources to get assistance and advice from fellow Audi enthusiasts like this forum.
    Mar 26 2019
    Ontario
    Diverter valve would be my guess given the mileage...operative word is GUESS. Thankfully replacing the DV is pretty easy...three bolts...takes 10 mins...if you're down there...get the modified one that's more whistlee...
    Jul 25 2016
    California
    Quote Originally Posted by Bee8point5 View Post
    My turbo was bad around 70k miles as well. So it's possible.
    Feb 15 2016
    Cambridge,Ontario
    Diverter valve would be my guess given the mileage...operative word is GUESS. Thankfully replacing the DV is pretty easy...three bolts...takes 10 mins...if you're down there...get the modified one that's more riceee...
    FIFY
    1976 Yamaha XS 360
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    Friend of mine used to say. If you can't afford a new german car then you can't afford a used one. LOL.
    2013 Allroad Premium Plus UM stage 1
    2003 Allroad EPL Stage1+ straight downpipes catless(sold at 187K miles)
    Jun 03 2010
    2010 A4 Quattro, 2017 VW Golf Sportwagen 4motion
    Fort Myers, FL
    Quote Originally Posted by lepa71 View Post
    I agree with that! I bought my 2010 A4 Quattro brand new and it has been an experience! Still love it though and will not be selling it.
    2010 Audi A4 Quattro, Check out my upgrade and maintenance videos Cars and Coding here: https://www.youtube.com/playlist?lis...4DHrYwEPid0aZb
    2010 Audi A4 Quattro, Follow my repair videos on youtube: https://www.youtube.com/c/carsandcoding
    Jul 25 2016
    California
    Quote Originally Posted by cuda2000 View Post
    I know exactly who you are now. Hahaha
    Jan 30 2018
    Rochester, NY
    OP craps all over our A4 platform, people offer assistance/suggestions and now they are gone............ Loser !
    Oct 18 2020
    Minnesota
    Quote Originally Posted by rcprato View Post
    I was just pissed off, I’ve calmed down since I’m sorry I know it’s a great vehicle if anything it’s the dealer making it a terrible experience for me. I shouldn’t have to go repair a car after driving it 200 miles from the dealership.
    Aug 21 2019
    Montreal, Canada
    I see you posted on the Audi subreddit. Hope you get your issue sorted out, keeps us in touch. I swear moonsoon grey A4s are cursed lol, my old car was exactly the same as yours and was a total nightmare, dumped it and got a manual S-Line instead.
    If your dealer doesnt help, try Audi NA. They seem way more indulgent in the US than here in Canada.
    Dec 03 2014
    SF/CA
    OP, dont be pissed. there is still good knowledgeable members here to help/share with you, like "Smac770". You don't need to care unrelated post, we are here try to fix the car right at the first try.
    P0299 is an infamous issue with our turbo, it mostly due to the wastegate loosen. B8.5 already has updated Diverter Valve and N75, it should last longer that why i think your one mostly need turbo replacement. As i read, most part on this part will still work fine except the wastegate will fail just matter of time. If your friend is a mechanic, just let him to scan and read the complete code.
    I wont suggest to replace with any USED turbo, those used turbo also going to fail if wastgate havent enforced/repaired. Remanufactured one around $1K and Audi one is $1.6K. I think "cuda2000" has youtube video how to replace it.
    Oct 18 2020
    Minnesota
    Quote Originally Posted by hkdolphins View Post
    Would I be able to hear if the turbo has gone to shit? When I took it to a mechanic I revved the engine and let him listen and he told me it didn't sound any different, we took out the diverter valve and it wasn't leaking oil or anything so we didn't think that was an issue either. Only thing we didn't do was take apart the turbo (which is probably what we should have done) I can't really feel a loss of power but my launch times are just a tad slower (within margin of error). We cleared the code so I'm just waiting for it to either pop up again or never pop up again, lol.
    Oct 18 2020
    Minnesota
    Also when we were monkeying with the turbo, we tried moving the actuator rod when the car was off and it wouldn't budge. But when we put pressure through it with a compressor, we could clearly hear it open and close and I visibly saw it move. So with my novice turbo experience it seemed like the actuator rod was moving the wastegate flap (that's how it works I think, right?) Normally...
    Just really puzzled. Can't take it to Audi for an "official diagnosis" until the code comes back though. That was a mistake on my behalf.
    Dec 03 2014
    SF/CA
    I didn't hear any click sound when code came up (some said yes), also can't feel any significant power loss but i feel the RPM wasnt up smoothly as it was. Some owners remove the 02 Sensor and borescope the wastegate movement. My CEL came back around 20 miles after cleared.
    https://www.youtube.com/watch?v=7fk6cSDE3hE
    Oct 18 2020
    Minnesota
    So was that how you fixed your problem was replacing the turbo? Call me crazy but I really wanted to tune this guy to APR stage 1 with a cold air intake and catback but from the sounds of it before I even think about it I should replace my turbo...
    Thank goodness I've been saving my money for years.
    But regardless I am hoping the code comes back so I can chew out the dealerships ass. I shouldn't have to pay for this repair, the code came on 6 hours after picking it up from the dealer!
    Dec 03 2014
    SF/CA
    My one is earlier B8.5 (MY 2012), so i replaced DV(tested the old one still work correctly) and reset the code. Code returned after ~20miles. Basically my shop pretty sure it's the turbo, replaced a brand new audi one and everything back to normal.
    If APR stage 1 is your plan, sooner or later you need a new turbo, it doesnt matter now or later. I dont chip my cars and read ppl will put K04 with chip.
    The youtube link above should get you all about this infamous P0299.
    Veteran Member Three Rings Depthcharge's Avatar
    Nov 15 2007
    '21 PS2, '20 SQ5, '14 A4
    DFW, TX
    Quote Originally Posted by Spawne32 View Post
    rofl +1
