Results 1 to 15 of 15
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    Best coilovers for the money?
    Got any recommendations on what are a good set of coilovers for the money? Lots of products, but the range is really wide. I prefer asking those in the know than pick and guess!
    Just looking to have good ride comfort, while having nice street performance. I'm just looking for OEM+ performance and reduce my tire-fender gap.
    Not looking to go crazy, $0-$1500 is my range.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Stasis ohlins
    Sent from my SM-G960U using Audizine Forum mobile app
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    H&R Street
    Established Member Two Rings onelowboi's Avatar
    May 31 2019
    bay area
    Solowerks - $550, 2.5" max drop, colored blue, fixed dampening
    ECS Coilovers - $600, 2.7" max drop, colored black shock bodies, silver springs, and red rings, adjustable dampening and preload, dampening is hard to adjust when installed
    BC Racing (known as "Stance Coils") - $1000, minimum 2 inches of drop with over 3" max drop, colored black shock bodies and springs, silver rings, adjustable dampening and preload, dampening is easy to reach, rebuildable
    HR Street Performance - $1300, 2.2" max drop, fixed dampening, colored silver shock bodies, red rings, and red springs
    These are gonna be your best bet options. I originally went with Solowerks because I found some for $300, but went with BC for the lowering. Also, Stasis is good, but I'm pretty sure they went bankrupt in 2013 and no longer produce, well, anything. Those are gonna be the main/well-known coils in that price range. I added in colors because the Solowerks blue really hurt my eyes to look at sometimes. I prefer the black OEM look.
    Mar 31 2008
    eS-4
    CAL*SO
    solowerks
    /thread
    Veteran Member Three Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    Nothing is wrong with springs from H&R or 034 w stock shocks. Lots of people go that route and are happy with drop and handling. Cheaper and without the coilover headaches.
    B8.5 S4 | B9 Q5 | IG: @dmzb8s4
    Jul 19 2017
    San Diego, CA
    Quote Originally Posted by ShelbyM3 View Post
    H&R Street
    Quote Originally Posted by dimonblr View Post
    I read that H&R has an issue where the rear installation isn't so good?
    May 31 2019
    bay area
    Quote Originally Posted by BucDan View Post
    Haven't seen any complaints with H&R coils before. If you install them correctly then they'll be good. Haven't seen complaints on H&R springs either unless I'm missing something.
    Springs are a cost-effective option too. The only thing I've ever seen that could be an issue with springs is that some companies don't make them stiff enough and will cause more scraping on bumps. Example, my friend with a MK7.5 GTI on springs is about 4.5 inches off the ground and would scrape on our canyon runs while I was about 3 inches off the ground on coilovers and didn't scrape. For springs, I would go with 034 as they tend to produce the best items and have more R&D invested in the B8 as they are Audi/VW specific. If you think you would want to adjust ride height in the future, coilovers would be a better option obviously.
    Feb 05 2007
    Portland, OR
    I installed my coilovers in 2015 in my garage. I had zero issues with the install in the rear and zero issues with the rear since then. That being said, I had to warranty the fronts within a month because they were both leaking onto my CV axles.
    Jan 16 2011
    Earth
    ohlins are the best and anyone that says different doesn't know what their talking about.
    Do it right or do it twice.
    https://ind-distribution.com/product...ion-road-track
    I suggested stasis ohlins is because a used set fully rebuilt runs about 1500-1800 and you can buy a second set to have when rebuild time comes. Spring rates thru hyperco can be had at any rate you want or eibach for standards rates. To dial in for your specific desires.
    Sent from my SM-G960U using Tapatalk
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by Audi 4 Life View Post
    $3k coilovers fkkkkkkk no
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by Fresh.S4 View Post
    Agreed. I would just go with air at that point (I'm biased because my car is already bagged to be fair). The only reason to spend $3k on coilovers is if you do track or autocross regularly imo
    2007 Porsche Cayman | 5MT
    Jul 19 2017
    San Diego, CA
    No way. That's too much. That's basically track/VIP style all in one. Was just looking for OEM+, not superstreet VIP.
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    For a non-track car, I’m very satisfied with Solowerks. 2 years and no issues.
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Jan 16 2011
    Earth
    I agree 3k is too much. Thats why I suggested stasis ohlins u can buy them for 1500-1800 fully rebuilt. Maybe less if your lucky.
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Solo are shit anyone who thinks their good has never had real suspension or doesn't know how a car should really feel.
    If you dont absolutly need adjustable height I would highly reccomend a good spring shock combo. Theres some good kits out there that are a great option for the cost.
