Results 1 to 40 of 58
    Veteran Member Four Rings Chris.green's Avatar
    Aug 09 2017
    Atlantic Canada
    DIY: Front bumper removal & intercooler install
    I'm making this post to help out anyone in the future. Before taking on this job I looked around a lot for a proper walk through on how to remove the bumper and couldn't find one for the B9. It's a simple job if you have basic skills with hand tools and working on cars. Took me about 2 hours from start to finish which included taking pictures as I went and also swapping out the reflectors for colour matched ones.
    The whole job was done without having to jack up the car or remove the wheels.
    Step 1.
    Remove the hood latch and rad cover. The hood latch comes off by pressing a small button on the back side of it. The Rad cover comes off by just pulling up on it.
    Step 2.
    Remove the wheel arch trim. This was the most nerve wracking part for me because I had never done it, and wasn't sure exactly how they came off. All you have to do is simply pull straight out starting from the bottom. Once the first clip pops out just work your way up to about the 12 o'clock position. Take this slow as there is a possibility of breaking the clips.
    Step 3.
    Remove 4 T25 Torx screws in each wheel well.
    Step 4.
    Pull the fender liner back slightly and remove 1 T25 Torx screw and one push rivet. To remove the push rivet start with a small flat head screwdriver or a panel popper and work the rivet down until you can fit needle nose pliers in. Once you can just pull down and it'll pop out.
    Step 5.
    Remove 7 T25 Torx screws from under the car in the belly pan. Two are on the corner of the bumper and 5 in a line on the belly pan. You will also need to remove two T25 Torx screws on the top of the grill. I didn't get a picture of these but they are fairly obvious and connect the grill to the rad support.
    Step 6.
    I would suggest getting an old blanket and laying it out under the bumper at this time if you are doing this alone. If you have someone to help it would be easier. Pull out on the side on the bumper at the corner to release the tabs and then pull towards the front of the car. When I did this on the second side the bumper popped right off and dropped on the floor. Thats why I suggest having a blanket down or someone to hold the other side.
    Once the bumper is off disconnect two plugs on the drivers side.
    At this point the bumper is off!
    Step 7.
    Remove the plastic shields on either side on the radiator. I had to snip mine behind the AC connection because I couldn't see any other way of getting it out. They connect to the rad support with two clips.
    Step 8.
    Disconnect both charge pipes from either side of the intercooler. You then need to compress a clip on either side of the intercooler and pull the top forward to release it. Once it's released pull up and it will come out of its lower mounting tabs.
    From here the install of your new intercooler will vary from brand to brand. Once you have it installed put everything back together and enjoy.
    As a side note - if you are considering this as well as painted side markers do yourself a favour and do them at the same time. I have to give props to anyone that has done them without removing the bumper. Removing them was hard enough, but picking away all the tape would have been a nightmare if I didn't have a flat head screwdriver to help.
    Hope this post helps anyone thinking of doing this!
    2020 SQ5 | Glacier White Metallic
    BC Forged TD03 | CETE Lowering Module | Forge DV
    034 Transmission Insert | CTS Turbo Inlet
    AWE Coldfront | RocEuro Intake | 034 Strut brace
    IG: chrisssgreenwood
    Established Member Two Rings pjekar's Avatar
    Jul 17 2017
    2018 S7 Prestige
    Staten Island, NY
    Awesome post - thumbs up!!
    Established Member Two Rings SurfTek's Avatar
    Oct 18 2019
    Virginia
    Thanks Chris, this is great!
    2018 ▊ SQ5 - Prestige | Florett Metallic Silver
    Aug 17 2020
    Saint Louis, MO
    Fantastic writeup, I'll keep this bookmarked.
    2019 SQ5 - Daytona Grey - Prestige - S Package
    Senior Member Three Rings ADG05's Avatar
    Oct 17 2008
    Santa Monica CA
    Quote Originally Posted by SurfTek View Post
    Nice work and thanks for sharing with the fam.
    Side note: I replaced one reflector on my wifes Q5 without removing the bumper......To say it was one reflector too many would be a huge understatement. PITA!!!
    2021 SQ5 Daytona Gray | Instagram: @raudi_sq5
    Junior Member Two Rings
    Oct 19 2015
    GA
    Wish I had this last week. Perfect write up!
    Note for Step 6; I only had one plug. I’m assuming the other plug is for adaptive cruise control.
    Aug 09 2017
    Atlantic Canada
    Quote Originally Posted by Mynavi View Post
    Nope, I don’t have that. I think one is camera and one is parking sensors.
    Jan 09 2009
    1of50
    Great job Chris!
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    Thanks for the write up.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Awesome, I need to bite the bullet and get an I intercooler and try to take on the task of installing it myself. Appreciate the write up.
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Great write up. I'll have to bookmark this in case I decide to pick up an RS grille.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Sep 28 2010
    NW NC / DE
    Great thread buddy! 👏🏼
    Aug 09 2017
    Atlantic Canada
    Thanks everyone. Hopefully we can start to build a bit of a DIY/walkthrough guide for most mods
    Jul 07 2016
    Quote Originally Posted by Chris.green View Post
    Next we will need a turbo inlet write up once the Carbnlab ships. I watched the video for Johann back when I first ordered it and seemed relatively straight forward except maybe the bottom bolt.
    Sep 22 2011
    Western MA
    Nice work! Excellent write up and pics. Thank you!
    2020 SQ5 Ibis White
    2016 A3 Cabriolet Glacier White 2.0T
    2011 Q5 Ibis White 2.0T (sold)
    2008 A4 Cabriolet Ibis White 2.0TQ (sold)
    2000 A4 Laser Red 1.8TQM (sold)
    Jun 14 2012
    PDX
    Anyone done this on a Prestige Trim with Adaptive Cruise? The clips behind each radar sensor are giving me a bit of a hard time.
    Everything else so far easy easy thanks to Chris's write up.
    Aug 09 2017
    Atlantic Canada
    I was under the impression you didn’t need to unclip those connectors.
    I figured they would have a plug with the others on the driver side with the parking sensors and camera.
    Jun 14 2012
    PDX
    The driver side radar sensor really was a pitb but got this all wrapped up in just a few hours.
    Adhesive removal of factory reflectors was pretty time consuming. Have to give major props to anyone who does that install without bumper removal.
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Quote Originally Posted by subaruski View Post
    I'm going to attempt reflector install in the spring without removing the front bumper
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Aug 09 2017
    Atlantic Canada
    Quote Originally Posted by DiscoDan View Post
    For the time it takes just take the bumper off. Seriously, it comes off in 10-15min lol
    - - - Updated - - -
    Looks awesome dude!
    May 31 2010
    18 SQ5, 16 Q5 3.0T
    Missouri
    It’s long after you install, but in case anyone else has the same question:
    I ran into the same difficulty. As shown in your pic, clearance on the inside portion of the connector is very tight. On the first one, I didn’t sufficiently squeeze both of the tabs on the lower sides and ended up breaking off one one of the tabs. The second one went easier after I realized my mistake. I used two flat head screwdrivers to squeeze the outer tabs and somehow managed to pull down on the connector at the same time. There must be an easier method. Maybe using a small needle nose vise grip to squeeze the tabs and pull at the same time?
    I’m ordering a replacement connector to replace the one with a broken tab. $15 + shipping. Since the connectors seems to fit pretty tightly, I might not need to replace the damaged one, but would hate to leave a damaged one in place.
    Afterward, I also realized that I could have removed both of these connectors before removing the OEM grill. By removing the lower grills, you can access these connectors even with the bumper fully in place. Meaning that I can likely replace the damaged connector after I reinstall the bumper.
    Sep 19 2006
    Boston
    Great writeup! The thing that caught me off guard were the screws in the bottom of the fender flares. T15s?
    Quick question though? I installed the wagner setup and it sounds like I have a BOV now and the car is a little rough in lower RPMs. I thought I tightened everything well, but maybe something else came loose. Is there an easier way to access the side pipes without having to rip the whole front bumper off? Lol.
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    [/QUOTE]
    Step 7.
    this![/QUOTE]
    Hey Chris.. did you put this plastic shield back on after the Awe IC was installed? Also did you remove the crash bar to pull the stock IC?
    2019 Audi SQ5 Premium +: CETE module // Vorsteiner VFF-107 22x10.5 // AWE Cold Front // CTS Intake // CTS Turbo Inlet // 034 Trans Insert // AWE Touring Exhaust // 034 Swaybars
    2021 Audi SQ7 Prestige : 034 Lowering Links //
    AKA WantaA4
    Aug 09 2017
    Atlantic Canada
    Step 7.
    this![/QUOTE]
    Hey Chris.. did you put this plastic shield back on after the Awe IC was installed? Also did you remove the crash bar to pull the stock IC?[/QUOTE]
    Yes I put it back, but I had to trim it slightly to account for the IC brackets.
    I didn’t remove the crash bar, there was enough room to just pull out the stock one and slip the new one in.
    Mar 08 2007
    Ashburn Va
    Oh ok thanks… I figured it out. Didn’t trim anything cause I figured it was plastic and wouldn’t hurt anything. I did break the top clips on them when pulling them off but again.. I didn’t see that hurting anything when I put it back in place.
    AKA WantaA4
    Dec 16 2021
    Norman/Oklahoma
    Thank you for the helpful write-up. The brackets that came with my AWE FMIC for the B9 SQ5 are different than what is shown in the pic above. Did you make your own brackets?
    Aug 09 2017
    Atlantic Canada
    Quote Originally Posted by boyo71 View Post
    Nope that’s what came with it. Maybe they changed them
    Dec 16 2021
    Norman/Oklahoma
    Thanks for the quick response.
    Sep 28 2010
    NW NC / DE
    Much different... I've messaged AWE again, Taylor. 👍🏼
    Senior Member Three Rings J-Dog's Avatar
    Aug 10 2018
    Doylestown, PA
    Hey Chris… Just curious.
    Did you put that foam “bumper car” piece back on the crash bar when you did your IC install?
    Aug 09 2017
    Atlantic Canada
    Quote Originally Posted by J-Dog View Post
    Yep, you can’t see it behind the bumper cover unless you have a honeycomb grill
    Aug 10 2018
    Doylestown, PA
    Yeah… That piece is seriously easy to break. I ended up having to pull the crash bar to get my new IC in the car, and broke a few tabs off that POS. Not a big deal. It’s still hanging on!
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    Just performing the install this weekend of an APR IC on my '21 SQ5 Sportback Prestige. Only snafu was the front camera connectors (seen hanging down in the following install pics). I pulled off the front clip and found the camera wires preventing removal. I had to temporarily re-install the front clip, remove the camera surround panels on the front clip, then disconnect the connectors (two clips on either side of the camera connector), as well as removing two or three wire stays to allow the front clip removal.
    Install pics:
    Stock IC:
    Oh, and APR forgot to pack the APR MAF housing, so my SQ5 has been sitting in the garage.
    At least it didn't prevent me from re-assembling the front end, and installing the OEM black 4-rings grille badge and SQ5 grille badge. I left off the front camera surrounds so that I could adjust the IC clamps, if needed.
    The MAF Housing was shipped overnight, so I should be receiving it on Wednesday (7/6).
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, PB Pedal Tuner; AskCarbon Steering Wheel
    2021 SQ5 S/B Prestige - Daytona Gray/Black
    Senior Member Two Rings robb1887's Avatar
    Apr 24 2021
    Virginia
    Just posting a tidbit from my experience, I had one fastener on each side of the lower fender trim that screwed up into the bumper assembly that prevented just "pulling" them out. You may need to check your lower corners to confirm there is or is not a hard fastener. Otherwise installed as expected from the descriptions above.
    18 SQ5 Prestige
    EPL, ForgedOne, CETE
    Build Thread
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    Excellent write-up. I just used this DIY to install my IE FDS intercooler and it was incredibly helpful.
    Nov 22 2018
    Palm Beach Gardens, FL
    Quote Originally Posted by JonnyBravo! View Post
    Nice! How long did it take?
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    got the same one on backorder from ie. august 22nd can’t come soon enough
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Oct 26 2014
    California
    Quote Originally Posted by ccoop6 View Post
    About 2.5 hours. Most of that time was spent assembling/disassembling the front of the car. Intercooler was like 5 minutes.
    Quote Originally Posted by Gunnarrrrr View Post
    I had the same ETA, but they shipped mine out last week. Fit and finish is top notch. I'm very happy.
    Nov 22 2018
    Thanks! That’s what I figured. If I do the install, I’d knock out RS grill and fogs at the same time.
    Mar 25 2015
    Placer County
    I guess I spoke too soon. Got mine today! I’ve got an awe exhaust, 034 sways, and now this to do today, guess i’ll have to do some triaging.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
