Arnold is a personal friend of mine and is pretty good at what he does. Did you also buy the Eurodyne Suite from him? If so, you should have asked him how to go about it.
What are your engine, turbo, and fueling specs? And with the new information you gave, I assume you are just trying to get a base file on your car running and go from there (this is also a real question)?
I have been out the loop for a while, but the base files "back in the days" were basically OTS (off the shelf) tunes that CTapp used to offer for bigger turbo applications. Not sure if the Eurodyne program is the same today (I have Eurodyne and got remote tuned) as it was before, but the Suite basically allowed you to fine tune from that base file (that was essentially an OTS tune). When I had my car tuned, my tuner had already tuned a bunch of cars and had a library of files (this was his job at the time). I gave him the specs of my setup, he said he had a file that was similar to that setup and that was the base tune we used for my vehicle. From that base tune catered for another vehicle he refined it through 5 (or 6) revisions total, increasing boost on each revision. During this time my crank gear was not dowel pinned and I felt the engine was unsafe to chase more power, so we stopped at 25psi on 93 octane (350whp butt dyno). Been running like that for a few years now, and next goal is 400whp on e85 (current slow project).
Point is that is how I went about getting my car dialed in, so you know at least one avenue to take if things don't work out too well. And I say this because even though I know the basics of tuning (don't confuse knowing the basics with actually putting parameters in a program), I also know how easy it is to blow up your engine if you do things improperly. So, I leave that to the professionals.
