Originally Posted by
WhereDaGold
Ok another thing I’m confused about is the differences for selecting different modes between b8 and b8.5. My b8 has the 3 options on the center console and two arrow buttons to choose between the modes. On my shifter, when in D, I can push it to the right (and it stays to the right) and at that point I can push it forward or back to upshift/downshift. I don’t even know if I can changes modes through the MMI
If you have the owners manual for your 2012 S4, you'll find the Audi Drive Select description and options on pages 122 and 123. If you don't have the manual, here's a copy and paste of the relevant text from a PDF copy (less the diagrams/pictures of the buttons, etc).
Introduction
Audi drive select provides the possibility to experience different types of vehicle settings in one vehicle. For instance, using the three COMFORT, AUTO and DYNAMIC modes, the driver can switch from a sporty to a comfortable driving mode with the press of a button.
Additionally, in vehicles with MMI*, the vehicle setup for INDIVIDUAL* mode can be customized by you. This makes it possible to combine settings such as a sporty engine tuning with light steering.
Description
The vehicle setup in each mode depends on the vehicle's features. However, the engine and servotronic are always affected. The automatic transmission*, dynamic steering* and adaptive dampers* are also adjustable.
Depending on the mode, the engine and automatic transmission* respond more quickly or in a more balanced manner to accelerator pedal movements.
The Servotronic (steering servo assistance) [see page 204] can also be adapted to driving situations.
Dynamic steering* changes the steering ratio as a function of the driving speed in order to optimize the driver's required steering effort. This sets the steering to be less sensitive at higher speeds in order to provide greater control over the vehicle. At reduced speeds, however, steering is more direct in order to keep the steering effort as minimal as possible when the driver is maneuvering the vehicle. At low and average speeds, dynamic steering additionally provides more responsive steering performance. The driver can set the basic steering ratio characteristics.
The adaptive dampers* use sensors to record information regarding steering movements, braking and acceleration operations by the driver, road surface, driving speed, and load. This makes it possible to adapt damping to the driving situation virtually in real time. Audi drive select also makes it possible to satisfy the desire for sporty suspension (DYNAMIC) and comfortable suspension (COMFORT) without giving up balanced tuning (AUTO). If your vehicle is equipped with dynamic steering*, servotronic can also be adjusted under the menu item Dyn. steering.
Selecting the driving mode
You can choose between COMFORT, AUTO, DYNAMICand INDIVIDUAL* modes. The control is located on the shift gate in vehicles with a radio, and in vehicles with MMI*, it is located in the center console.
- Turn on the ignition.
- Press the left or right arrow button until the desired mode appears in red.
You can change the driving mode when the vehicle is stationary or while driving . If traffic permits, after changing modes, briefly take
your foot off the accelerator pedal so that the recently selected mode is also activated for the engine and transmission.
COMFORT
The COMFORT mode provides a comfortable vehicle setting. The engine and automatic transmission* respond in a balanced manner when the accelerator pedal is pressed or released. Steering is light and indirect*, and adaptive dampers* provide a soft suspension. The setting is ideal for driving on long stretches, such as on freeways.
AUTO
Full use of AUTO provides a comfortable, yet dynamic feel. The setting is perfect for daily use.
DYNAMIC
DYNAMIC gives the vehicle a sporty feeling. The engine responds quickly to accelerator pedal movements, and steering is sporty and more direct. The adaptive dampers* are adjusted to provide a stiffer suspension and the automatic transmission* shifts at higher RPMs. The setting is ideal for sporty driving.
INDIVIDUAL*
You can adapt this mode to your personal needs in the MMI*.
Setting the Individual Mode (Applies to vehicles: with MMI and drive select)
You can personally specify the vehicle setup in the MMI.
Select: 'CAR' > Audi drive select individual. You need to select this control to drive in the recently set INDIVIDUAL mode. Note: Your INDIVIDUAL mode settings are auto-matically stored and assigned to the remote control key being used.
