Results 1 to 16 of 16
    Established Member Two Rings T00fast's Avatar
    Apr 19 2020
    Omaha, Ne
    Air Suspension Fault - c1048, c1031
    Greetings all, well I knew this day would come when I'd have something to troubleshoot on my '16 s6. I was cruising home from shopping when I got an air system fault, headlight fault, and TPMS fault. The TPMS fault is taken care of and I understand that the headlight fault is due to the air system fault. I'm thinking that the problem is in the rear given one of the faults talking about the rear. I just need some direction on where to start troubleshooting!
    Edit: I did lower the car 10 mm with VCDS. No issues for around 4 months.
    Here is the full Scan:
    Saturday,10,October,2020,13:06:34:28862
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: WAUF2AFC3GN055175 License Plate:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
    44 46 52 53 55 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
    VIN: WAUF2AFC3GN055175 Mileage: 105187km-65360miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1B-Active Steering -- Status: OK 0000
    20-High Beam Assist. -- Status: OK 0000
    22-AWD -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    85-On Board Cam. -- Status: Malfunction 0010
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
    Part No SW: 4G0 906 014 D HW: 4H0 906 014
    Component: 4.0l V8TFSI / H63 0001
    Revision: NCH63---
    Coding: 0A2500326546010E3000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
    ROD: EV_ECM40TFS0114G0906014D.rod
    VCID: 2313EAB80B52F3F36F1-8076
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
    Component: 0B5 40TFSINAR H03 0006
    Revision: --H03---
    Coding: 000001
    ASAM Dataset: EV_TCMDL501021 001022
    ROD: EV_TCMDL501021.rod
    VCID: 303915F44AA4586BE23-8064
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
    Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
    Component: ESP9 Premium H01 0530
    Revision: -------- Serial number: --------------
    Coding: 65BED449A67D2B921B00
    ASAM Dataset: EV_ESP9BOSCHAU57X 004018
    ROD: EV_ESP9BOSCHAU57X.rod
    VCID: 41DF4030F10EC1E31DD-8014
    4 Faults Found:
    161280 - Tire Pressure Warning
    C102D 00 [047] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 105180 km
    Date: 2020.10.10
    Time: 12:44:51
    VzRef: 4D
    Bit Info 1: 00
    Bit Info 2: 40
    Bit Info 3: 26
    Bit Info 4: 1F
    Uz: B9
    Unlearning counter according OBD: 40
    161536 - Tire Pressure Warning
    C102D 00 [035] - -
    Not Confirmed - Tested Since Memory Clear
    200448 - Function Restriction due to Faults in Other Modules
    U1113 00 [044] - -
    [SCL_LWR_Hoehenwert_HL_Error]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 105181 km
    Date: 2020.10.10
    Time: 12:45:37
    VzRef: 3D
    Bit Info 1: 00
    Bit Info 2: 40
    Bit Info 3: 26
    Bit Info 4: 1F
    Uz: B9
    200192 - Function Restriction due to Implausible Message(s)
    U1112 00 [032] - -
    [SCL_LWR_Hoehenwert_HL_Invalid]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 GR HW: 4H0 907 064 GR
    Component: BCM2 2.0 H37 BCM2 2.0 H37 05720572
    Revision: 00002001
    Coding: 0DA86F4E000000000000
    VCID: 7F5B06C8C7FA77132B9-802A
    Subsystem 2 - Part No: 4H0 905 852 C
    Component: J764 ELV MLB
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
    Component: KLIMA 4 ZONEN H14 0112
    Serial number: 09071500040024
    Coding: 688130B84D0000
    ASAM Dataset: EV_AirCondiComfoUDS 003008
    ROD: EV_AirCondiComfoUDS_003.rod
    VCID: 6A8DC79CACF8E2BBEC7-803E
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
    Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
    Component: BCM1 2.0 H20 0311
    Revision: 21020001 Serial number: 00001117384701
    Coding: 01050011043C9FF2F90048C780003800CF9CD208AE08022180 000894F10017020060002D0B0000
    VCID: 76B5E3ECE8C0365B78F-8022
    Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
    Component: WWS57X 150623 H37 0080
    Serial number: 150707012600
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 24082604
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
    Component: E1 - LDS H07 0044
    Serial number: 25 06 2015 00001184
    Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0030
    Serial number: 00000000095Z01FF2DDA
    Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
    Component: EVLS-SG H08 0300
    Serial number: WA121089000014026874
    Coding: 020300
    Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: 2D19C9B7000000000001
    2 Faults Found:
    00471 - Control Module for Elect. Regulated Dampers (J250)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105180 km
    Time Indication: 0
    Date: 2020.10.10
    Time: 12:45:36
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105180 km
    Time Indication: 0
    Date: 2020.10.10
    Time: 12:45:36
    Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 561 B HW: 4G0 907 561
    Component: ACC3 H21 0053
    Serial number: 00000000000000
    Coding: 7E01010102
    ASAM Dataset: EV_AdaptCruisContrAU57X 002014
    ROD: EV_AdaptCruisContrAU57X_002.rod
    VCID: 290FF890697E29A325D-807C
    1 Fault Found:
    93440 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [FAULT_CIS_VIDEO_FAIL]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105181 km
    Date: 2020.10.10
    Time: 12:45:37
    Control Module temperature: 39 °C
    Voltage terminal 15: 14.398 V
    Velocity_vehicle_reference: 17.06 m/s
    Longitudinal_acceleration_vehicle_reference: -0.61 m/s²
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
    Component: Airbag10.43 H62 0086
    Revision: -------- Serial number: 003G0002AZUA
    Coding: 303331343135303334354A55304C34473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 343119E4BEBC644B86B-8060
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
    Component: BF-Gewichtss. H15 0046
    Serial number: 6940000Y150001D9P40P
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB405L3H46CDGOS
    Crash sensor for side airbag: front passenger side:
    Serial number: 3585HRB405P3CEMSCHCF
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3515JRB405H3FDPEA1SY
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3525JRB400853400GHLL
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB405F341DKC8BA
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB405F341DK9OLY
    Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
    Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
    Component: Lenks.Modul H04 0005
    Revision: -------- Serial number: 90372OG7000K4
    Coding: 0004FC
    VCID: 38292DD4A254802BAA3-806C
    Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
    Component: E221 - MFL H08 0010
    Serial number: 18 06 2015 F0053830
    Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G0 920 982 L HW: 4G0 920 982 L
    Component: TBenUsaAccNv H10 0104
    Revision: 06001087 Serial number: 658100715596044
    Coding: 03CF0905BF51D705020200
    ASAM Dataset: EV_RBD4K 004055
    ROD: EV_RBD4K_AU57.rod
    VCID: 353724E0B5C67D43B15-8060
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 4G8 907 468 F HW: 4G8 907 468
    Component: J533--Gateway H14 0083
    Revision: -------- Serial number: 00000001927546
    Coding: C0ED074814
    ASAM Dataset: EV_GatewPkoUDS 001028
    ROD: EV_GatewPkoUDS_001_AU57.rod
    VCID: 3B2332D893E2AB33471-806E
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Serial number: 8000837103
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
    Component: J532_DCDCStab H23 0022
    Serial number: 1504300000000000040F
    Address 1B: Active Steering (J792) Labels: None
    Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
    Component: DYNAMIKLENK. H06 0730
    Revision: 52001005 Serial number: --------------
    Coding: 0E0100
    VCID: 392F28D0995E992355D-806C
    Address 20: High Beam Assist. (J844) Labels: None
    Part No SW: 4H0 857 511 HW: 4H0 857 511
    Component: FLA H04 0021
    Revision: AA001002
    Coding: 04018264747464545425363E00
    VCID: 678BBEA8BF6ADFD3F39-8032
    Address 22: AWD (J492) Labels: 4H0-907-163.clb
    Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
    Component: 4 Wheel Drive H17 0200
    Serial number: 000307150001033
    ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
    ROD: EV_AllWheelDiffeQSPFR.rod
    VCID: 2809FD94727410AB3A3-807C
    Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
    Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
    Component: KLIMA FOND H08 0112
    Serial number: 15071500040597
    Coding: 20
    ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
    ROD: EV_ClimaContrUnitRearUDS_003.rod
    VCID: 3E253BCC80F0BE1B60F-806A
    Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
    Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
    Component: LUFE-DAEMPFER H19 0783
    Coding: 008006
    ASAM Dataset: EV_AirSuspe 003025
    ROD: EV_AirSuspe_VW51.rod
    VCID: 2F3B1688579A4793FB9-807A
    2 Faults Found:
    455691 - Sensor for Ride-Height
    C1048 07 [008] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105180 km
    Date: 2020.10.10
    Time: 12:45:35
    453633 - Pressure Sensor for Level Control
    C1031 F1 [008] - Residual Pressure for Lowering Rear Axle too Low
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105187 km
    Date: 2020.10.10
    Time: 12:53:44
    Address 36: Seat Mem. Drvr (J136) Labels: None
    Part No SW: 4G8 959 760 HW: 4G8 959 760
    Component: MEM-FS H03 0157
    Revision: AA000000 Serial number: 00000156770028
    Coding: 00581B0000006001000001010101102030303232203232
    VCID: 77ABEEE8EFCA4F53639-8022
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
    Component: SARA 6D red H04 0056
    Revision: -------- Serial number: EJ1BPA7E01N0GC
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_SARA2 005012
    ROD: EV_SARA2.rod
    VCID: 372B2EE8AFCA8F53A39-8062
    Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
    Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
    Component: SWA Master H06 0060
    Serial number: 0374160928
    Coding: 040211
    ASAM Dataset: EV_LaneChangAssis 001028
    ROD: EV_LaneChangAssis_AU21.rod
    VCID: 392F28D099DE992355D-806C
    Lane Change Assistant 2:
    Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
    Component: SWA Slave H06 0060
    Serial number: 0374285052
    Coding: 040211
    Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
    Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
    Component: TSG FA H04 0507
    Coding: 011F17015E00628002000013
    VCID: 45D75420E5A6EDC3215-8010
    Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
    Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
    Component: RCEPS H43 0012
    Revision: 00001000 Serial number: 0008795957
    Coding: 011001010001
    ASAM Dataset: EV_RCEPS 009013
    ROD: EV_RCEPS_009.rod
    Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
    Component: BCM2 2.0 H37 0572
    Revision: 00002001 Serial number: 0374181582
    Coding: 0106063A00FA418580B0080402070E47000000000000000000 0000000000
    Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
    Component: GTO BF H01 0081
    Serial number: 00000000000000300346
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
    Component: J245 PS40.402 H03 0004
    Serial number: 0000FST000ETD8S00000
    Coding: 101F02
    Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
    Component: GEB.F.Heckoef H16 0811
    Serial number: 93585890
    Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
    Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
    Component: TSG BF H03 0507
    Coding: 011F17015E00628002000002
    VCID: 46D5532CD8A0E6DB28F-8012
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
    Component: EPB-4 H04 0015
    Revision: -------- Serial number: 00000001534224
    ASAM Dataset: EV_ParkiBrake 001028
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 2D070C805D963583C95-8078
    Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
    Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
    Component: MxB-ECU 001 0100
    Coding: 04FA0A1122600400
    ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
    ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
    Led Headlamp Powermodule Left:
    Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
    Component: LED LeiMo li. H07 7560
    Coding: E01E00
    Led Headlamp Powermodule Right:
    Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
    Component: LED LeiMo re. H07 7560
    Coding: E01E00
    Address 5F: Information Electr. (J794) Labels:* None
    Part No SW: 4G1 035 025 K HW: 4G1 035 025
    Component: MU-H-LNS-US 042 0143
    Serial number: A278G0F7506662
    Coding: 017551020000000013220002041A00102F0007E5F1700104FE
    ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
    ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
    VCID: 2615F3AC786006DB08F-8072
    Data medium:
    Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
    Component: NAR 2017 --- 0057
    Serial number: --------------------
    Display unit 1 for multimedia system:
    Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
    Component: DU8 C7 SV H63 0006
    Serial number: AUZ8Z9FY802218
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
    Component: E380 BDT C7 H20 0250
    Serial number: 90349OGD000DQ
    Compact Disc Database:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote2 --- 3006
    1 Fault Found:
    0020 - Tuner for Satellite Radio
    B11CF 53 [009] - Deactivated
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 100696 km
    Date: 2020.06.10
    Time: 17:32:18
    Voltage terminal 30: 14.4 V
    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
    Satellite radio tuner status-Channel selection for satellite radio: 0
    Satellite radio tuner status-Audio Signal: Not available
    Satellite radio tuner status-Antenna current: 0 mA
    Satellite radio tuner status-Reception quality: Not available
    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
    Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
    Component: TSG HL H03 0507
    Coding: 010F17004000628002000002
    VCID: 49CF5810C9BE09A3C5D-801C
    Address 6C: Back-up Cam. (J928) Labels:* None
    Part No SW: 4H0 907 428 D HW: 7P6 907 441 F
    Component: TopView H07 0330
    Revision: 11001001 Serial number: 82330JF0240112
    Coding: 0212000101010000000102000000
    ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
    ROD: EV_CamerSysteTopViewAUDI.rod
    VCID: 2E050B8C50904E9BF0F-807A
    Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
    Component: TSG HR H03 0507
    Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
    Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
    Component: DPC-SG H27 0081
    Revision: -------- Serial number: 262130025421000
    Coding: EA060000
    ASAM Dataset: EV_OnBoardCamerDPC 001007
    ROD: EV_OnBoardCamerDPC.rod
    VCID: 2C010184668C3C8BDEB-8078
    1 Fault Found:
    0708 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [EGD_Fahrwerk_01_Signal_Error]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105180 km
    Date: 2020.10.10
    Time: 12:45:36
    Outside air temperature: -37.0 °C
    Voltage terminal 15: 14.2 V
    Control Module temperature: 50.0 °C
    Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 541 B HW: 4G0 907 541
    Coding: 7E01010102
    ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
    ROD: EV_AdaptCruisContr2AU57X_002.rod
    VCID: 270BFEA87F6A1FD3339-8072
    Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
    Part No SW: 4H0 907 107 H HW: 4H0 907 107
    Component: BV-SG H33 0090
    Serial number: 005000621407157
    Coding: 04C1BA1B0111
    ASAM Dataset: EV_BC7 001001
    ROD: EV_BC7.rod
    1 Fault Found:
    0091 - Function Limitation due to Missing Video Data
    C1108 00 [008] - -
    [DPC_SystemError]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105181 km
    Date: 2020.10.10
    Time: 12:45:37
    Outside air temperature: 25.5 °C
    Voltage terminal 15: 14.5 V
    Control Module temperature: 31.0 °C
    Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
    Component: RGS-VL H13 0080
    Coding: 0066E608031F0376070308014240C0010000
    ASAM Dataset: EV_RGS_L 002004
    ROD: EV_RGS_L_VW51.rod
    VCID: 313F10F041AE5163EDD-8064
    Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
    Component: RGS-VR H13 0080
    ASAM Dataset: EV_RGS_R 002004
    ROD: EV_RGS_R_VW51.rod
    VCID: 323D1FFC44A86A7B947-8066
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0010
    Serial number: 150615202158
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
    Part No SW: 4H0 907 145 B HW: 4H0 907 145
    Component: AEM - LEAR H10 0008
    Revision: 00001001 Serial number: 97813005428201
    ASAM Dataset: EV_AEMLearAU64X 002016
    ROD: EV_AEMLearAU64X.rod
    End----(Elapsed Time: 02:43, VBatt start/end: 12.2V/12.0V. VIgn 12.0V)-----
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    First place to start is the sensors.
    Sometimes the linkages break or otherwise fail.
    Coding: 008006
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105180 km
    Date: 2020.10.10
    Time: 12:45:35
    There are 4.
    Left Front Level Control System Sensor -G78-
    Right Front Level Control System Sensor -G289-
    Right Rear Level Control System Sensor -G77-
    Left Rear Level Control System Sensor -G76-
    I don't believe the code specifies which one(s) exactly are at fault, but off the top of my head I would log the sensor heights and maybe look at the one that does not change as the suspension is moved by you or a friend.
    Example:
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Apr 19 2020
    Omaha, Ne
    Okay, so I saved off my full scan and cleared logs. I will see if this come back. If it does I will attempt to capture output of each sensor. In the meantime I drove the car around, switched between drive modes; the car seemed to raise and lower just fine.
    To log each sensor, I go into Leveling control and what values do I want to log? Also should I just log the values and just switch drive modes or actually manually disconnect the leveling links and move the sensor arms?
    Thanks
    Aug 06 2014
    NJ->CO
    Yep your code does show it is "intermittent" but it might come back. In which case I lean more towards faulty sensor rather than just broken linkage arm.
    Kind of sucks cause they are not cheap.
    It's up to you how you want to test it. I don't know the values off the top of the head but they are all listed in VCDS in plain searchable text so you should have no trouble finding them.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Apr 19 2020
    Omaha, Ne
    To update this potential issue, I pulled the spare tire out and gained access to the battery and did a battery test on the vehicle. I used a TopDon-100 off Amazon. It checked out at 88% as was fine. I didn't know where the air distribution block was, but there it was right in the foam spare tire hardware kit holder. I went ahead and hit it with soapy water and didn't see any obvious leaks. I think I can rule out that area of the car.
    Question - should the car always be leveling when I open the door? I do notice that all 4 corners will drop down (Not slammed but maybe a half inch) even when I leave the car in Comfort mode overnight. When I open the door and BEFORE I start the engine it wont level up until after I start the car. Is this normal? I find it hard to believe that all 4 air struts are leaking at the same time.
    I did find some sensors to log in the leveling system module but wasn't sure they are the right ones. I'll post more info once I hook up VCDS again.
    Mar 30 2018
    long island
    Quote Originally Posted by T00fast View Post
    when i exit my car i can sometimes hear the suspension leveling, regardless of mode. other times i hear no self leveling. i think it depends how much stuff i have in the trunk or how many passengers exit the car....its all weight related.
    the car will not increase ride height when off. this is due to the compressors inability to run when the car is off.
    the code that would concern me is:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 105187 km
    Date: 2020.10.10
    Time: 12:53:44
    but as gk1 mentioned, the ride height sensors are a simple culprit to check.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Apr 07 2006
    Burlington, Ontario
    I don’t find my car leveling at all once I shut it down so that seems to be a concern I would get checked for sure
    2013 Audi S7: Audi exclusive interior, carbon fiber updates, RS7 rear bumper conversion, 20" PUR FL26 wheels
    Aug 06 2014
    NJ->CO
    If the suspension was leaking air the symptoms and fault codes should be different.
    Opening the rear doors or trunk tend to initiate some rear axle leveling procedures. I believe it is an attempt to compensate for a possible load change, or ease trunk loading access. Also if you usually drive around solo and then put some people in the back you can also see the message on the DIS that the car is self leveling once the car is running.
    Also (at least with my car) when the car is "sleeping" I have been in the garage working on other things and heard it re-adjust(vent) from time to time. I believe it is possibly temperature compensation but I do not know for sure.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Apr 19 2020
    Omaha, Ne
    Update and more info - I jacked up the front left of my s6 (I suspect this is the problematic area) unhooked the leveling sensor linkage to the control alarm and logged it. The sensor name was called Absolute Ride height or something like that. As I would move the arm back and forth the numbers in mm would go higher and lower but then change to something that didn't make sense. For example one side of the sensor would be 500mm and as I move it the other way it would go to 300 something mm which makes sense, but then back to a higher number. The range wasn't consistent.
    To further confirm its probably this sensor I cleared codes and did this again and the C1048 (mechanical failure came back) I'm hoping that moving the sensor arm back and forth in the full range it can go doesn't trigger a failure. Also what does c1048 mean? C for connector? Should be able to take this data and cross reference with the service manual i'd think. Searching my service manual finds nothing.
    I think I need a new sensor. Question are there any aftermarket ones that are worth a damn? This sensor is 300 bucks new. Looking for direction on the replacement part.
    Aug 06 2014
    NJ->CO
    C is just generic OBD designator for "chassis"
    B - Body
    C - Chassis
    P - Powertrain
    U - User
    Most codes in the service manual revolve around P codes.
    I think you found your culprit is the sensor though and now you just need to find a good price.
    The sensor p/n should be 4H0941285G Front Left dealer online = $334
    Ebay's got one for $37 it might be worth taking a flyer on even if it does not work...
    https://www.ebay.com/itm/28394353154...kcid=28&chn=ps
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Apr 19 2020
    Omaha, Ne
    I bought the 37 dollar sensor. Its worth a try. I've found the genuine one for 280 ish. The concept of this part is simple in theory... voltage is supplied, and signal voltage is modulated. I'll update this thread when I get the Chinese part in there.
    Apr 19 2020
    Omaha, Ne
    Got the sensor in, cleared codes and went for a drive. Lets see if this Chinese special keeps me code free. Fyi, this is what i bought:
    https://www.ebay.com/itm/Headlight-L...72.m2749.l2649
    Aug 06 2014
    NJ->CO
    Good luck, let us know.
    Audi probably has them made in china by that manufacturer anyway, they just tack on $75 per ring when it gets printed on the dealer part. LoL
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Apr 19 2020
    Omaha, Ne
    All, I am considering a re adaption after I put in this sensor. I just feel like setting were wrong from the get go. Found this Ross-Tech thread but dont see the default values for my s6:
    Is this process accurate and/or does the c 7.5 s6 share the values of any of these vehicles?
    https://forums.ross-tech.com/index.php?threads/12737/
    Aug 06 2014
    NJ->CO
    S6 should be the 2MB suspension.
    384 mm Front
    382 mm Rear
    (Confirmed by the repair manual as +-10mm too)
    I don't believe that changed for the C7.5
    I think it is really meant for when installing new suspension components. i.e you set the axle to those levels prior to tightening up all the bolts.
    If I were going to attempt it I'd make sure to save and write down everything.
    When I followed the similar procedure for lowering, the stored values were all over the place since presumably it was done correctly by the factory. Others also confirmed their starting values did no necessarily match others nor the service manual.
    These were my baseline heights...
    LF 400.7
    LR 395.1
    RF 390.7
    RR 378.3
    IMO if you got to the "start to reference level" then measure them all as equal then I might consider stopping since it sounds like nothing is wrong. If the one you replaced was wildly off then maybe proceed.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Feb 03 2016
    Cleveland
    Was the C1031 code resolved with the new height sensors?
