Results 1 to 19 of 19
    Junior Member Two Rings
    Sep 22 2020
    FL
    Where to buy battery with BEM code?
    I need a new battery, and none of the local parts stores have any with a BEM code. Where can I get one?
    2014 A6 3.0 - APR Stage 2 Dual Pulley
    2007 Q7 3.6
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    You don’t need to code the battery.
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by ticklechicken View Post
    Got mine at advance auto, if your new battery doesn't have one, just change the last digit on your current b to fool the system
    from my phone
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    Costco sells interstate batteries. Best price on the market, for a 36 month free replacement
    Senior Member Three Rings robocop47's Avatar
    Oct 21 2019
    Cincinnati, OH
    Quote Originally Posted by esimp2k View Post
    This is false
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Yes you absolutely need to code the battery.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Jun 17 2009
    Quote Originally Posted by GilliamOS View Post
    Absolutely you do not. Search here google it etc. it’s been discussed multiple times. The only possible and not even guaranteed downside is that it takes the ecu longer to recognize the new battery. That is all. And that’s only sometimes.
    Jun 17 2009
    Quote Originally Posted by robocop47 View Post
    This is false
    Actually it’s not. Search the forum and google it. Just takes longer to adapt. Have had 4 Audi’s. Never had an issue with not coding or adaptation after battery change.
    Sep 22 2020
    FL
    Quote Originally Posted by mintytoo View Post
    Based on your comment about changing the last digit, I assume the one you bought at Advance Auto doesn't have a BEM code. Correct?
    - - - Updated - - -
    Quote Originally Posted by 430hps4 View Post
    Are you saying they have a BEM code, or are you just telling me what type of batteries they sell at Costco?
    2007 Q7 3.6
    Active Member One Ring rflotea's Avatar
    Oct 09 2009
    usa
    [QUOTE=esimp2k;14310617]Actually it’s not. Search the forum and google it. Just takes longer to adapt. Have had 4 Audi’s. Never had an issue with not coding or adaptation after battery change.
    Agree.Same way.A4,A5,S5 and S8 never had issue without adaptation.( Only profit for stealrship).
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    - - - Updated - - -
    My battery from advance auto had bem code on a sticker. If your new battery doesn't have one, you can change the last digit
    from my phone
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    [QUOTE=rflotea;14311385]
    So I think the c7 has to have a change in the BEM code. I bought a s7 and the previous owner didn’t code it and replaced the battery. The battery kept dying faster. Had the battery checked and it was fine. I coded the bem and made sure the aH setting was right. No issues now. Pretty sure it resets a timer that tells the car how much to charge the battery.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Sep 01 2016
    Sacramento, Ca
    Carquest had one almost identical to the factory battery for a great price.
    Established Member Two Rings orphancrippler's Avatar
    Aug 01 2020
    2018 Nissan Rogue SL, 2016 Nissan Rogue SV
    Telford, Pennsylvania
    I bought a die hard AGM platinum from Advance Auto Parts, and the BEM code was hidden UNDER another Die Hard factory sticker, I think it may have been the like generic warning sticker about making sure you take the vent cap off or something similar.
    I initially didn't think it had one, and was disappointed as others had said theirs did, but it was there, just not immediately obvious. Interestingly enough, the one I got was 950CCA and 100Ah, but in the newer UDS modules in my/our C7 electronics systems, coupled with the newer VCDS interface for said modules doesn't allow for manual entry of the Ah rating. Even after putting in the BEM code, there are drop down boxes to select Ah, Brand and maybe one more, and the nearest options were 95Ah and 105Ah. I set it to 105, as choosing 95 resulted in weird, over-100% readings in the charge, health and other measurement values, and I didn't think that would be good for the car long-term. Choosing "Unknown" in the hopes it would reference the BEM code to get the proper Ah rating, even with a reset of the controller, just reverted it to whatever the last valid selection stored in the box was.
    I can't speak for all Die Hards, but I would think they're the same. Now that I'm thinking about it, the BEM code sticker was white and had a QR code on it, while the sticker that was covering it was a bit bigger and shiny black. Best of luck!
    Sent from my Galaxy S20 Ultra 5G
    2017 S6 DS1/SRT Custom ECU+TCU "Deathstroke the Terminator"
    SRM +4mm, HPA Street DPs, APR Catback w/X-pipe & 4" Tips, APR HX, MercRacing IC Core, SRM Short Intakes, AWE S-Flo V2, SRM Dual LPFP, Autotech Plungers, SRM FF Sensor + Engine Lines, 4 Bar MAP + Boost Sensors, TiAl WG Actuators, EMP Pump, JHM Oil Screen Kit, 034 Rear Swaybar/Endlinks/Drivetrain Inserts, SRM Driveshaft Carrier, iO2 CatSims, CF Spoiler + Mirrors, RS-Quattro Grille, Black Badging, CeramicPro Gold, 20mm R/17.5mm F Spacers
    Nov 04 2022
    NH
    Diehard Platinum AGM battery have BEM code which is covered by the warning label. That said, my 2011 Q5 didn't take the coding using VAGCOM...don't know why. Advance Auto Parts technical support couldn't help me.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    A good AZ thread with lots of information is " Battery replacement 4.0T (S6, S7, RS7)". My understanding is that coding a new battery is beneficial but not mandatory. The car will still start with an uncoded new battery (useful design for emergencies). The Audi literature implies that the Battery Control Module helps extend the life of a newly manufactured battery; the coding is how the control module becomes aware that the battery is newly manufactured. As others write, changing one digit on the prior BEM seems to work if the replacement non-OEM battery lacks a BEM.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    That's pertinent information.
    Thanks Alabama.
    Sent from my SM-N976V using Tapatalk
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    So technically any BEM code would work, so long as it doesn't match the last one? I'll generate and sell anybody a code for a In N Out combo. No cheating and googling BEM code though, alright?
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by WatchMeSpend View Post
    That's what folk report. Apparently the BEM code is equivalent to a unique serial number, not a VCDS "long coding" number. I'm assuming the chemistry of a newly manufactured battery changes with age, so the charging system adjusts during the early part of the battery's life expectancy. I read that there is no standard in how the car computer calculates battery life expectancy; each vehicle manufacturer has its own proprietary system.
