Results 1 to 17 of 17
    Sep 16 2020
    N/A
    Misshift Prevention (Manual gearbox)
    Is there any software available, which prevents misshifts? Something along the lines of detecting the selected manual gear and if the ensuing rev-match exceeds the redline, disallow the clutch from engaging?
    I just want to make sure I don't accidentally money shift my engine.
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Yes. Even in manual the car will shift up (dsg/auto)
    Edit... Manuals are manuals. They ain't gonna save you if you don't know how to drive.
    Sent from my Igloo.
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
    May 12 2017
    Do A4's rev-match? I thought it was an S4 thing.
    Jan 05 2019
    Ft Collins, CO
    It's been a minute since I've used my paddles but I don't recall there being any rev matching.
    2014 allroad
    Sep 16 2020
    N/A
    Just to clarify, I am asking for a manual
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    A manual transmission is manual. The clutch is controlled by your foot. How could software change a mechanical process?
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Sep 16 2020
    N/A
    Well, I was just guessing it could disengage the clutch for you if it sensed that the selected gear would result to the engine over-revving. That of course assumes that the clutch can be electronically operated, something which I am willing to guess is not a stock feature. So that brings me to the question; is there any hardware which could automatically operate the clutch for this instance? If yes, how complicated would it be to fit? If not (which is very likely), could it atleast notify that the ensuing gear change could cause damage? Furthermore, in the worst case scenario, if the gear is applied and the engine is over-spun could cut the fueling to bring down the revs as quickly as possible?
    Jun 30 2014
    West
    Automatic. Transmission.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Das Ponto View Post
    Yes. Even in manual the car will shift up.
    Sent from my Igloo.
    what are you smoking ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    This was before he clarified he was talking about a manual car.
    Sent from my Igloo.
    Ponto
    Feb 15 2016
    Cambridge,Ontario
    you are essentially asking is there anything that will teach me to drive without consequences....
    the technology exists and is its infancy due to lack of funding , and has not been truly developed , nor not been put into effect in production vehicles as we are moving away form the ICE to electrics .. so is a "non starter" as it were.
    it essentially uses solenoids to fire the valves instead of a mechanical linkage to the crank.
    modern gear boxes are very good ,, you would have to be a complete moron to do that on a modern car ... now my 915 gearbox in my 911, the possibility is VERY real.
    but on a related note humble mechanic has a great you tube video on a money shift with engine teardown .. it is pretty ugly, but very cool at the same time.
    1976 Yamaha XS 360
    May 12 2017
    Quote Originally Posted by Bror View Post
    I think you're over thinking this. The only time I see "money shift" being an issue is you're racing someone and you down shift while popping the clutch. That in itself is already a bad idea. Unless you're not paying attention, you could feel how much you fucked up when you're slowly releasing the clutch. You should always rev-match when down shifting anyway, in my personal opinion. That way if you happen to fuck up by downshifting too much, you have time to immediately engage the clutch.
    Jun 30 2014
    West
    So Bror - what is your plan here? Do you have a B8 with manual tranmission? Are you planning to track it?
    MPG 24city 31hwy
    Jan 11 2018
    1990 VW Corrado
    London, Ontario
    CO Motorsport on youtube has a video breaking down his MK3 16v turbo drag car, and he has a motorsport shifter that locks each gear out after you shift out of it.
    May 12 2017
    Quote Originally Posted by misiak View Post
    One thing that tripped me out with the Audi's, was how I could shift into reverse while the car is in motion. I never disengaged the clutch but I was able to shift it into reverse (was just curious if it was possible). I owned a TL-S a few years back and the reverse was all the way to the right instead of left like our cars. But there the reverse was locked unless you were stopped.
    Sep 16 2020
    N/A
    Quote Originally Posted by audrobotic View Post
    There isn't one really.I was asking because I have been thinking of purchasing an A4 Facelift with manual transmission (if all goes well and I do find one that is). I just sorta wanted to know if there was a system which would protect the gearbox in case I misshifted when doing a high rpm run (e.g. 0-100km/h) per se. This whole, which transmission to choose case, has been bothering me for a while now tbh. At first I started thinking the S-tronic was the optimal all-arounder. I still do think it is, hands down. However, when it comes to reliability and serviceability, I have heard quite a few horror stories of malfunctioning Mechatronics and steep service bills. Enough, as a matter of fact, to steer me away from the automatic bunch all together. The robust, easy-to-use and economic nature of the manual appealed to me. These qualities come a long way, especially in a vehicle which has miles on it. I am fairly confident that if I were to go for the S-tronic, sooner or later, the accumulated wear and tear would get the best of it. But what do you guys thing? Am I being too cautious maybe?
    Feb 15 2016
    Cambridge,Ontario
    the best advice i can give .. is give your brain a chance when you buy your car to adapt... after a while shifting will become second nature... dont buty it and try to rip 0-100 same day kind of thing...
    But your fear is real it can and does happen , can happen very quickly on the track ...
    1976 Yamaha XS 360
