Results 1 to 31 of 31
    Aug 22 2020
    Dallas Tx
    Audi A6 3.0T white smoke / Oil lost
    Hello everyone I have a 2012 Audi A6 3.0T. over the last few day I have been trying to figure out the source of where the white smoke is coming from. The smoke is coming from the exhaust pipes and what looks to be the oil cap or spark plugs housing. along with some oil that looks to be from the oil cap, I also have a misfire on cylinder 2 with EPC light on
    The car on start up has no problem but after 5 second has a rough idle. The car will also vibrate between 1500-2800 RPM after will not smoke or vibrate unless the car drops below 2800 RPM. The car also has not lost any coolant and can drive highway spends with no problems.
    If keep the car in manual and shifts between 3000 and 4000 RPM the car drive like normal and will even pick up spends pretty fast
    The car has 138k miles
    APR Stage 2 dual pulley tune
    New harmonic engine balancer
    New manifold bank 1
    New spark plugs
    New ignition coils
    New water pump
    New thermostat
    New coolant pump
    New valve cover gaskets bank 1 and 2
    Things that we tried
    We did remove the fuel injectors clean them then swap them around to see if the misfire comes back on a different cylinder, but it was still on cylinder 2
    Replace the spark plugs again as they was only 1 month old
    And we swapped the ignition coils to see if any of them was bad and still the misfire is on cylinder 2.
    All cylinder have compression and only get the EPC light after 5-10 secs of the car has been started before the 5 or 10 sec cylinder 2 will not misfire from what I can feel.
    What I think is the problem
    After spends hours looking at what it could be I believe it's the PCV valve that is going out or is out as I do have to put oil in my car every 3 weeks or 4 weeks after getting a oil change,
    if you have any idea or recommendations please let me know as I am running out of options
    Sent from my SM-N975U using Audizine mobile app
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    If the oil cap is tough to remove, while engine is idling... PCV is your target
    Aug 22 2020
    Dallas Tx
    Quote Originally Posted by 430hps4 View Post
    Should I test this while the car is warm or can I test it on a cold start
    Sent from my SM-N975U using Audizine Forum mobile app
    Mar 11 2007
    Colorado Springs
    I think the car has to be warmed up so the pressure can build. You need to get this sorted quickly or you could negate some of the maintenance items you've ticked off.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Junior Member Two Rings
    Aug 28 2018
    Houston, TX
    Quote Originally Posted by xZUAx View Post
    when mine went bad it was tough to pull from a cold start and i had oil mixing with my coolant ...
    Aug 22 2020
    Dallas Tx
    Quote Originally Posted by trav-0 View Post
    Did you also have white smoke or a misfire?
    Aug 22 2020
    Dallas Tx
    Quote Originally Posted by A6sport View Post
    Will test and update post
    Oct 02 2005
    The Moon
    Having a cracked cylinder wall or piston rings can still give good compression numbers in some instances. Based off what you've done, short of serious carbon build up an engine sounds due.
    Aug 28 2018
    Houston, TX
    if it did it wasn't noticeable ... i was getting a low coolant light too ...after the replacement i got a P2753 code "Transmission fluid cooler control circuit open" its a simple fix
    Aug 22 2020
    Dallas Tx
    So if I remove the oil cap all the smoke starts to come out of the oil cap and no smoke comes from the exhaust.
    If I remove the vent hose no smoke comes from the oil cap nor the exhaust and it only comes out of the vent holes that leads to the PCV valve any thoughts???
    Mar 11 2007
    Colorado Springs
    If it were me, I'd be at the best Audi dealer in Texas, with the best Tech available.
    2012 A8L 4.2
    Aug 22 2020
    Dallas Tx
    Ya I fully understand that we are going to replace the PCV valve and see if anything changes as I only had the car for 14 months and put over 6k into the engine and if I take it to Audi that already quoting me $3200-$7500 so I'll just call the car a lost as I replaced almost everything under the hood at this point
    And plus Audi is telling me 2800 just to replace the PCV valve and gasket I can due my self for $190 like I been doing
    However I will post my update tomorrow when we pulled everything off the car again
    https://youtu.be/lx72qVvK7Mg
    The previous owner of this vehicle did not take care of it as we found wires slice and put together to avoid sensors being tripped and a lot of broken material under the hood that we also replaced.
    This was most likely my 1st and last audi I love German cars had 3 vw passat and never had a problem but it is insane all the problems I'm having with this car under 2 years start from the 2nd week of owning the vehicle. So if you're in the DFW area never buy and used Audi from Toyota of McKinney
    Mar 11 2007
    Colorado Springs
    If the PVC isn't the issue, let Audi diagnose and, get a second opinion... Hang in there once you figure this out, you're in for many miles of joyful motoring.
    These cars are solid.
    2012 A8L 4.2
    Aug 28 2018
    Houston, TX
    I see you're in Dallas... Hit up Zinkwerks... They are solid and won't try to rape you on the price
    Sent from my LG-H932 using Audizine Forum mobile app
    Oct 18 2016
    WA
    Trying to wrap my head around this, the thing that sticks out to me is where is the PCV picking up all of that burnt coolant that's coming out of the oil filler (or just the vent hose if you disconnect it)?
    Long live the Rhombus
    Aug 22 2020
    Dallas Tx
    Quote Originally Posted by bahula03 View Post
    The PCV valve has a pass-through for the coolant so for what I'm thinking the PCV valve handle three components oil separator coolant pass through and vent hose. But I have no coolant or oil mixture also in no way is the oil milky and the smoke does not smell sweet at all.
    Aug 22 2020
    Dallas Tx
    After replacing the PCV valve we now have a suction on the oil cap
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    White smoke is almost always burning coolant. Blueish smoke is burning oil.
    Get the cooling system pressure tested to see if you have a leak. Check the oil to make sure its still blackish and does not look like chocolate milk. If it looks like chocolate milk then you got coolant into the oil and need to dump that oil IMMEDIATELY and put fresh oil in. Coolant mixed into oil will likely kill the motor.
    Aug 22 2020
    Dallas Tx
    Quote Originally Posted by Valpo A7 View Post
    Just did an oil and coolant change yesterday and oil still looks blackish oil was change about 1k miles ago coolant was still pink with no oil or anything in it
    Aug 22 2020
    Dallas Tx
    So after changing the PCV we no longer have the smoke from the engine bay the car now idles rough between 500RPM -1500RPM
    We did an oil change and coolant change also at this time both was clean and clear. We did clean all injectors also and did a carbon clean up
    We also have alot more white smoke now and the car will drive normal above 1500 RPM in manual
    Nov 27 2018
    Valparaiso, IN
    If you still have white smoke I am still thinking you are burning coolant. Did you do a pressurized leak down test of the cooling system?
    Aug 22 2020
    Dallas Tx
    No coolant leak and doesn't smell sweet the smell Is more of a oil burning or gas can't pin point what the smell is but I'm leaning more to an oil smell then coolant and yes I did and the car holds coolant with no problem under pressure it goes down a little then soon as you release goes back to the same spot
    Aug 22 2020
    Dallas Tx
    Update took the spark plugs out and put a camera down the hole and this is what we found. This is a very bad carbon build up and don't know how we can clean it out with out removing the engine
    In the 3rd photos it worries me that cylinder 2 is bent. But hoping it carbon and now looking for a way to clean it to see more FullSizeR(1).jpgFullSizeR.jpgFullSizeR(2).jpg
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    In for updates. I hope a good cleaning is all you need. Might be worth doing the chemical treatment that marinates on the pistons overnight.
    Sent from my SM-N975U using Tapatalk
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Oct 18 2016
    WA
    Any resolution on this?
    Aug 22 2020
    Dallas Tx
    Dead cylinder audi said I need a new engine and quoted me 28k plus tax was coming out to $34128 so I bought a 2020 vw atlas
    Honestly my cylinder head warped and has a gap between the wall and the cylinder head causing it not to have compression so even if I get the engine rebuilt it was 5k-7K from someone else
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Sorry to hear that. I would probably have bought a used engine and modified it, but that's just me. I am also nowhere near as upset as you probably were.
    Aug 22 2020
    Dallas Tx
    Quote Originally Posted by WatchMeSpend View Post
    Yeah the decision was made out of anger and I wish I would have just spent the money I put down (5k) fixing the car but I realize that I had to start looking at options for my family as someone ran into this side of my wife's car and totaled and flipped her car so needed a family vehicle
    Nov 27 2018
    Valparaiso, IN
    A decent used engine starts about $4500 and then you also have to spend $3-5000 labor to swap it out
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Sorry this happened to you; please help me understand what might have been the cause so I can try to avoid. Apparently the previous owner neglected maintenance. I assume the carbon build-up is the primary cause of the cylinder failure. Besides using proper VW spec oil and doing oil changes more often than manufacturer recommendations, any other suggestions? Or do you think this was just random bad luck?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 22 2020
    Dallas Tx
    Quote Originally Posted by Alabama View Post
    I think I just had bad luck with this car since day one after buying the car the next day my sells person quite after 7-8 days owning the car the cat broke and was told by Toyota to just put after market parts on the car that then then fixed and they kept the car for 6 weeks trying to fix because they didn't want to pay audi to fix it. About a month or 2 later my Harmonic engine balancer went out (actually broke) and me and my pregnant wife had to put the car out of the road at 11pm at night on a 70mph highway after fixing that my Water pump and thermostat and the pipe in-between the block went out.
    So every month something new happened to the car so over all I just believe I got a bad car and was told by other audi owners they never seen an Audi have as many problem as my did and that the 3.0t and 3.2t was one of the best engines audi made that's why it was used so many times over the last 7-10 years.
    So I would say make sure you put fuel injectors cleaner in the car to help with carbon build up.
    Make sure if your burning oil fast to replace pcv
    If you are hard on your car and like to run it don't change your oil Evey 10k miles but every 5-7k
    These are beautiful cars and some times has to be looked after as kids so if you get a engine code fix it sooner then later just because it's drives fine does not mean to drive itSnapchat-1388911619.jpg
