Results 1 to 4 of 4
    Nov 06 2018
    2014 Audi A1 Sportback
    Netherlands
    2016 Q3 rear hatch trim removal
    Do anyone know how to remove the lower part of the trim? I have not had any success on finding a how-to on the subject. Some help would be appreciated.
    Nov 22 2020
    NZ
    Do you mean the lower trim on the rear hatch lid itself. If so for my 2014 model you take off the covers for the lights, and the warning triangle, and remove the four four fasteners. Then you have to use a wedge to release the trim panel from about 8 clips. The rear edge ones came away reasonably easily, but it needed a lot of pulling for the top ones.
    Nov 06 2018
    Netherlands
    Thanks. That is what I meant.
    Feb 27 2013
    Twin turbo 350Z, Mercedes ML350, Audi Q3 and BMW 535i M sport
    New York
    not sure if this will help but here is the link to the video i did adding a reverse camera in the description i did the time stamps for the chapters so to can jump to where we removed the rear trunk lid. https://youtu.be/ret9hi2_lSM
    B7 A4, 6MT, Quattro - Sliver (Sold)
    JHM HPFP upgrade, JHM Test Pipe, JHM Y pipe, B7 S4 exhaust, JHM flywheel and RS4 clutch, GFB DV+, P3 boost gauge, S4 front & Rear brake upgrade, 034 rear sway bar, ST Coilovers, K&N filter, ECS Oil catch can, JHM K04-R Turbo Kit.
    Audi Q3 8U-White
    https://www.youtube.com/channel/UCWU...e_polymer=true
