Results 1 to 40 of 61
    Veteran Member Three Rings Ace22's Avatar
    Oct 26 2013
    Ohio
    Winter mat options
    Since these are hitting our shores, and winter is around the corner in my neck of the woods. What are people doing for winter mats? cargo mat?
    I have Weathertech in my current RS7, and have not been disappointed, although it looks like the current rubber mats (rubber all weather) are not available. (I don't care for the floor liner look)
    The Audi parts for front and rear look appealing, but the Audi cargo mat still says "A7" for all 3 models...weird.
    Assuming A7, S7, and RS7 are similar inside, what options are there?
    2021 RS7 Unitronic Stage 1+, Akrapovic, Eventuri intake, Performance Wheels, IE lowering links
    2023 SQ8 Stock
    Junior Member Two Rings
    Jun 22 2014
    Nashville, TN
    Agree with on the Weathertech. They belong in an F150 but not an RS6/7. I had the S6 winter mats in my previous car but don't see the same option for my RS6.
    I bit the bullet and orders the A6 labeled mats. Better than nothing.
    4K1-061-221-041 A6, S6 (2019+) All-Weather Floor Mats Set, Front - Black
    4K0-061-511-A-041 Rear Foot Mats
    Apr 05 2012
    Earth
    Quote Originally Posted by Ace22 View Post
    This is the case for all Audis. They have specific A/S/RS mats for the driver but the trunk/cargo area mat only comes the one way.
    I always get the Audi rubber floor mats and trunk liner thrown in with the car (I'm sure I pay for them somewhere along the line).
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    I understand you preferring something other than the WeatherTech floor liners but they are the gold standard. I can't tell you how disappointed I was with even the WT rubber mats vs. the floor liners. The Liners just outperform by a wide margin.
    Maybe an option to customize the WT Floor Liner would be to remove the WT sticker on the Liner (it eventually comes off anyway) with an RS7, Quattro, or Audi rings decal/sticker/badge. You can source them from numerous locations, including Ebay, and I believe there is a thread on AZ where someone "seals" the rings sticker with a clear film.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Junior Member Two Rings need4spd's Avatar
    Nov 13 2013
    Flying Low
    I've had bad experiences with the Weathertech mats, a) the ones for the back are too thin and start to curl up. b) the front ones also are on the thin side on the sides and start to buckle away from the transmission hump and the door side sill. they need to make them a little thicker in my opinion as an engineer. Not sure why they make the back ones from a thinner sheet of plastic.... Just cost cutting and they are overpriced for what they are a heat formed plastic sheet.
    Sorry to be Debbie downer, but I had this in 2 completely different cars (and different makes).
    We have 3D Maxpider U-Ace brand mats in our S5 and like them over the Audi S5 rubber mats, and they are the floor liner type like Weathertech has.
    https://www.3dmatsusa.com/
    2019 A6
    Veteran Member Three Rings Smooremin's Avatar
    Jul 02 2015
    Chicago, IL
    Quote Originally Posted by wbrownie View Post
    I did this too, because I cannot stand carpeted mats, especially in fall/winter. Sure I would love for it to say RS6, or even S6 for that matter, but not to the point where I would not get them, or go aftermarket.
    24 S8
    96 Grand Marquis
    88 16v Scirocco
    Veteran Member Three Rings sandjunkie's Avatar
    May 29 2013
    2021 S4 Kemora Grey, 2024 Macan S Volcano Gray, 2022 718 Spyder Shark Blue
    Orange County, California
    Anything for the cargo area?
    @flatsechs
    2021 S4
    2024 Macan S
    2022 718 Spyder
    Jul 02 2015
    Chicago, IL
    Quote Originally Posted by sandjunkie View Post
    Yeah, same one in the A6 Allroad. I can find the PN if people really need or want it.
    24 S8
    96 Grand Marquis
    88 16v Scirocco
    Veteran Member Three Rings ALLROADINGB9's Avatar
    Jan 23 2017
    Westchester, NY
    The RS6/7 specific mats are apparently coming.. Within the next few weeks.
    Jul 02 2015
    Chicago, IL
    Quote Originally Posted by ALLROADINGB9 View Post
    Of course they are :laugh:
    I guess I will have to hide the costs of those somewhere else now too :laugh:
    24 S8
    96 Grand Marquis
    88 16v Scirocco
    Senior Member Three Rings MBrock's Avatar
    Oct 24 2012
    Current: 2025 Audi RS6 Performance, 2023 Alfa Romeo Giulia Quadrifoglio, 2019 Mercedes AMG GTC Roadster
    Oct 26 2013
    Ohio
    After looking at all the options, I went ahead and placed an order for these winter mats in black. I appreciate the feedback. I have had MaxSpyder in my RS5, Weathertech, and stock from Audi in the past, so I thought I would try something different.
    I figured there were enough RS7 logos in car already, and they seem to have good reviews. Once I get the car and install, will see how they install/perform.
    https://www.lloydmatsstore.com/northridge-floor-mats
    2023 SQ8 Stock
    Established Member Two Rings gezuvor's Avatar
    Dec 11 2011
    '19 Audi Q5 Prestige
    Portland, OR
    Not that it helps, but I wanted to add some clarification:
    4K1-061-221-041 This one is branded A6, but they obviously fit all the A6/S6/RS6 models
    4K1-061-221-A-041 This one is branded S6
    If my history with the nomenclature is accurate, I think there will be a B or C number showing up some time soon, with the RS branding on it.
    The rear mats are the same for all A6/A7 models, since they aren't branded, although there are two versions (511 & 511A), so maybe not?
    Unfortunately, the same goes for the trunk mats & trays. All "A6" branded (so far)...
    - Rich
    Dec 11 2011
    Portland, OR
    Audi doesn't have pics of the S6 version, but this is what they would look like:
    - Rich
    Veteran Member Four Rings Treeskier's Avatar
    Feb 06 2017
    RS6; SQ5; Q7; S2k; ROW D90
    Philly
    subscribed to watch and see what people find / like. I've used weathertech in the past and been happy, but always open to new ideas and, this time, I might splurge for some RS6 mats if they're functional.
    Established Member Two Rings US1787's Avatar
    Jun 28 2020
    Joy
    Virginia
    Anyone have any updates on OEM All-Weather RS6 floor mat options? I'm skeptical that Audi will produce them given that the RS6 has been in production in Europe for two winters now (counting this upcoming season) and there are no mats available in Germany either.
    May 16 2015
    United States
    Bumping this. Anyone get any other options? My SA was going to see about ordering RS ones from Germany. Not sure on the cost and old be fine with whatever fit fine.
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Winter mat options
    Quote Originally Posted by sds193 View Post
    Yes they are available now with the RS6 on the fronts.
    Sep 15 2019
    SE CT
    Quote Originally Posted by gezuvor View Post
    Hows this?
    Established Member Two Rings RisR32's Avatar
    Jan 15 2008
    Philadelphia
    Quote Originally Posted by Jimminez@Nemesis View Post
    Yes they are available now. PM me if your are interested in a set.
    Can you get the front/rear and also the rubber trunk liner with the RS badge?
    May 16 2007
    Ottawa CA / DE USA
    Quote Originally Posted by RisR32 View Post
    Front and rear floor mats are rubber but the trunk is a plastic shell.
    Oct 08 2012
    Bloomfield Hills
    I already have the front and rear rubber Audi mats with the RS on it. However the trunk mat is A7.
    Veteran Member Three Rings svra42.8's Avatar
    Oct 11 2006
    Bartlett, Illinois
    I am using these on my RS7. This was for an A6 but they were cheap, came in 3 days from Istanbul to USA. I honestly cant complain much as they serve the purpose for winter. Cost was a whopping $71.00 for front and rear mats.
    One retainer on the passenger side didn't line up but they don't move.
    https://www.ebay.com/itm/3D-Molded-I...72.m2749.l2649
    2021 Glacier White/Carbon Optic RS7
    Senior Member Two Rings aquarian's Avatar
    May 29 2011
    Bellevue, WA
    I have the OEM S7 all weather mats and loving them.
    2012 Audi R8 V10 - Titanium package - TCU tuned - Hard-wired Escort 8500 X50
    2017 Audi Q7
    2021 Audi S7
    Dec 03 2020
    Wisconsin
    Quote Originally Posted by need4spd View Post
    I think these look sharp but they don't appear to have a fitment for the RS6 yet. They do appear to have better coverage to the door sill than OEM (where I usually get a salt residue in the past)
    Veteran Member Three Rings spidey9999's Avatar
    Oct 19 2006
    We have these in our GTi’s and are very happy with them:
    https://www.tuxmat.com/
    Junior Member Two Rings Mr.Showroom's Avatar
    Jun 08 2018
    991.2 GT3
    Audi has Part Number for RS6/7 winter mats but yet to have an ETA
    I grabbed a set of A6s while waiting for the RS mats to come in, better than nothing in the Canadian winter 😅
    Jan 23 2017
    Westchester, NY
    The mats are off order block and have an MSRP of $140. + Tax and shipping.
    Jan 15 2008
    Philadelphia
    Part #?
    04' DBP R32 SOLD, 06' A-4 2.0t SOLD, 10' GTI SOLD, 11' A-4 2.0t Titanium Avant SOLD, 2012 TTRS SOLD, 17' S3 SOLD, 18' RS3, 19' Q8, 2021 RS6 Avant
    Jan 23 2017
    Westchester, NY
    Part #?
    4K1-061-501-A-041
    Jan 06 2020
    WA
    Anyone have experience with the ‘diamond leather’ mats? If so, how did they hold up? Is using those in a wet environment like the PNW a bad idea?
    Feb 06 2017
    Philly
    Quote Originally Posted by spidey9999 View Post
    anyone put these in their RS6 yet? i particularly like how the rear covers the middle hump...
    Jan 23 2017
    Westchester, NY
    May 16 2015
    United States
    Mine just came in today. Ordered middle of December from Germany by my dealer. $250ish for the set. I ordered Weathertech for the trunk that should arrive this weekend.
    Senior Member Three Rings gpoulos's Avatar
    Sep 23 2019
    Just ordered a set of fronts from Partsbytopher on IG after seeing these pictures. !
    2021 RS6 Avant Nardo Black/Red
    Jul 02 2015
    Chicago, IL
    Quote Originally Posted by gpoulos View Post
    Me too
    24 S8
    96 Grand Marquis
    88 16v Scirocco
    Junior Member Two Rings p549rr1's Avatar
    Jul 11 2013
    2010 Audi R8 V10
    Jersey City, NJ
    Same, mine arrive monday
    Sent from my SM-G965U using Tapatalk
    Feb 24 2014
    Washington, DC
    Tuxmat installed. I was skeptical but I'm really happy with them so far. Fit is great, covering basically the entire footwell. Only minor issue was passenger's side covers up the little mesh net and bulges slightly.
    I like the material better than plain rubber both to look at and to step on. So appears very durable and is easily washable.
    Feb 06 2017
    Philly
    Quote Originally Posted by afrozenfyre View Post
    What is the material? Is it not rubber? How's the rear fit over the hump - nice and snug? Very interested in these...
    Feb 24 2014
    Washington, DC
    Tuxmat says it's PVC outer with an EVA foam-like core that gives it a nice "plushness". It's pretty grippy though and the driver foot pad is rubber so it won't get worn through.
    The rear fitment is fantastic. They include a bunch of clips that fit snugly up into the hard plastic trims on the car, but I barely needed them. Only really used them where it bulged up due to being shipped folded.
    Here's a closer shot of the rear:
