Results 1 to 10 of 10
    Sep 27 2020
    Santa Ana, California
    Exclamation 2009 Audi A4 2.0TSFI Turbocharged Multiple Misfires with Video
    Hello my fellow human beings! I owe a 2009 Audi A4 2.0T Turbocharged with a 2.0t TFSI engine and for the past months I’ve been experiencing misfires on cylinder 3 and cylinder 4. I have done some common fixes like changing the spark plugs, coil pack, PCV valve, and fuel injectors but I’m still having the same problem. I have a bit of symptoms when the car is on such as a little bit of rough idle, rough exhaust, hissing sounds where the cold intake is at, and when I’m on driving gear going 5mph with out pressing the gas and brake, the rpm needle wobbles and my car shakes. Any advice I can get from you. This problem is stressful to me I just want to get over this problem. Thanks for your help!
    Senior Member Two Rings NYDCB's Avatar
    Aug 22 2016
    Washington, DC
    I assume you've pulled codes? What were they? Has any preventative maintenance been done prior (chain tensioner specifically)?
    I am currently dealing with similar symptoms.
    Senior Member Two Rings schwiz23's Avatar
    Feb 22 2020
    Burnsville, MN
    You didn't mention how many miles are on the vehicle. When these symptoms occur it could be excess carbon buildup on the valves or an issue with the timing chain/tensioner. If you're pulling codes with VCDS, check the phase adaptation on the chain to see how many degrees you're at.
    In my opinion, I wouldn't drive the vehicle until it's figured out and corrected. Detonation might not be far away.
    '15 A4 S-Line Premium 6MT - Hybrid K04 - APR Tune - ECS FMIC & Alum. Charge Pipes - IE HFC/Downpipe - S4 Quad Tip Exhaust Conversion - Android 10.25" Carplay Retrofit - S5 19" Wheels
    May 12 2017
    Does your car smell like gas? Like it's running rich? Check your PCV hose connected to your intake manifold. May have a loose connection. My car sounded exactly like that and turns out my buddy forgot to plug the intake manifold when installing my catch can. Weird thing is it didn't happen for 2 weeks after I got it installed.
    Sep 27 2020
    Quote Originally Posted by hcuorG View Post
    Yes it smells like strong gas. I thought it has to do something with the turbo of not getting enough air in the system.
    Sep 27 2020
    Quote Originally Posted by NYDCB View Post
    I got P0300, P0303, P0304. And a hour ago I got a new code P0301 added as well. Engine got rebuilt at 150k miles
    Sep 27 2020
    Quote Originally Posted by schwiz23 View Post
    It has 188k miles. I opened the intake manifold and looks clean from the inside. I don't think its that. And I don't have VCDS available at this moment.
    Feb 22 2020
    Burnsville, MN
    Quote Originally Posted by JohnnyR9822 View Post
    Disregard my comment. Didn’t know it was rebuilt 30k miles ago.
    Sep 27 2020
    It's cool. I'm so close of selling my B8 if I don't find a solution for this.
    Aug 22 2016
    Washington, DC
    You should do a compression test for good measure: https://www.youtube.com/watch?v=En6xaX-QX0Y
