Results 1 to 15 of 15
    Dec 29 2019
    Palmdale
    Gauge Cluster Lens Replacement
    Hey guys I’m stumped here. I have a 2015 Audi A4 S-Line and for some reason the lens developed kind of these bubbles in it. When it first happened I thought maybe when I was cleaning it something got behind the lens somehow. I removed the cluster and found that the foggy bubbles are in fact inside the lens like it delaminated. I have called everywhere and have had no luck trying to find a replacement I even called Audi and they only offer the entire cluster. I really don’t see a reason for a whole new cluster for just a simple lens. I have not found this issue anywhere on the web. I’m desperate for any help I can’t deal with this in my line of sight and I don’t want to buy a whole new cluster.
    Thank you for any help or advice.
    Veteran Member Three Rings Aris3.2's Avatar
    Mar 13 2020
    New Jersey
    There should be some cheap clusters on ebay.
    Try and buy one with a decent price and condition and then just polish the cluster lenses with Displex that small little thing does wonders, removes all the fade and any small surface scratches.
    Mar 13 2020
    New Jersey
    https://www.ebay.com/itm/203111343718
    Here’s what i found with a quick search pretty decent price and condition.
    Jul 16 2018
    Atlanta
    I don't know if it's a thing with complicated auto parts like the instrument cluster, but for audio and computers, you can often find "broken, selling for parts or fixer upper" type listings for dirt cheap.
    Dec 29 2019
    Palmdale
    Wow that is a good price. I usually try to avoid buying plastic stuff used but it’s looking like I don’t have a choice. Thank you
    Aug 24 2018
    Are you in Palmdale Cali?
    Dec 29 2019
    Palmdale
    Pretty close. I work in Palmdale, I’m about an hour north.
    Aug 24 2018
    I’m upgrading my gauge cluster to a higher resolution one shortly.
    You can have my old lens if you would like.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Can't replace the lenses its plastic welded.
    Buy a used one.
    Sent from my SM-G960U using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Aug 24 2018
    I can unbolt mine and pull it right off. It’s not just the lens that comes off, but easy to swap still
    Maybe prefacelift is welded?
    Quote Originally Posted by Audi 4 Life View Post
    Buy a used one.
    Jan 16 2011
    Earth
    Quote Originally Posted by PedroA4 View Post
    No they are all plasrtic welded I have a facelift cluster. I am talking about the peice you take off that clear lens has a plastic frame and its plastic welded and not removable from the frame, the only way is to take the whole cover from another cluster.
    Sent from my SM-G960U using Audizine Forum mobile app
    Aug 24 2018
    Ahhh. Now I understand what you’re saying. I’d agree with this, but to me is a mute point. Why not just swap the entire piece over?
    Jan 16 2011
    Earth
    Yes Thats what I said.
    Aug 24 2018
    Ha!! You sure did!!
    Sorry I wasn’t really ready this through!!
    Jan 16 2011
    Earth
    Accidental post
