So – Audi CPO warranty strikes again…
Here the course of events;
Took my car in the shop for the 45k miles service (40k miles on the clock) in December of 2019 – complaining about a leaking rear differential.
Was informed by Audi Marietta that my car (2016 S6) does not have any regularly scheduled differential oil changes and that they would need to perform an "oil change" on my dime.
After complaining that leaking should be covered under warranty – the shop graciously comp’ed the refill (no rebuild, reseal or anything).
Fast forward to September 15th – dropped the car off because the differential was leaking (again), and the transmission was shuddering on downshifts + a blown motormount.
They “fixed” the leaking differential (as per the invoice they presented to me) by “wiping oil from previous repair”. SMH – after continuous complaints that wiping oil doesn’t constitute a “fix” – they promised to “monitor the situation” (as my car sits motionless on their lift – I doubt it will leak there, cold and unused…)
After initially finding the motormounts to be “in perfect working order” – I had to show them the VCDS readout of the failed mount, at which point they were able to “reproduce the issue – and found fluid leaking from mount”.
But my personal favorite is the shudder, it’s covered in TSB 2059303/1 from May 2020.
As per (again) Audi Marietta – my car (2016 S6) wouldn’t be covered by the TSB – while it clearly states “ALL VINs” for 2016 S6…
After further pressure and a call to AoA they sent oil samples to AoA and were told from the engineering team that the mechatronic did fail and that a replacement is needed.
Now the kicker – AoA denied to cover this due to “modifications to the suspension” (I replaced the stock plastic air links with aluminum ones, when one original one snapped – ride height was NOT altered) and put 15mm spacers front and 20mm spacers rear on.
Plus added an aftermarket exhaust.
That’s the full list of modifications aside mirror caps and other optics.
I am waiting for their letter to me, above was a phone call – my attorney is going to have a field day…
