Originally Posted by
Spawne32
I have to ask, because this has been a big topic of debate, has anyone ever shown any evidence that it causes excessive wear like you are suggesting? I've been running it in various engines for a decade now and none of them show any signs of wear. I've even had some apart and the bearings were fine. T6 has been a huge name in oil for decades, I can't imagine why it would under perform.
The test showed far below average protection against wear, shearing to metal-to-metal at about 67,000 psi, whereas the top oils, including the Mobil 1 FS for VW502 00 exceed 125,000 psi.
The wear I saw in the 'Speed3" was primarily accelerated turbo center shaft wear. I went through three k04s before converting to a hybrid with a Garrett GT28 CHRA with better bearings. That is a known problem, anyway, with the K04 (and K03) because of the very tiny 5mm center shaft. The turbo spins at well over 100,000 rpm. The Mazda 2.3L turbo also had a strange pcv system that caused excessive oil pressure in the crankcase that affected oil flow to the turbo. We tried oil restrictors in the turbo oil inlet and other bandaids.
We all were chasing the detergent additives to help with the dirty carbon from direct injection and necessarily rich AFR, and not really thinking about oil shear. With hindsight, I think the T6 was not protecting the turbo center shaft. 30,000 miles or less per turbo was common. One only got me about 12,000 before bearing failure. Oil changes were religiously at 5,000 miles. We were pushing the turbos hard with 18-20 psi, pulling a lot harder to 6,700 redline. Stock maxed out at 14.5 psi and tapered sharply after 5,500 to protect the turbo. That is a lot of stress and heat. We also had premature wear on the cam tensioners and timing chains.
True, I never had any signs of engine bearing or cam lobe wear over 11 years and 150,000 miles. Compression remained high and oil consumption was negligible. T6 was hugely popular. With the benefit of hindsight, I do wonder if wear from oil film shear might have been due in part to choice of oil.
T6 has fallen out of favor in the 'Speed community. Most are now running Mobil 1 full synthetic or Pennzoil Ultra.
