Results 1 to 2 of 2
    Junior Member One Ring m.callihan's Avatar
    Sep 14 2019
    2009 A4 Cabrio S Line
    Pennsylvania
    B7 Cabrio Airbag light (01587)
    Hello all
    I was driving my 09 A4 Cabrio tonight and my airbag light came on randomly.
    Scanned the airbag module for codes and came up with this:
    01587 - Igniter 2 for Airbag; Drivers Side (N250): Upper Limit Exceeded
    Does anyone know what exactly this means, or a cause? Could it be a costly repair? I'm also afraid to clear the code for fear that it could cause the bag to deploy.
    I do not plan on tackling the issue myself, as I don't want to screw anything up, especially with an airbag, but any information is greatly appreciated!
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Quote Originally Posted by m.callihan View Post
    Hello all
    You won't blow up the airbag by clearing the code, it's ok! with that being said that code won't go away til whatever's wrong with it gets fixed.
    As far as fixing goes I've always left airbag issues up to the dealer, have you had the Takata airbag recall done yet?
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
