Results 1 to 15 of 15
    May 22 2017
    Wilmington, MA
    Alternator pulley tool?
    Hello!
    I've got a '12 A4q (CAEB engine) and want to replace the pulley on the alternator. I know you need two tools: one is a 33-spline thing that is hollow. But some things I read on the web say the other tool is a torx T50, while others say it's a triple-square.
    Does anyone know what the right tool is for this engine?
    Be alert! America needs more lerts.
    Eric Law
    '14 A6Q 3.0t prestige self-tuned
    '12 A4Q also self-tuned
    Feb 15 2016
    Cambridge,Ontario
    Cant you snap a pic with your phone and look ?.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    May 22 2017
    Wilmington, MA
    No, because the cover is still on the front of the pulley. I've seen covers on those pulleys that look like they could be replaced after removal, but this one's different and I'm afraid I may ruin it in the process of removing it.
    That won't be a problem once I have the new pulley in hand but I don't have it yet, and I want to get the tool ordered ASAP.
    Eric Law
    Feb 15 2016
    Cambridge,Ontario
    I have never relaced the pully sorry, but a pic still might help if you say its different
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    The cover is definitely a rip it off once thing. It ain't going back on. That said, it doesn't matter to have the cover off for short term operation. My '09 had the triple square counter hold.
    Front side, cover ripped off:
    Back aide of the shot pulley, with the tool assembled as I used it:
    The tool kit I bought when I had to replace it. Includes the 33 spline to thread to the pulley and both triple square and Torx for the counter hold. You use normal hex wrenches/sockets to turn them. You'll need a pass-through or crow foot solution to torque it correctly, same as nut on the top of the shocks, etc.
    May 22 2017
    Wilmington, MA
    Thanks! I looked up that set and it deals with the issue nicely because it has both bits! And isn't stupidly long like some others I've seen. So I just ordered one.
    Eric Law
    Feb 15 2016
    Cambridge,Ontario
    so what is the reason for replacing the pulley ??? how does it fail ???
    local wrecker wants 75 bucks for a whole alternator so i think if it failed i would go that route and save the buggering around ....
    unless of course like most things Audi you have to take half the car apart to get the alternator out i guess.
    1976 Yamaha XS 360
    May 22 2017
    Wilmington, MA
    Well, they do fail but in this case it's preventive. The serpentine belt and tensioner pulley are both pretty tired, and I found a kit with the belt, tensioner, idler, and alternator pulley all together for a good price so I figure I might as well replace everything while I'm in there.
    Eric Law
    Jul 16 2018
    Atlanta
    Alternator is really easy to remove.
    The pulley is a one way clutch or overrun pulley. If you insert a wooden stick (not metal!) into the alternator to block the rotation of the rotor, you should not be able to rotate the pulley clockwise, but the pulley should freely rotate counter clockwise. The idea being the belt pushes the pulley clockwise to spin the alternator rotor. But when the engine has a sudden rpm drop, and thus now spins the belt more slowly than the rotor spin rate (ie, the pulley appears to be moving counter clockwise relative to the alternator rotor orientation), the alternator can wind down on its own and is not a dragging force on the belt.
    In my case, the pulley was free spinning in both directions, thus the dash message about charging system failure.
    If the reman alternator includes the pulley for under a C note, that's fine. Wow, alternator pulleys are up a lot from when I replaced mine. But yeah, you have to make sure the used alternator actually includes the pulley, is what I remember when I was having to look into the subject. The pulley was around half the price of the the whole alternator (with pulley). CarID shows this third-party option: https://www.carid.com/gates/alternat...519&url=408154
    06H903119B is for the Bosch alternator (B8.0) vs. 06H903119C for the Valeo alternator (B8.5). The ...119 is another composite part number. Appears the actual part number on the pulley itself is ...201.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Smac770 View Post
    well in my case some grease monkey pulls it out of a wrecked car for 75 bucks ... good enough .. sold..
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    The part number on my pulley (pita to clean all that gunk off) is 06H 903 201 C (for the Bosch 140A alternator).
    Made in Canada, no wonder they are so expensive.
    Only other marking on it is 258A1. No OEM name, not even Audi rings.
    https://youtu.be/Lz7_1Qsg2Tw
    If for nothing more than that catchy intro jingle.
    Feb 15 2016
    Cambridge,Ontario
    holy crap we still make stuff ?? are sure it isnt a scuffed up china !!! :)
    love the miami vice intro
    1976 Yamaha XS 360
    May 22 2017
    Wilmington, MA
    Well this just seems to be one challenge after another!
    I ordered this nice kit from Ina that includes all the serpentine-related stuff including the alternator pulley. And the little cover that goes on the front of said pulley. But I can't figure out how it attaches! It doesn't appear to be a press fit, it doesn't seem to snap on, nor is there any adhesive or anything indicating it sticks on.
    Has anyone ever installed one of these pulleys and dealt with this?
    Eric Law
    Jul 16 2018
    Atlanta
    If it's like the one I got, it presses in. If there's not a lip on the cover that presses into the groove (appears to be a groove) on the black outer ring, then it likely needs to get fed under the black outer ring, into the gap between the black ring and the silver face. I can't remember specifically how mine attached, but it was something like that which took a bit more determination of will than I prefer to apply to car parts.
    May 22 2017
    Wilmington, MA
    Yeah I'm wondering if I got the wrong cover. It looks like it could be a press fit if it were 4 or 5 mm larger.
    I've also contacted Ina (well, "Schaeffler North America") to see if they can offer any insight... I'll post back when I get a response from them.
    Eric Law
