I have recently installed a short list of additional mods and done some recent maintenance, See these below:
MODS
- 196.5mm Crank Pulley
- Autotech HPFP Mod
- CWA100 Aux Water Pump
- Ported Blower
- Replaced 74.5mm Iabed Throttle body that started whistling after porting (just bought same throttle body from Bosch)
Maintenance Items
- Valve Carbon Cleaning
- PCV Replaced
- Fluid Changes
After doing all this at once my car is having some trouble idling. I am getting some codes, but the Carista I have is giving me codes but nothing comes up after searching for them on Google, thinking Carista sucks. Check engine light is on:
Immediately after startup the car revs way higher than usual. It revs up to about 1850 RPMs and then drops down to 400 RPMs and stutters then revs back up to about 1850 again. This process repeats itself for a while and then it will eventually settle down to revving between 1600 and 1800 bouncing between the two at about 2 second intervals.
My immediate thoughts are that it isn't ready for a new throttle body, maybe it needs to be adapted via VCDS, this is in the works for someone to come up and help with that this weekend. My other thoughts is, maybe APR Stage 2 isn't ready for all this and doesn't know what to do with the extra airflow through the blower. I have been stage 2 for a year or so, and have had the bigger throttle body on with no problems, didn't need to adapt to anything that time. So Could the larger pulley ratio and Ported blower or even the fuel pump be throwing off the tune and it is just trying to balance itself using larger amounts of air or fuel?
I know without the codes it's sort of difficult to diagnose, but if someone has run into this, I could use the experience. I have not driven it in it's current state, so I couldn't tell you how it performs on the road.
As a side note, we just upgraded the SQ5 to IE Stage 2 Dual Pulley and I can tell you, stage 2 DP from IE feels way faster than APR 2 DP. That thing rips. Now that we have the cable already I am contemplating switching to IE and getting a tune that is set up for all the mods. I think I have everything listed in my signature if you want to look, but the gist of it is in this post.
Thanks for reading,
Kyle
