Hello, I have a 2014 Audi A5, I hit a large pothole recently and the Suspension System Fault! came on. Now it comes on every time I start the car. I also noticed it came on once when I went through a touchless car wash when it sprayed underneath. There is no problem with the headlights. I removed both front wheels and noticed on the drivers side there is a wire that has a hole rubbed in it that goes to the shock. Not sure if this is causing the code.
Is there a VAG com scanner that can reset this code and the service due code?
Is this the part - AUDI OEM 08-17 A5 Quattro Brake-Front-Sensor Harness Left 8K1972251E? I do not want to buy something I dont need.
Thanks,
Steve
