Results 1 to 20 of 20
    Oct 12 2020
    Manchester, NH
    Redline B8 vs B8.5
    Newbie question here.
    I'm in the market for either a late B8 S4 or and early B8.5 S4.
    I read in the FAQ that on the DSG version of the car the redline was reduced from 6800rpm to 6500 rpm when they went from the B8 to the B8.5
    Does anyone know why this change took place?
    Thanks,
    John
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Likely different gearing in the new DSG. Nonetheless you can still flash a TCU tune to bring the redline back.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by renntorq View Post
    Thanks,
    John
    I was told by unitronic it has to do with a different PVC setup
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Jul 31 2016
    PA
    Crank it up to 7400 and don't look back.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Honestly, all other things being equal, if you can verify the B8.5 has a v2 DSG tranny in it, you want to select that car over a B8.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Thanks,
    John
    Different gear ration on B8.5 is a lot longer gears / updated software / updated mechatronic ! I highly recommend B8.5
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    No difference on 6Mt cars In addition to what has already been said. Audi realized that the S tronic trans was not as strong as a Tip tronic. IMHO,they reduce the redline to take stress off of the trans.
    Oct 18 2006
    Audiville
    Quote Originally Posted by Dr GP View Post
    Perhaps, but again, after talking to Unitronic about the different redlines between b8 and b8.5 on their tcu tunes (according to their website the b8 has a higher redline by 200 rpm) sounds like the differences are more than transmission based and their PVC explanation makes more sense... seeing as how the B8.5 v2 DSG tranny is known to be more robust and reliable, why would Unitronic run a lower redline on the B8.5 vs the B8?
    Their PVC explanation mentioned increased oil consumption due to PVC redesign of the B8.5 at the higher redline iirc... Unitronic also seems to be the only tuner doing this...which makes them either really good or overly conservative?... truth is I rarely see any issues with Uni tunes in regards to oil consumption, cat failure, etc... so the PVC explanation makes sense, at least to me it does...
    Thoughts?
    Senior Member Three Rings usmcfieldmp's Avatar
    May 04 2020
    Fort Worth, TX
    IMHO, they reduce the redline to take stress off of the trans.
    But 2013 was also the first year for the RS5, which I was under the impression used the same S Tronic transmission.
    Similar torque with much higher redline.
    2002 Audi TT Quattro || Entering Racecar Status | Needs a LOT of love || Project Thread
    2013 Audi S5 || TOTALED ||
    || 1986 Volkswagen GTI || 1997 Dodge Viper GTS || 2005 Chevrolet Cobalt SS ||
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Clarification: Are we talking about the redline on the tach or when the REV Limiter kicks in?
    Oct 18 2006
    Audiville
    when rev limiter kicks in/ecu/tcu redline shift point... again as per Unitronics site info and discussions.
    May 04 2020
    Fort Worth, TX
    I've always seen the display of the redline on the tach as arbitrary, and have always used the word "redline" interchangeably with rev limiter.
    So I was talking about the rev limiter, as well - S4/S5 vs RS5; there's about a 2000 rpm difference.
    Oct 18 2006
    Audiville
    Quote Originally Posted by usmcfieldmp View Post
    RS5 is a completely different engine, NA 4.2L V8
    May 04 2020
    Fort Worth, TX
    Quote Originally Posted by 01northernS4 View Post
    I'm aware. Refer to Post #9. He's saying he thinks the lowered limiter is to save the trans, and I'm saying the RS5 goes against that logic. Similar torque curve, but much higher limiter.
    Oct 18 2006
    Audiville
    Ahh yes agreed
    What do you think about Unitronics explanation with regards to the PVC system differences resulting in a lower Redline to reduce oil consumption? They do test the crap out of these things so I'm pretty sure they know what they're doing...
    Jan 09 2010
    New York
    What ?!!
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by UkuRiSh View Post
    What ?!!
    Why do you think the B9 S4s have Tiptronics? Because they can handle more torque. . Wont have to deal with warranty issues ,especially in light of the slight increase in power. Its always about the money.
    May 04 2020
    Fort Worth, TX
    That's just speculation, but it is interesting that it appears that they swapped from S Tronic to Tiptronic on EVERY S/RS car, with the exception of the R8, S/RS3, and TT. Looks like all of the A-line cars are S Tronic.
    I'd bet it might have more to do with how not-smooth, clunky, etc the S Tronics drove, instead of their torque rating. Otherwise, I feel like the A6 and A7 would have Tiptronic, especially when paired with the same engine as the A8, which DOES have Tiptronic.
    Aug 16 2020
    Q
    I am very sure you are correct. The DSG is decent, a cool idea, and makes very fast upshifts. Daily drivability-wise, it's not bad, but nowhere near a traditional torque-converter automatic. It will never get over the clutched standing starts, downshifting delays(in D), and general feel. Compared to the early-2000's M3 with SMG that I drove, the DSG is light years ahead. If I could trade my DSG trans. for a Tiptronic I would.
    Jan 09 2010
    New York
    Lol my car made over 500wtq and my buddy car made over 750wtq and many other DL501 S6/S7 cars with stage 3 made over 700whp / 700wtq they all good and hold power with proper tune! Audi switched to zf because much comfortable and cost much less
