Results 1 to 15 of 15
    Senior Member Three Rings Clod's Avatar
    Dec 31 2010
    Boston
    Carbon fiber mirror caps
    Does anybody have the OEM carbon fiber mirror caps? Do you think they are worth the cost or should I go for the replicas? I had a set of replicas on my A3 and they looked good but thinking about getting the OEM ones. Seeing that you can get replicas for about a quater the cost maybe that's the way to go? Thoughts?
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    Poor fitment, wind noise, eventual discoloration and or delamination is what you can expect from aftermarket. You get what you pay for
    Sent from my Pixel 3 XL using Tapatalk
    2018 nardo gray rs3 - sold
    Mar 28 2018
    I would recommend getting the oem ones , you can find them on Ebay from time to time and they are usually pretty well priced. There's actually a set on there right now starting bid at 220. But they are the non side assist ones. Keep an eye out and I'm sure you'll find a set
    Sent from my SM-G950U using Audizine mobile app
    Senior Member Two Rings WmRS3's Avatar
    Dec 13 2019
    Audi RS3, Audi S8, Ford Raptor, Volvo S60R
    MA
    Oem Audi of Jacksonville Alex in parts is where I got all my carbon parts cheapest I found find.
    Oct 02 2017
    I have the OEM ones, with the help of an S3 owner he did a video of the install. He was very impressed by the OEM version vs the aftermarket ones he owned. I went ahead and got ppf on mine but the issue with the aftermarket ones had less to do with CF quality and more to do with internal webbing for fitment. OEM is just a better product especially for install and fitment.
    Dec 31 2010
    Boston
    Thanks for the feedback, do you guys know if the OEM ones are all carbon fiber or wrapped ABS?
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    I bought cheap ones. Then after they warped in the sun I got the oem ones. Oem was wrapped just like cheap ones. But they have held up fine.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    Junior Member Two Rings
    Dec 05 2017
    AB
    Quote Originally Posted by Bezlar View Post
    I had the oems as well and did not like the fitment. They would overlap almost to the lower portion of the housing not providing a flush fit along with the side assist indicators where they no longer seated flush but inwards.
    Apr 05 2006
    992 c4s
    Blue Springs
    Quote Originally Posted by LuckyBB View Post
    I had the oems as well and did not like the fitment. They would overlap almost to the portion of the housing not providing a flush fit along with the side assist indicators where they no longer seated flush but inwards.
    Yep the rs3 ones don’t fit near as well as my sq5
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    Dec 31 2010
    Boston
    Bummer! Guess I have to look for somebody that does full carbon fiber not just wraps.
    Dec 13 2019
    MA
    Took me 3 sets to get a good pair.
    Aug 23 2009
    2008 A4 Avant S line/Titanium pkg
    Gresham,Oregon
    I bought my oem set off ebay 3 yrs ago.$200! Had them on my 16 S3,18 S3 & now my 19 RS3. Perfect fit each time!
    Dec 31 2010
    Boston
    Quote Originally Posted by denz50 View Post
    How did you score a deal like that?
    Dec 05 2017
    AB
    Quote Originally Posted by WmRS3 View Post
    OEM or aftermarket?
    Veteran Member Four Rings adamkb26's Avatar
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    OEM is best just get them from Audi and they’ll be covered for quality and fit.
    2018 Mythos Black TT RS
    034 Stage 2 ECU/TCU | IE Carbon Intake/Inlet | AWE Switchpatch | Forge Motorsport FMIC | 034 Parts: HFC DP, Dogbone Mount/Inserts, RSB/End Links, Subframe Inserts, DSG Catch Can | Euro OLEDs | AP Carbon Wing/L Blades | HRE FF11
    2018 RS3 | 2018 S5 | 2017 TTS | 2015 RS5 | 2013 S4
