Results 1 to 17 of 17
Thread: TTS vs. TTRS
    Nov 04 2019
    San Francisco, California
    TTS vs. TTRS
    Inspired by my post on Stage 2 S3 vs. (Stock) RS3
    I currently drive a Stage 2 S3 but want to switch to a coupe, and am looking at TTRS and the TTS.
    Does the TTRS's larger turbo and larger engine mean that it takes longer to "come onto power" than the TTS? My s3 feels pretty snappy and even though I know the 5cyl's are waaaaay faster than the 4cycls past ~4k RPMs, I do love how peppy the 2.0T is under 4000.
    2015 Glacier White S3 Prestige, 034: Dogbone Mount & Inserts, Engine Mounts, Steel Brake Lines, P34 Intake, Downpipe, TCU, Stage 2 ECU; RS7 Sparkplugs and RS3 Coilpacks, Hawk HPS 5.0 Pads
    Senior Member Three Rings Spike Spiegel's Avatar
    Oct 27 2018
    On the Bebop, NH
    Quote Originally Posted by nikuhina View Post
    All things equal, a larger Turbo takes longer to spool than a smaller turbo due to it needing more exhaust air to turn their turbine and so they will make boost high up in the rpm range. "On the other hand smaller turbo has lower turbo lag because less exhaust gas is required to spin it so they will make boost even at lower rpms but at higher rpms it won't make enough boost so top end power won't be as much."
    The trade off on how wide a power band is for each car with their own turbo configurations. But typically the size of the Turbo isn't the only difference. Also have to account for diameter of tubing used, length of tubing used due to different circumstances (such as engine bay space and engine configuration, etc). All which effect air flow that is needed for the Turbo to spool in X amount of time. I'm certain others can provide a much more detailed explanation than I did or even add corrections. But that is my understanding.
    Best,
    Space Cowboy
    2019 Daytona Gray RS 3 | Instagram: SPCECB
    Aug 20 2019
    New York
    I know this is subjective, but all I can say is that my stock TTRS feels like a rocket. I put down my foot and it GOES, without delay.
    Keep in mind that the advertised 0-60 for the TTRS is 3.6 seconds...
    Feb 20 2014
    Port Orange, FL (Daytona Bch)
    The noise the TTRS makes is worth it. I had 2 TTS and now 2 TTRS....unless it's a financial issue, get the TTRS.
    Current: 2022 TTRS Turbo Blue, Xpel clear bra, H&R Sport Springs, ceramic coated.
    Past: 2019 TTRS Turbo Blue, 2018 TTRS Nardo Grey, 2015 Audi TT S Competition Package & 2011 Audi TT S, Black on Black
    Remember: Hit em with the Hein!
    Junior Member Two Rings
    Apr 11 2019
    Denver CO USA
    Quote Originally Posted by GaBoYnFla View Post
    This. There’s nothing like a 5-cylinder burble and bark. BRAAAAP.
    Oct 27 2018
    On the Bebop, NH
    I agree with this. Shopped an S3 and RS3. RS3/TTRS 5 cylinder is nearly worth the price alone for me.
    Best,
    Space Cowboy
    Best,
    Space Cowboy
    Jun 30 2020
    2018 TTS, 15 S1000r, 14 Z1000, 1990 ford festiva
    Southern Indiana
    I own a mk3 TTS and TTRS so this is simply my opinion.
    TTS comes on to power fast and with less throttle input.
    TTRS comes onto power about the same but it seems to take even more throttle.
    TTRS has bigger turbo but also a bigger motor toback it so they about equal out. The RS however has way more up top power.
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    I had an S3 loaner not too long ago Spike and was surprised that it seemed to accelerate more effortlessly around town than my TTS (same drive-select settings). It could however be a difference in gearing with the TTS favoring the top end. Your Stage-2 S3 must be a real treat to drive.
    So, I too would vote the TTRS for the unique sound of the 5 cylinder if nothing else (and if money is no relative object).
    Of course you'll lose back seating convenience, but gain liftback utility and ....
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Mar 17 2014
    20' TTRS / 20' Mini Cooper S
    Vancouver
    I came from a full bolt on stage 2 S3, I did everything possible to get the car sounding as good as I could (AWE Track with APR cast DP along with most of the engine bolt on's aside from a new intercooler)..
    The TTRS engine note alone (with just a mid pipe delete) has such a better tone, even though the S3 with AWE track with DP was much louder, the sounds are entirely different...
    The S3 stage 2 was much quicker in normal driving situations as it makes boost so early, The stock TTRS takes some time to spool up but when it does, the power is a glorious surge that sometimes requires two hands on the wheel...
    If finances are not an issue and your ready to move into something different, You wont regret it... Also, the cabin is simple but very nicely finished, the seats in the TTRS are worlds better than anything I have driven without having to spend 100,000+ lol
    DO IT lol
    May 03 2018
    11th gen Honda Accord Hybrid EX-L
    Jax, FL
    I recall making no real effort running a single passanger Golf R stage 2 apr against my stock RS3 (edit: with three passagers). We were neck and neck until we hit higher speeds, as the slight pull away started to occur.
    Now, if I drove it in manual mode, esp off and in the right RPM, outcome would have been slightly better.
    Now, Stage 2 S3 vs my stock TTRS would yield less results than the above. In my favor.
    TTRS, even in stock form, is much more violent in performance than a Golf R or S3. We have a half more litres than the 2.0, so lag is relieved a bit there. There is not even a close comparison, no less at higher speeds.
    My 19 TTRS is faster than my former weighted18 RS3. JS. IMHO.
    Jun 30 2020
    Southern Indiana
    TTS vs TTRS comes down to only 1 factor for me. Price. If its in the budget to go TTRS then by all means do it. It is so much more car and if you decided to mod it a little goes a long way. A modded TTS is only the start of an TTRS. I would buy TTRS again over another TTS all day.
    Jul 16 2013
    Ho
    TTRS if you can make it work for sure. I came from mk2 to mk3 tts then traded it in for mk3 ttrs when i found a good deal on used one. TTS pretty quick but the RS just a different beast specially the top end. It just keep pulling. Plus the sound of the 5cyl is amazing. RS also has a better DSG as well with 7spd DQ500.
    2018 TTRS (Nardo Gray)
    Previous:
    2018 TTS (Daytona Gray Pearl / Express Red)
    2008 TT MKII 2.0T DSG (Ocean Blue Pearl)
    Established Member Two Rings Kadab's Avatar
    May 04 2018
    2018 TT RS, 2013 WRX, 2017 Silverado, 2020 Sante Fe
    Huntsville, AL
    A TTRS is quicker and faster than any of the previously mentioned cars. The throttle mapping is not good though, because you really have to move the pedal to get much response. I think a device such as a Sprint Booster is needed that remaps the throttle with various settings. I installed one and made it much more aggressive and responsive. My TTRS is stage 2 and really is a beast.
    2018 Ara Blue TT RS // Unitronic Stg 2 E85 ECU, Stg 2 TCU // APR 4" Intake // APR FMIC // IE Downpipe
    ECE Dogbone // Front Subframe Locking Collar Kit // Sprint Booster // 350mm rear rotors // BFI engine mounts
    Jul 16 2013
    Ho
    Quote Originally Posted by Kadab View Post
    That was the case too when i had TTS .. must be Audi thing with they're dsg. Tempted to get something like the sprint booster since others have mentioned it for better response 👍
    Previous:
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    There is little to no lag in the TTRS, the larger engine gives it enough torque to deliver power until the turbo spools, it is NOTHING like the stock S3 (I had a 15 and the turbo lag was atrocious). On Stg 1 any lag that even the most anal person could find is gone.
    The TTRS is witchcraft, pure and simple.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Jul 12 2018
    UK
    Quote Originally Posted by Thumper3 View Post
    Glad I'm not the only one who thinks this - I have the 2.0 in my wife's Golf R so I get to compare all the time. I also have a 420hp RS2 with the 2.2T engine. It's so funny switching between them... high compression, DI, variable valve lift, modern turbo tech have us spoilt really.
    The RS2 is LAGGY. And that is improved over stock, as it has a ported head and modern compressor wheel to make 5-7psi for 1000rpm before it really kicked in. Old school turbo cars were flat off-boost with big injectors that didn't perform well at low IDC, low compression, and timing and valve lift biased to on-boost performance. Even in the power band there is a lag as the turbo spools up each time you lift (hence anti-lag when used in the Rally cars of the 80s). And it all comes in like a crescendo around 4k rpm.
    In comparison the Golf R/2.0T is instant! Feels a bit flat compared to the 2.5T but at 2500rpm then it just takes off. Kinda like the turbo diesels, making strong torque in the mid 2000s, but this one holds on as the rpms rise.
    TTRS, the power doesn't come in for another 500rpm I'd say, but it is not laggy. That extra displacement is noticeable when it's not on boost. Above 4k the turbo comes on song as quick as you can get your foot to the floor. What amazes me is that it does this with a turbo large enough to make 550hp on pump, with no additional fuel upgrades without the compromises.
    To the OP's point - both are a fantastic drive train - in my opinion lag is not an issue, you may find your driving style adjusts a little. Personal note - I also found the throttle mapping not to my liking, putting it in Linear mode with VCDS and I'm happy with it now. I do opt to take the Golf alot round town, but getting in the TT always feels a bit special, the 5cyl engine was and is worth the extra for me.
    Nov 03 2014
    BMW i3, Golf 1.4T, TT RS 8S
    Mexico
    Quote Originally Posted by Ross_T_Boss View Post
    Amazing write up and amazing cars! Would love a RS-2, that’s the first of the RS and all the Porsche bits and badging are something special.
    Could you be so kind and share some pictures of your RS-2?
