Results 1 to 8 of 8
    Established Member Two Rings darren p.'s Avatar
    Nov 30 2015
    Mk2 GTI VR6 B5 S4 Avant E90 M3s
    Rusted Flex Pipes
    Bought my car with 3" ASP catless down pipes and exhaust. The flex pipes were rusted and I had them replaced what will be 6 years ago come December. They are rusted to shit again and am wondering how normal this is and if anything can be done from preventing them from rusting through or just deal with it every 5 or so years? I understand the flex braiding is not full stainless but just looking to get some ideas/insight.
    Darren
    Veteran Member Three Rings harryn's Avatar
    Dec 03 2016
    2021 Audi A4, 2000 Audi S4, 1995 BMW M3
    Wrapping it can buy you extra time from rusting, or high heat enamel paint. Won't prevent rusting, but sure will take a long time.
    Veteran Member Three Rings ChanceA4Parks's Avatar
    Jan 22 2018
    Ridgeland, MS 39157
    "POR 15" makes really good rust prevention and rust neutralizing products.
    Sent from my SM-N976V using Audizine Forum mobile app
    Only owned 1 Audi so far.....It won't be my last!!!
    Built 2008 Audi RS4 with a 2.7t swap. JE Pistons (9.0:1 83mm)and Pauter Rods. 2.8 heads with Supertech Valvetrain (stock size) and RS4 Cams. TTE780+ turbos, RS6 Throttle Body, Snow Performance Stage 2 Meth Injection, and Motoza Tuned. The Tuner Inlets and intercooling piping. ID1000 Injectors and 034 Surge tank. Just use your imagination on everything else!!!
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I wouldn’t wrap them on a street car. It will retain moisture and make them rust quicker. Pulled wrap off a set before and underneath had rusted to the point where the downpipes broke into pieces.
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Would never use a wrap on a street car as mentioned sbove.....
    Not to sound like a smart-ass but have you tried a quality coupling
    Ie-- made of a 304 ST STL
    Sent from my SM-A505U using Tapatalk
    Nov 30 2015
    Quote Originally Posted by LJS View Post
    You must have a guilty conscious if you think that is being a smart ass
    Excuse my ignorance but I was under the assumption that the whole section gets changed, not just the braided sleeving around it? I'm not sure what exactly was used last time but I spoke to ASP and they were willing to repair it, they still have the jigs for them but I didn't want to drive all the way down to south jersey for that so just had a local shop do it. The pic you posted of the Vibrant is stainless? Sorry, its a bit blurry and can't make out all the text when I zoom in.
    POR 15 could be a good idea. I'm sure I'm not the only one to go through this or is it just most people garage and don't dd their cars? My car see snow and north east winters so if it is just something that needs to be done every so often, so be it.
    Apr 08 2013
    Connecticut
    Yes- the Vibrant unit is all stainless steel- 304 for the inner pipe(bellows) and braid, 409 for the welding rings(similar to the material of the OE exhaust)
    Here's a link to their site
    https://vibrantperformance.com/catal...346d9095ecae3e
    Nov 30 2015
    Thank you for this. Spoke to the shop that replaced it last time and they said they only use Vibrant so is it odd that they rusted out in 5 years?
