Results 1 to 6 of 6
    Veteran Member Three Rings Discipulus's Avatar
    Sep 20 2016
    Portland, OR
    DIY - Secondary External Cabin Air Filter
    If you've ever removed the plastic rain guard behind the firewall you might notice a grill covering the intake of the blower fan for the cabin air/climate control system. It looks like this:
    Apparently in the Chinese market, this grill comes populated with an external Pre-Filter to help with smog and low quality air in that country. As far as I can tell, the part is only included in Audi's in the Chinese market, however the empty grill is on all Audi's. I searched around and found that the replacement filter for this is widely available in China, but very expensive here in the states. Thus, I ordered mine from Aliexpress.com.
    Audi Part Number: 8KD 819 441
    Link on Aliexpress: https://bit.ly/2RvK9u9
    I have not yet received mine, because shipping from China takes a month. I'll update this post with more pictures and details once I get mine installed. I just wanted to get this up sooner rather than later to help out some folks who might want to breathe better air during this awful dusty smokey fire season here on the West Coast =)
    References and credits:
    S4 DIY Guide - https://www.audizine.com/forum/showt...bin-air-filter
    More random info - https://www.audizine.com/forum/showt...ter-discovered
    Q5 additional info - https://www.audizine.com/forum/showt...Filter-Install
    Update - based on the above links provided by @bakedziti it looks like this has been well covered in other posts! No need to reinvent the wheel here, the above links should provide sufficient DIY guide info.
    APR Stage 2 DP | JHM 207mm Crank | JHM HX | EPL TCU | JHM Race Pipes | JHM High-Flow Cats | Euro-Spec SQ5 Springs | Bilstein B8 Shocks | 034 Motor Mounts | ECS Drivetrain Inserts | ECS Aluminum Cross Brace | AFE Pro Dry air filter | 034 Silicone Intake Tube | 034 RSB | TRW metal endlinks | ECS Stainless Brake Lines | RSNAV S3
    2015 Q5 3.0T - Current
    2011 A4 6MT - Sold
    Junior Member Two Rings
    Apr 08 2020
    Springfield, Oregon
    Excellent post m8. Was just looking into something like this for the sq5. The smoke here has been so dense for a week now...ordering asap myself. Thanks!
    Sent from my SM-N976V using Audizine Forum mobile app
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Sep 20 2016
    Portland, OR
    Excellent search skills! I also came across at least one of these but nothing as extensive as you found. Thanks for sending these - I suppose no need to create a DIY with this much info already readily available. Updated initial post with your links.
    2011 A4 6MT - Sold
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    The non carbon filter is available on amazon and it will arrive in a couple days
    https://www.amazon.com/dp/B084Z584BQ..._axGyFbZE2KA5E
    2011 A4 Avant Prestige S-Line
    Sep 20 2016
    Portland, OR
    Quote Originally Posted by Novarider View Post
    Nice find! That's definitely faster than shipping from China =).
    Sent from my Pixel 3 using Audizine Forum mobile app
    2011 A4 6MT - Sold
