I have a problem with fixing my friends Audi A4 b8 Avant Quattro 3.0tdi, it is having ABS, ESP, Tyre pressure and Parking brake malfunction.
I added list of fault codes, as it seems most of these are connected to each other, but I can not understand what is causing it.
It seems like CAN signal fault but at the same time I have heard it can be ABS ESP module itself that is causing problems like this.
Maybe there is someone smarter than me and can suggest the core of the problem
Diesel (CCWA - TDI-CR - MT/AT)
DTC Description
No fault codes
Brake (ABS/ESP - Bosch 8.1 ESP - MT/AT - With tyre pressure monitoring)
DTC Description
01317 - Combination instrument
- Check fault codes
- Permanent
00473 - Electromechanical parking brake control unit
- Check fault codes
- Permanent
03159 - Function, tyre pressure monitoring ESP
- No symptom
- Permanent
00287 - Rear right wheel speed sensor
- Circuit failure
- Permanent
Brake (Parking brake - EPB (Electric parking brake))
DTC Description
01316 - ABS control unit
- Check fault codes
- Permanent
Instrument (Instrument - Diagnose)
DTC Description
00457 - Control module network
- Check fault codes
- Permanent
Fault codes
Mechanic:
Date: 8.09.2020
Car licence no:
VIN: WAUZZZ8K89A132581
Mileage:
Vehicle: Audi - A4 [08-] - 2009
Delphi DS150E (New VCI) | 2014 Release 2 (2.14.2.2) 1
Climate (Climate control - Climatronic "Basic" (Mono zone heat regulation.))
DTC Description
- Check fault codes
- Permanent
01271 - Step motor temperature damper
- Above upper regulation limit threshold
- Intermittent
Gearbox (Gearbox - S-Tronic 0B5)
DTC Description
No fault codes
Immobiliser (Immobiliser - EZS (Kessy))
DTC Description
00956 - Key 2; adaption limit exceeded
- Below lower regulation limit threshold
- Permanent
02823 - Lock conditions electronic steering column lock
- No symptom
- Permanent
00955 - Key 1; adaption limit exceeded
- Intermittent
01330 - Convenience control unit
- Check fault codes
- Permanent
Restraints (Airbag - VW 10)
DTC Description
No fault codes
Multifunction (Central electronics - Diagnose)
DTC Description
00779 - Outside temperature sensor
- Circuit failure
- Permanent
Multifunction (Convenience system - Diagnose)
DTC Description
- Check fault codes
- Permanent
Delphi DS150E (New VCI) | 2014 Release 2 (2.14.2.2) 2
Multifunction (Door electronics - Driver door)
DTC Description
02122 - Memory button
- faulty signal
- Intermittent
Multifunction (Door electronics - Passenger door)
DTC Description
00920 - Mirror heating
- Circuit failure
- Permanent
Multifunction (Door electronics - Rear left door)
DTC Description
No fault codes
Multifunction (Door electronics - Rear right door)
DTC Description
No fault codes
Multifunction (Gateway - Diagnose)
DTC Description
No fault codes
Multifunction (Infotainment - DSP (Sound system))
DTC Description
02558 - Speaker left rear
- Open circuit
- Permanent
00417 - Front left mid/bass speaker
- Open circuit
- Intermittent
Multifunction (Infotainment - Media player position 1)
DTC Description
No fault codes
Multifunction (Infotainment - Navigation)
DTC Description
No fault codes
Delphi DS150E (New VCI) | 2014 Release 2 (2.14.2.2) 3
Multifunction (Infotainment - Radio)
DTC Description
No fault codes
Multifunction (Infotainment - Telephone)
DTC Description
No fault codes
Multifunction (Seat electronics - Seat module, driver)
DTC Description
02095 - Component protection active
- No symptom
- Intermittent
Multifunction (Steering wheel electronics - Diagnose)
DTC Description
- Check fault codes
- Permanent
