Results 1 to 17 of 17
    Established Member Two Rings kdubaudi's Avatar
    Feb 10 2006
    PA/Jersey
    Pinch weld jack pad
    Does anybody make a pinch weld jack pad that actually works? I tried one off Amazon and also the Schwaben Jack pad from ECS tuning.
    here are the results:
    Amazon generic:
    The generic Amazon one is getting cut through and split in half seems too soft.... undercoat protection ripping off the pinch weld.
    Here is the Schwaben:
    As you can see the pad seems soft and is folding up in my pinch weld still looks abused.
    Is this what I should expect or is there something better?
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    I just recommend getting out an oscillating tool and make a slit yourself on a hockey puck
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    Quote Originally Posted by arjun90 View Post
    Hockey puck FTW
    Sent from my SM-G960U using Tapatalk
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
    Feb 10 2006
    PA/Jersey
    Thanks...guess a hockey puck it is!
    Jul 31 2016
    PA
    I just fold up a towel on the jack, never been an issue.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    I have a few of these and will never need to use a hockey puck again. cheap and havent failed me yet. They are magnetic so i just stick it on the pinch weld and then set my jack underneath. There are different depths you can purchase so just measure.
    https://www.amazon.com/POTAUTO-Unive...s%2C223&sr=8-5
    Feb 10 2006
    PA/Jersey
    Quote Originally Posted by apatchin View Post
    This looks perfect...thanks for posting! About to click buy!
    Established Member Two Rings DustinFennell's Avatar
    Dec 05 2013
    2019 Ram Truck
    Mesa, AZ
    Those are the ones I have from Amazon and they worked great!
    2022 Q5 - Chronos Gray w/Black Interior, Black Optics
    2022 Q8 - SOLD
    2020 SQ5 - SOLD
    2014 SQ5 - SOLD
    Established Member Two Rings DUBDAWG's Avatar
    Aug 18 2017
    SQ5, IV Jetta 2.Slow, Polaris RZR, Yamaha Viper
    Syracuse New York
    This is great. I have used the ones from ECS as well, they have totally failed and or banged up my car. I'm done with those but would give this alternative a try.
    Sent from my SM-G975U using Audizine mobile app
    Established Member Two Rings 49Willys's Avatar
    May 22 2015
    Lake Stevens , WA
    I have the ones from Quick Jack and no problems https://www.quickjack.com/media/cata...et-5300013.jpg
    Mine 15 SQ5 Seapang blue Black optics
    Hers 08 A4 S-line Ti 3.2 trip
    Gone
    06 S4 25 Quattro(oil consumption)
    08 A5 S line 3.2 mt total loss water damage
    Sep 11 2015
    Western Mass
    What was the depth measurement you found worked for our cars ?
    Feb 10 2006
    PA/Jersey
    My pinch weld measured slightly thinner than 14mm so I ordered the 0.55" version.
    May 28 2008
    PDX/DEN
    exact one i purchased
    May 28 2008
    PDX/DEN
    Quote Originally Posted by Rbb1485 View Post
    that was my bad, i meant width. And i purchased the .55"
    Jul 31 2020
    2014 Ford Fiesta SE and 2017 Honda Civic LX
    Phoenix AZ
    In case anyone wants to know, the .39 width fits my 2014 Q5 just fine. It unfortunately is not wide enough for my wife’s Civic and the .55 is back ordered for a few months. 🤦*♂️
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    https://www.amazon.com/TMB-Motorspor...1328830&sr=8-8
    I use these. I cut the slot a bit wider with a hacksaw, to accommodate the wider pinchweld of VWs and Audis.
    Jul 31 2020
    Phoenix AZ
    Quote Originally Posted by pdnation View Post
    I am amazed at the holding power of the magnets. I completed the 75k MX 2 weeks ago. I have 1000 miles on since then. I walked up to the car from the passenger side last night and noticed something under the right side. It was the Jack pad still on the pinch weld. Apparently, I forgot to take it off 2 weeks ago.
