Results 1 to 17 of 17
Thread: Wheel Alignment
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Wheel Alignment
    Local Firestone shop has a wheel alignment special for
    $97.00 or lifetime $179.
    Does these Audi S7, need any special attention when doing a 4 wheel alignment?
    Firestone and Audi IDK.
    Sent from my SM-N976V using Tapatalk
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    Firestone didn’t want to touch my car recently after getting new tires installed (Firestone Indy 500). And not that I would trust them with a “performance” alignment anyway. I’d look for a specialized shop IMO who only does alignments. I paid $100 for mine.
    If in the Chicagoland area, Thalmann Alignments is the place to go.
    Established Member Two Rings Rsniper4's Avatar
    Nov 14 2016
    A while ago I went to get a budget alignment done on a B5 A4 at Brakes Plus.
    They were able to check the alignment, but were not able to make any adjustments. They mentioned that to adjust the front alignment, the front subframe /engine cradle had to be adjusted too, and that work was way beyond the ~ $100 service.
    I'm not sure how similar and old A4 is to a newer S7, but I imagine Audi wouldn't change to make things any easier.
    As eurospek suggested, your best bet would be to take it to a specialty shop for a proper alignment. In my experience, expect to pay at least $150.
    2001 A4 1.8T , 260,000 mi (resting)
    2014 A7 TDI
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Looking at my records, my A7 has not been aligned since 115,000 miles. I am now at 205,000 miles but there is no indication of any problems with alignment. Tires are at 60,000 and the wear pattern is damn near perfect.
    Eventually I will get it in to at least get checked but not any time soon.
    Mar 30 2018
    long island
    i have had my rs7 aligned 2x in 30k miles.
    dealer did it once because it was out of spec, after hitting a pothole and damaging a wheel. $200.
    i asked for them to do it while in dynamic (lower). they told me there is a special way they do it, and im guessing the "book" tells them what mode to have the car in.
    the second time was at a reputable shop, who did it at my request since i was getting new tires and wanted the alignment done while set to dynamic. $180.
    they had no issues doing it and got it back into spec when in dynamic.
    prior to the alignment, the car was in spec in comfort, but out of spec in dynamic. they showed me all 3 printouts: comfort and dynamic prior to alignment, and dynamic after alignment.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Dec 04 2015
    TN
    This is good info.
    Alignments and modes.
    I think Ima just hit audi up for the $160. W.A.
    I did repaiired 3 bent wheels and now just recently got new tires.
    Jun 05 2008
    Carmel, IN, USA
    I’ve used Firestone Lifetime Alignment on my S6 and prior cars. Great deal. In theory, you could mess something up that requires camera realignment I’m told.
    '14 S6 Prestige Phantom Black Pearl Effect/Black: Sport Rear Differential, Head-up Display, Night Vision, Driver Asst Pkg, Contour Seating, LED Headlights, Layered Aluminum/Blk Wood, Sunshades, Cold Weather Pkg, Rear Airbags, Side Tint, Auto Hold, Audi Platinum Protection 12/'21 96,912 mi
    ’13 Mercedes Benz E 550 4Matic
    '16 Honda Odyssey Touring Elite Obsidian Blue Pearl
    Sold: '05 A6 C6 3.2Q Stratos Blue Loaded
    Dec 04 2015
    TN
    Going Firestone route next week for the Alignment.
    Mar 14 2019
    Miami, FL
    Quote Originally Posted by schalliol View Post
    That!! If you have ACC there is a risk.
    Dec 04 2015
    TN
    This is pertinent information
    Dec 04 2015
    TN
    Mar 30 2018
    long island
    the ACC/alignment issue is usually only a problem if the alignment is way out of spec to start with. And typically it should only out of spec that far because of an incident (bad pothole/accident/hit curb) or major suspension component replacement. There is a good chance that any of these circumstances could cause a ACC error as well.
    When i had my alignment done in dynamic mode, the shop started telling me how it shouldn't be done that because of ACC....luckily i don't have ACC and we moved on from the topic.
    If I had ACC option, i still would have gotten the alignment. if the car came back with ACC error after alignment, i would schedule a visit to the dealer for ACC calibration only.
    Point is, dont let a shop or dealer charge you a flat rate for alignment including ACC calibration since it may not be necessary.
    Jun 05 2008
    Carmel, IN, USA
    Yeah, I've definitely done the Firestone alignment lots without any issue, but I wanted to make people aware of that possibility because the dealer said it could be a problem. Whenever my car goes into the dealer, they run an alignment check anyway…just don't fix anything if it's off.
    Nov 27 2018
    Valparaiso, IN
    Found this thread from 2017 about alignment.
    https://www.audizine.com/forum/showt...-for-alignment
    Aug 31 2016
    2013 S5 3.0T
    St. Louis, MO
    A note for anyone getting an alignment from non-dealer shops: make sure they use the correct specs for your car/options. Tire shop thought my car was out of spec, but i found they were using a standard A6 spec, not the sport suspension spec.
    All specs for all trims/options are listed in the repair manual. I can share if anyone needs it.
    Current: 2018 A6 3.0T, 2013 S5 3.0T
    Gone: 2013 A6 3.0T
    Jun 05 2008
    Carmel, IN, USA
    Quote Originally Posted by saadcee View Post
    I'd love to see it for a 14 S6 if you could share! Thanks!
    Feb 03 2016
    Cleveland
    I called a bunch of shops and even a reputable Audi tuner, no one was willing to touch it. Had to go the the dealer and 3 months later, need another alignment. Work order even said couldn’t finish, test drove and it was OK.
