Results 1 to 30 of 30
    Established Member Two Rings walsh's Avatar
    Jul 15 2013
    2019 Audi RS5 | 2004 VW R32
    Denver
    Intake & Turbo Inlet Compatibility
    Title pretty much says it although I’m particularly interested in what turbo inlets people are currently running with the eventuri intakes. As a rule of thumb if it’s a 4” turbo inlet and the intake has a 4” pipe you can probably get a universal coupler and run the two together. I’m just curious to see who is actually running what setups, if they’re working well or not, and any particular notes for that setup regarding install, etc.
    Jan 24 2015
    Australia
    Forge 3.5” + forge 3.5” hardpipe
    I’ve seen plenty of 700hp builds with this combo and stock airbox, sure you could argue there’s 10-20 or so hp left on the table, but would you even feel it at that power level vs stock
    I’ve had eventuri intakes on my past builds, but I can’t really justify the price this time round, it’s more than half way to a tte700
    I’m also not a fan of the ricer turbo whoosh sounds from an intake on this car getting off throttle - my f80 m3 didn’t have a bov or dv, so it was just all spool with the eventuri
    Apr 04 2012
    2019 RS3 Ara Blu
    I've ordered a 4 inch coupler to mate the cts 4 inch intake to my UNI 4 inch inlet. Currently It has the 3 inch intake with a reverse coupler from 4 to 3.
    Unitronic 1+ ECU/TCU: Tyrolsport Deadset Subframe locking kit: ECE Rear Motor Mount : Unitronic 4 inch turbo Inlet : APR Ignition Coils : VTT Silicone Charge Pipes : NGK Race Plugs : Whiteline Rear Sway Bar : 034 Motorsports mid-pipes : 034 Open Carbon Intake System : CTS Intercooler : 20% Suntek Ceramic Tint
    Junior Member One Ring
    Sep 29 2018
    Quote Originally Posted by allerum View Post
    Keep me posted on how this install goes. I currently have the 4" CTS intake and I'm hoping to get a 4" Unitronic Turbo Inlet soon.
    Feb 02 2020
    '19 RS3, '17 Tundra, '16 3 GT, '19 Polaris Scrambler 850
    Milwaukee, WI
    Quote Originally Posted by Dirty_Erdy View Post
    X2. Doing the exact same thing...
    Current: '23 GR Corolla, '19 RS3, '17 Tundra, '16 3 GT
    Past: '13 Evo X, '12 Mustang GT, '08 Civic Si, '03 Evo VIII, '01 Golf 1.8T, '84 Chevrolet Cavalier
    Junior Member Two Rings
    Aug 23 2019
    2018 Panther Black RS3
    Vancouver/BC
    Quote Originally Posted by bucolic View Post
    Just wondering how come you guys didn't go with the CTS 4" inlet which should be direct fit. Or go with both uni inlet and intake?
    2018 Panther Black RS3, Uni Stage 2 93 files. CTS intercooler, CTS Turbo Downpipe, Uni mids, stock airbox mod w/ K&N filter, NGK Plugs.
    Sep 29 2018
    Quote Originally Posted by Fear37 View Post
    The Uni elbow has adapters you can buy to accomodate the popular hybrid turbo options. The CTS one does not appear to have that option at the moment.
    Sent from my Pixel 3 using Tapatalk
    Feb 02 2020
    Milwaukee, WI
    I had the CTS 4" turbo inlet pipe but sold it when I decided that the 4" Uni turbo inlet design/build quality seems superior. It's important to me since the OEM turbo inlet seems to be one of the most restrictive parts when doing bolt on mods...
    Aug 23 2019
    Vancouver/BC
    Make sense, thanks
    Apr 08 2014
    What do I need to get the 4” unitronic inlet to match with my 4” CTS intake? I don’t feel like trying to sell my 4” CTS intake for a Unitronic intake. But I am set on the unitronic inlet for sure
    Sep 29 2018
    Quote Originally Posted by CdnaudiS4 View Post
    CTS sells a 4" straight piece of silicone hose for this exact purpose. You will have to cut it to the correct length though. I haven't done it yet and I'm interested if there are any fit up problems.
    Also, does anyone have a solution to the CTS intake fouling the electrical connector mounted under the cowl??? I know the IE intake has a relocating bracket included with their kit.
    Oct 31 2016
    Boston, MA
    I am also interested if anyone has experience with OP’s original question, does the 4” Eventuri intake mate up to a 4” inlet with just a silicon coupler? Does anyone run this combo? I like Uni’s inlet design a bit better than the Eventuri carbon inlet, I’d guess that metal does a bit better longevity wise than 2mm thick carbon fiber.
    Apr 04 2012
    2019 RS3 Ara Blu
    So to make the CTS intake work with the Uni 4 inch inlet you do need to have a straight coupler that's about 6 inches. This tilts the other end of the pipe downwards that does not fit that giant filter they supplied. So I had to use the smaller CTS intake's filter which is fat and short and not as long as the other one. This all fits up and nothing is banging. But the metal pipe is close to the box so I had to scoot it up on the screw to stop it touching. Currently it fits including the top added so its a more closed box.
    Apr 25 2020
    WV
    I've currently got an open APR intake/inlet setup, but this was thrown together long before stage 3 plans. What is my best bet at this point? The heatsoak is real, and I'm looking for the most beneficial closed setup. Would the 4" APR turbo inlet need to be replaced, or would there be compatibility with other intakes?
    Apr 08 2014
    It has been about 6 months now. Have you or anyone used the silicone coupler to match the 4" Uni inlet to their 4" CTS intake? I'm about to place an order for the Unit inlet but wanted to make sure it 100% will fit.
    Oct 22 2020
    Texas
    Not sure if this helps, but I’m currently running a Unitronic 4 inch turbo inlet, with the apr 4 inch intake
    Apr 08 2014
    Quote Originally Posted by VirtuousWolf View Post
    Was it as simple as just using a coupler? Uni intake IMO was just way too expensive just for an intake so I went with the CTS one haha.
    Jun 24 2019
    Atlanta Region
    Unitronic 3" turbo inlet wastegate line question
    For those with the Unitronic 3" or 4" turbo inlet what did you do about the wastegate line? I have the 3" installed but wasn't able to attach the bracket on stock wastegate line to back side of the inlet without putting too much stress on the short rubber line connecting to the wastegate. The metal part of this line is currently making contact with back and top sides of the inlet. Does the Unitronic upgraded wastegate line replace the entire stock metal/rubber line or do you replace each rubber section individually? If replaced entirely how did you route/secure it. Pics below.
    2018 RS 3 | Uni Stg1 ECU Stg2 TCU | Uni Mid Pipes | Uni 4" Turbo Elbow | APR 4" Intake | 034 Heat Shield | ECS/034 Dogbone Mount | 034 DSG Catch Can| VTT Charge Pipes | 034 Lowering Springs | Bronze 034 ZTF-01 Wheels 245/40/18 PS4S
    Oct 29 2018
    San Francisco, CA
    The Unitronic upgraded line replaces the entire line from the wastegate all the way to the opposite side of the cylinder head.
    Veteran Member Three Rings 0000 RS5's Avatar
    Jul 13 2015
    Quote Originally Posted by JustASix View Post
    The upgraded line is required for the 4”, I believe. The 3” can reuse the stock. Mine fit on my 3” Uni turbo inlet.
    Jan 13 2021
    Winnipeg
    I just finished the install and the wastegate line sits on top of the inlet. It is raised, there are 2 rubber sections that keep it up a bit higher. There is some stress, but it did fit pretty well.
    I do have the 3 inch inlet and a coupler from 3 to 4 inch to connect to my 4 inch CTS Turbo intake.
    2018 RS3 - Glacier White - JDY NG6670 Build in Progress - IMS Charge pipe/BOV kit, Syvecs Haldex Controller, Uni Dogbone, 034 rear subframe inserts, Catch cans (Iroz engine, 034 DSG), Neuspeed lowering springs & 2 piece front rotors.
    2007 Gallardo Spyder - Eurocharged ECU/TCU Tune, LOC REV5 exhaust
    1993 Mustang LX - GT40 Tubular upper / lower intake, BBK shorties & H pipe, Dynomax catback, Steeda Tri-Ax
    Sep 12 2020
    SC
    I have the CTS 4" intake and 4" unitronic inlet. fits perfectly fine, 4" circle is a 4" circle no matter who makes it.
    I used the 4" coupler that came with the CTS intake, didnt need to cut it at all.
    Use the silicone wastegate line from the unitronic inlet kit.
    FWIW, the APR 4" inlet looks to be a better investment. I really like how it has the heat shield. seems to be a much better design/engineered piece and comes with a more robust wastegate line.
    Established Member Two Rings RSpeeds's Avatar
    Nov 04 2019
    2020 BMW X3M
    Quote Originally Posted by Arelax View Post
    When I installed mine initially it was fine as well. After a few hundred miles it settled along the firewall and started rubbing. I bought the ECS coupler linked below and it moved the pipe far enough away from the firewall to stop the rubbing.
    https://www.ecstuning.com/b-ecs-part.../006669la01~a/
    2020 X3M | 11.0 @ 128mph | MHD Stage 2 E30 Tune |
    2019 Audi TTRS | 10.55 @ 130mph E63 | Neuspeed RSe102 | PS4S Tires | DS1 | CTS 4 Inch Intake | CTS 4 Inch Inlet | CTS Turbo Outlet | SRM Ethanol Sensor Kit | Iroz Downpipe and Midpipes | ECE Dogbone | 980cc Injectors | 18 Inch Hoosier DR2's | IROZ 800hp Intercooler |
    Sep 12 2020
    SC
    Quote Originally Posted by RSpeeds View Post
    When I installed my initially it was fine as well. After a few hundred miles it settled along the firewall and started rubbing. I bought the ECS coupler linked below and it moved the pipe far enough away from the firewall to stop the rubbing.
    mine currently only rubs against that bracket holding 2 electrical plugs on the firewall. i put a piece of rubber between the intake and that bracket, I can't see it being an issue but ill take another look. Thanks for the advice!
    Jun 24 2019
    Atlanta Region
    For those that have installed the Uni or any 4" inlet for that matter, what tool or setup of tools did you use to access the inlet bolts? My car currently has the Uni 3" inlet which I was able to do with my current tool setup but I underestimated the size increase on the inlet near the flange. Didn't need to remove the charge pipe for the 3" install. I attempted to install the uni 4" last night but didn't have any combination of torx bits, sockets, or drivers that would work. Any input is appreciated.
    Also there isn't a different length 4" coupler required to put an 4" APR intake on a 4" Uni inlet is there?
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    Quote Originally Posted by xiaphin View Post
    I recently installed an Eventuri 4" Carbon Fiber inlet to an AWE 4.5" Carbon Fiber CAI. For me, I actually went underneath the car and removed the turbo outlet pipe going to the intercooler to give me clearance to remove the inlet bolts on the turbo. Then, I installed the inlet with the outlet pipe still off of the car. Once that was complete, I put the outlet pipe back on and the continued the installation of the CAI.
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
    Feb 02 2020
    Milwaukee, WI
    Now have my open-element 4" CTS Turbo air intake to Unitronic 4" turbo inlet pipe without issue. Just hoping the larger 4" pipe clears my front strut tower brace waiting to go on...
    Sep 12 2021
    Gold Coast Australia
    Quote Originally Posted by Vali View Post
    Did you ever get a response to your question so that you can deal with the heat soak. I have installed the same system and you are correct Heat soak is real. So whats the answer?
    Replace the intake?
    Junior Member One Ring iamthewolfman's Avatar
    Sep 14 2020
    2019 RS 3
    Westchester, NY
    4" Uni inlet with AWE 4.5" intake here. No fitment issues using the 4.5 to 4" silicone coupler
    Oct 31 2016
    Boston, MA
    To address the first post, I now have a 4” Eventuri Gen2 intake mated to a 4” Unitronic inlet. Had a shop do the install (along with a Unitronic intercooler) so can’t speak to the difficulty. I posted this in another thread as well, but basically they had trouble mating the two and so my car sat in the shop over a weekend until I could source a six inch long 4” inner diameter silicone coupler off Amazon. Once they had this it was easy to mate the two, as there is about a 3-4” gap between the inlet and intake once installed. Of note, I also have midpipes on the car.
    About 3-4 weeks afterwards I started noticing a subtle shudder on partial throttle only, right around 2,500 RPMS, and especially on incline, like the car was lugging or gears were slipping. More throttle and it goes away. It felt drivetrain related to me so I brought it to Audi to have them check it. They were able to replicate the issue and basically said it wasn’t the drivetrain (happened in comfort mode as well as dynamic, and also when rear axle was disengaged) and suggested it was my intake. It may be that the stock ECU is having trouble with that particular combo of airflow and load given the non-stock components, or Audi goofed and it is actually drivetrain related. I am not tuned yet but wanted to make sure the tranny and engine were okay given this new issue. I am not convinced its the intake that caused this issue, but just food for thought. I plan on tuning soon once my warranty expires, and will update this thread if the problem goes away.
