Results 1 to 24 of 24
    Junior Member Two Rings
    Jul 01 2008
    Texas
    Lowering Links for C8 RS7?
    I'm probably going to pull the trigger on an RS7 in the next few weeks, and I'm already looking at wheels and stance. I did the lowering links on my 2016 RS7, and they've been nothing but great for two years. Has anyone confirmed yet if they'll work on the C8? I'm guessing they didn't change much in the way of the air suspension design, but I could be wrong. Fingers are crossed that the same lowering links will work on the C8, but I wanted to ask before I try it.
    Any feedback/insight is appreciated!
    - 2023 RS6 Avant Nardo Gray - CETE Lowering Module, Exhaust Valve Controller, Vossen 22” Anthracite HF3’s
    - 2020 Audi R8 V10 Performance
    - 2023 Porsche GT3
    - 2006 Ford GT
    - 2019 Corvette ZR1 Convertible
    - 2013 Ferrari 458 Spider
    - a few old cars
    Senior Member Three Rings nish's Avatar
    Mar 19 2012
    RS6 Tribute & RS2 Avant
    Tampa, FL
    Quote Originally Posted by dontbethatguy View Post
    Talk to Jose at MTM, he’s already done a few cars with the links
    -Nish
    IG: @rswgns
    Current: RS6 Avant Tribute & RS2 Avant
    Past: B7 RS4 Avant Tribute | C7 S6 |B8 A4 Avant S-Line |Mk4 R32
    Veteran Member Three Rings sandjunkie's Avatar
    May 29 2013
    2021 S4 Kemora Grey, 2024 Macan S Volcano Gray, 2022 718 Spyder Shark Blue
    Orange County, California
    Why lowering links vs factory scan tool?
    @flatsechs
    2021 S4
    2024 Macan S
    2022 718 Spyder
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    Just a heads up.
    Lowering links work beautifully when new. If it’s a daily driver though, and exposed to a winter season, they corrode like mad. The ball joint will eventually become seized, and then break the sensor, or even snap the ball stud off.
    I used them on a macan turbo, it broke the stud right of the suspension arm after two seasons.
    On the S8 it broke the sensors from huge loading from a seized ball joint.
    The threads also become inoperative after six months.
    Now the design may be different, but mine were threaded steel type construction. I greased them too.
    So if your a fair weather show car. It’s a fantastic solution. For me it cost me a stranded macan wth front suspension locked full pumped up with a busted stud hanging off the sensor. And a replacement sensor on two of the wheels for S8.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Senior Member Three Rings MBrock's Avatar
    Oct 24 2012
    ^ Great info! Thanks. I was just looking at the various lowering options on the air suspension that we all defaulted to in NA.
    Current: 2025 Audi RS6 Performance, 2023 Alfa Romeo Giulia Quadrifoglio, 2019 Mercedes AMG GTC Roadster
    Established Member Two Rings Ryun43's Avatar
    Sep 28 2020
    RS6 Avant
    Jacksonville FL
    The MTM links I put on my rs6 where plastic similar to the stock ones.
    Should help with some of the issues.
    Honestly after seeing how meager factory links are, metal threaded ones seem like unnecessary overkill
    IMO
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by sandjunkie View Post
    Do we know of anyone who has done it with Vag yet? I went that route with my C7 and loved it.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    May 29 2013
    Quote Originally Posted by Djpeaksd View Post
    I will have mine done that way on Nov 6.
    @flatsechs
    2021 S4
    2024 Macan S
    2022 718 Spyder
    Apr 13 2012
    San Diego
    Just going vag not cete? Also I think Smooremin has his done already with the Audi tool at his dealership.
    2021 RS6 Avant - Navarra Blue with Xpel Stealth, Vossen S17-06 in Dark smoke, lowered 25mm, Milltek exhaust
    May 29 2013
    Quote Originally Posted by sdaudiguy View Post
    Yep no CETE. Want to show stock at the dealer and vag seems easier and cheaper.
    @flatsechs
    2021 S4
    2024 Macan S
    2022 718 Spyder
    Apr 13 2012
    San Diego
    What’s a vag tool run?
    Jul 01 2008
    Texas
    Thanks for all of the info guys! I definitely appreciate the feedback LOU. I'm in central Texas, so no winter weather here. With that said, I'm not going to use the metal links like I did on my C7.5. They were a PITA to get set with the lock nut on both sides, and I agree that it's a bit overkill considering how flimsy the factory links are. If I do links again, I'll go with the MTM's, as suggested. They look easier to set and can't corrode.
    Correct me if I'm wrong, but I thought the VAG tool would only lower the car around 1/2" on the C7's. I won't let the dealer do it because I just don't have faith that they can. It's the same guys that couldn't set the oil level correct in my current RS7 where I had to go back two more times after an oil change because they overfilled it. While the tech was draining more oil out, the service advisor was telling me that I can't drive the car less than 10 miles at a time or it gets an inaccurate oil level reading. He won the award for the dumbest thing I had heard all week.
    - 2023 Porsche GT3
    - 2006 Ford GT
    - a few old cars
    May 29 2013
    C8 can go much lower on Vag. @smoormin’ car went probably 1.75 inches down before he stalled on about 1 inch down for daily driving
    - - - Updated - - -
    $540 Total with full 4 wheel alignment.
    @flatsechs
    2021 S4
    2024 Macan S
    2022 718 Spyder
    Jul 01 2008
    Texas
    @sandjunkie, that's great to know! Thanks for the info. I may go that route as well since it'll go lower.
    - 2023 Porsche GT3
    - 2006 Ford GT
    - a few old cars
    Senior Member Two Rings aquarian's Avatar
    May 29 2011
    Bellevue, WA
    Are dealers the only people who can do VAG lowering on the C8? I have a 2021 S7 coming soon so am curious about options as well.
    - - - Updated - - -
    2012 Audi R8 V10 - Titanium package - TCU tuned - Hard-wired Escort 8500 X50
    2017 Audi Q7
    2021 Audi S7
    Apr 13 2012
    San Diego
    I thought the vcds tool could do this as well but dont know. The info online ive found seems to say so...
    Feb 01 2016
    Encinitas, CA
    I think it just takes someone who knows VCDS very well to figure it out. On my C7.5 everyone in beginning said it couldn't be lowered with VAG. A buddy of mine who is very very good with that stuff figured it out and lowered my car for me.
    Oct 31 2005
    Ashburn
    I was able to do VCDS lowering on my previous C7 S6 just as others have mentioned, my B9 SQ5 however is different. From what I'm hearing VCDS cannot lower the newer air suspension equipped vehicles.
    When I tried to use VCDS anyway, the tool was locked out of the module so that you couldn't access the controls. I have heard the Audi Scan tool is the only tool that will lower newer cars.
    - Instagram: @Sinister_rs5-
    Veteran Member Three Rings Smooremin's Avatar
    Jul 02 2015
    Chicago, IL
    - - - Updated - - -
    We dumped out 88mm when we slammed it
    Ended up at 22mm lower or something like that
    24 S8
    96 Grand Marquis
    88 16v Scirocco
    May 29 2013
    Quote Originally Posted by Smooremin View Post
    Wow 88mm!! Didn't expect that.
    @flatsechs
    2021 S4
    2024 Macan S
    2022 718 Spyder
    May 29 2011
    Bellevue, WA
    Using VCDS or ODIS?
    2017 Audi Q7
    2021 Audi S7
    Jul 02 2015
    Chicago, IL
    Quote Originally Posted by aquarian View Post
    Using VCDS or ODIS?
    ODIS
    24 S8
    96 Grand Marquis
    88 16v Scirocco
    May 29 2011
    Bellevue, WA
    How much lower can the MTM lowering links provide? I might consider doing that when my S7 arrives.
    2017 Audi Q7
    2021 Audi S7
    May 29 2011
    Bellevue, WA
    Just found out that MTM links and Ghostlinks are identical. https://www.ghostmotorsports.com/pro...stlinks-a6c74g
    2017 Audi Q7
    2021 Audi S7
