Results 1 to 6 of 6
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Thule AeroBlade Edge removal
    I have Thule AeroBlade on my allroad but will never use it. Attempting to remove it and looked at the instructions. I see on step 7 there is a rubber strap you pull around. Currently, I've unlocked the plastic cover and pulled it off. What is the best way to remove the rubber strap on step 7?
    Thanks
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Jan 05 2019
    Ft Collins, CO
    Can't see what instructions you're referring to. Anyways it looks like there are two allen head bolts in the middle of the foot. Also appears to be a bolt in that round cavity. Just loosen everything until it comes off. You may need to pull up that rubber strip covering the T Track for better access.
    2014 allroad
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by COar View Post
    Apologies, here is the manual https://images.carid.com/thule/base-...structions.pdf. there is also no bolt in the big hole.
    2007 Toyota corolla
    Jan 05 2019
    Ft Collins, CO
    Ok doesn't look that strap requires any tools to install. Push on it then pull up. A flat head screwdriver (or similar) may be needed to help pry it up. Then for removing the actual feet, hopefully you have the Thule wrench, because a lot (if not all) of these racks require special 'security' bits.
    2014 allroad
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    You need AcuTight Tensioning Tool to install/remove it. Guess the previous owner didnt give it to you.
    part #is 1500052318
    B6 Noggy Avant, B8.5 Allroad
    Dec 04 2019
    West Chester, PA
    Yup thats right hkdolphins. Can't believe some people are asking > $40 for this screw driver. Guess I'll have to buy it. Found one on for $17CAD, hopefully they ship to the U.S.
    2007 Toyota corolla
