Results 1 to 21 of 21
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Accidentally filled up with E85
    Hey guys, today I was planning to fill 3 gallons of E85 and the rest 91 octane like I normally do. I was talking to a friend and totally forgot, so I ended filling 13 gallons of E85 until the tank is full. Should I be concerned with any potential damages? or Can I just drive it normally until the E85 works it's way out? I plan to fill up with 91 gas on a daily basis to dilute the mixture slowly. Any other advice?
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill | Eurocode Sways | Eurocode Inserts | ECS TCU
    Mar 31 2008
    eS-4
    CAL*SO
    yea you'll be fine. you can get on it a lil to feel it lol but dont get crazy and you'll lean out pretty hard without a hpfp upgrade.
    every qtr tank just top off with 91.
    spend the money and get yourself at least an ethanol sensor so you can better control your fuel readings.
    im apr stg1/hpfp/stock pulley and i run the 100oct file with e40 as a daily
    Veteran Member Three Rings P1Racer's Avatar
    Nov 18 2014
    Santa Cruz,California
    Quote Originally Posted by AerotusX View Post
    You’ll be fine, just don’t go too far into boost to prevent leaning out and causing any harm. The engine has safety parameters to where it may throw you in limp mode to prevent and damage. Just restart the car and you’ll be fine. Just keep topping off with 91 until you can balance it out more.
    2011 S4, 034 DP ECU/TCU, AWE Inlet pipe, JHM 187mm Crank pulley, CTS 57mm Supercharger Pulley, AWE Touring Exhaust- 102mm, JHM V2 Test Pipes. @TommyLinebarger
    Mar 24 2014
    Thanks for the positive note, guys. My CEL did come on but the car is running fine on the way home. I commute 50 miles round trip for work, so I'll top it off with 91 each day.
    Jun 27 2018
    houston/tx
    Drain the fuel.
    Sent from my ONEPLUS A6013 using Tapatalk
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    Imo.i personally wouldnt drive it. Maybe if I can drain most of it out.
    we are the borg! resistance is futile.
    Apr 28 2019
    Baltimore,MD
    You prob got a CE light for fuel trims, as full E-85 will prob push the trims to the limit. How many gal did you put in? I'd prob top off with 91 asap.
    2014 S4 stage 2+ DP Revo HX
    Veteran Member Four Rings hunter_killer's Avatar
    Mar 25 2020
    Mandan, North Dakota
    I had did the same thing earlier this summer and got into it by about 4K rpms and got a CEL for too lean of conditions. I drove like a grandma until I topped it off with more 91 but weird thing is after that incident my back fuel level sensor got messed up and never read right afterwards.
    2013 Quartz Gray S6: APR Stage 1 and CTS intakes.
    Gone: 2013 S4 Stage 2. RIP.
    May 05 2018
    South Florida
    dont rape the car and youll be fine.
    Mar 24 2014
    I heard you can't siphon gas out the old way anymore. The only way is to drop the tank? Well, I'm going to take the chance and drive it out. I was able to refill with 3 gallons of 91 today. I'll report if I encounter any issue or damage. Wish me luck!
    Mar 24 2014
    Quote Originally Posted by hunter_killer View Post
    Is your fuel gauge reading way off and how do you know it's messed up?
    Apr 16 2017
    Illinois
    If you have an IE tune, I think they have a way to drain fuel.
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
    Mar 25 2020
    Well because my gauge doesn’t read right and I have a CEL for the rear fuel level sensor. Seems coincidental that it popped up right as I filled up with 91 from a nearly fully e85 tank.
    Mar 24 2014
    Ok, I see. Just scanned my codes and I only have lean codes for now.
    6208 - Fuel Trim; Bank 1 (Mult)
    P1128 00 [236] - System too Lean
    6212 - Fuel Trim; Bank 2 (Mult)
    P1130 00 [236] - System too Lean
    Mar 31 2008
    eS-4
    CAL*SO
    yup those are the codes for running too much ethanol. just keep dilluting it until you are putting in 3/4 tank of 91 then top off with e85. that should put you around e15-e20
    Established Member Two Rings 2013S4's Avatar
    May 20 2017
    NW Indiana
    I did that once also, just didn't it push it hard and keep diluting it when it got a few gallons down. No issues.
    Jul 31 2016
    PA
    You could drain a bunch out by using VCDS to run the LPFP under Engine control module, output tests. Disconnect the line that goes over the air intake, put some tygon tubing on the hard line into a suitable container, and run the pump to drain as much out as you want.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Mar 24 2014
    Quote Originally Posted by djn876 View Post
    Thanks for sharing this method. I will keep in mind for future needs. For now, I have replaced about half a tank with 91 so I think I will be fine as most of you said. The car runs great with no adverse effects. One observation I noticed is that E85 runs really clean. My stainless steel exhaust doesn't turn black even after a few days.
    Jul 31 2016
    PA
    Good to hear no issues, and yes, saving the polar bears one tank of ethanol at a time.
    Dec 09 2019
    Chicago
    Quote Originally Posted by Fresh.S4 View Post
    Why aren’t you using the e40 file instead of 100octane file if you have e40 in your rank ?
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by denokarter View Post
    i dont believe apr has an e40 file.
