Results 1 to 21 of 21
    Mar 14 2019
    pittsburgh
    Tunes - How custom?
    So I have searched and looked over the various tune threads (i could have missed one) but I dont feel at this point I know the answer:
    Who does the most "custom" tunes for our cars? The only dyno tune option I know near me is CB Tuning and thats hours away. I didn't know if Uni or APR do exclusively off the shelf stages. Reason I ask is I finally got my avant back on the road: Autotech HPFP, S3 injectors, Treadstone FMIC, ARP top end hardware, R8 coils, one step colder plugs, catch can, cold air intake, rebuilt head, DV+, factory KO3 rebuilt (by Tim's Turbos w/ 360 and clipped wheel), 3in HFC and downpipe.
    I dont neatly fall into any "stage" but I assume I would be a stage 2+ if no custom option exists. Rebuilding the bottom end would be next and then probably K04, but I am not quite there yet.
    Thanks.
    2008 BT A4 S-Line 6MT 2.0 Quattro
    2008 A4 3.2 S-line Quattro
    2007 A4 Avant 2.0 Quattro
    2006 A4 2.0 Quattro
    2003 A6 3.0 Quattro
    Jun 17 2013
    jersey city nj
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    For a stage 2 car, custom would be a waste of time. Your turbo is your biggest limitation. I feel that any extra power custom tuning would bring wouldn’t be worth the effort because anything extra custom tuning would give would be way outside of the K03’s efficiency range. You’d basically just creating a bunch of hot, less efficient air.
    Who’s tune are you running now? You have a HPFP upgrade and S3 injectors so you must have something now right?
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Senior Member Three Rings Kylet21's Avatar
    Dec 19 2016
    2012 TT RS
    Milwaukee, WI
    +1 on United Motorsports. The standard off the shelf 2+ tune won’t account for the S3 injectors. UM can help you with that. I don’t have their tune, but I have heard nothing but positive things.
    Mar 14 2019
    pittsburgh
    Quote Originally Posted by EvolutionArmory View Post
    Thanks.
    To my knowledge its still stock. I have not had the ECM out but I have no reason to believe its anything else. I have only put 100 miles on the car since rebuild. The only thing I seem to notice is that my boost gauge says 13 when I thought they ran at 10.
    2006 A4 2.0 Quattro
    2003 A6 3.0 Quattro
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I think member Perry01 might have the answer for you. His K04 2.0T is custom tuned by Integrated Engineering and he's getting almost 350 awhp on the dyno and dipping into the 12's in the quarter in a Q5 SUV.
    https://www.audizine.com/forum/showt...light=2.0T+K04
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I second the idea that a custom tune really isnt necessary, and despite it being "custom" you might not have better results compared to an OTS flash.
    Do you have any airflow specs or compressor maps for the turbo?
    If you really feel the need for a one off tune, Eurodyne Maestro is a good option. That said, the tune will only be as good as the person behind the keyboard.
    2019 SQ5 Prestige
    Mar 14 2019
    pittsburgh
    Quote Originally Posted by texasboy21 View Post
    Not unreasonable statements.
    I do not have any numbers presently, but only because I am not great with my Ross Tech yet. I finally paid for more VIN last week so I have only played with my halogen to xenon so far. Should you tell me where to look I will share said numbers.
    2006 A4 2.0 Quattro
    2003 A6 3.0 Quattro
    Jun 27 2011
    Quote Originally Posted by MSq5 View Post
    IE doesn't have a k04 tune for the b7s though. B8s yes, but not B7s.
    I'd also throw my vote in for United Motorsports. Might want to give them a call and see if they can do something semi-custom for your turbo setup.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Motoza
    Sent from my LM-G710VM using Audizine mobile app
    Dec 19 2016
    2012 TT RS
    Milwaukee, WI
    Apparently several of the major tuners will do custom tunes. Not sure how you qualify or what the stipulations are, but APR even does custom tunes. As with any custom tune, expect a significant amount of data logging and back and forth. But seriously I would give United Motorsports a call and just ask them what they think is the best route. They will likely be able to give better advice than any of us on here.
    Jun 27 2011
    APR will never do a custom tune on a B7. Maybe on brand new platforms (since that’s where the money is and it helps pay for their R&D) but if you called APR about a custom tune for a hybrid k03 turbo they’d laugh then hang up.
    -CP
    2017 Q7 3.0t
    Dec 19 2016
    2012 TT RS
    Milwaukee, WI
    They did just do a custom tune on a B7. Granted it was an RS4 with some very custom turbo work. See EricZ build thread.
    Mar 14 2019
    pittsburgh
    Quote Originally Posted by Kylet21 View Post
    Somehow I neglected to put this in the initial post, but the car is an automatic and Fred at UM informed me they dont touch autos. So unfortunately UM is now out.
    2006 A4 2.0 Quattro
    2003 A6 3.0 Quattro
    Jun 27 2011
    Tunes - How custom?
    APR tuned that? Are you sure? I’ve been following the thread but don’t recall reading that.
    I just don’t think you’re going to get anything but a no from them unless you happen to be a BorgWarner engineer doing some experimental e-turbo tuning. Not a stock-ish b7 2.0t with a clipped k03.
    Though I’m sure if you write enough zeroes on a check they’d be happy to oblige. I just don’t see APR giving two shits to engage their tuners for a custom tune for a barely-above-stock 2.0t. Not like there is a market for that or any r&d value there.
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    have you thought about just going K04? you have all the supporting mods, maybe just a RS4 PRV. More doors might open up. I run the GiAC tune and enjoy it. But if i were to do it again or just for fun i would go with someone like UM. I heard whispers Malone tuning around here too. they have a 2.5 stg tune.
    https://tunezilla.com/catalog/Audi/2...Stage-2.5/4201
    May 20 2017
    New Hampshire
    Quote Originally Posted by apatchin View Post
    GIAC tunes are no joke. My K04 tune is probably one of the most aggressive off the shelf K04 tunes in the B7 section judging from my logs VS everyone else so far. People don’t talk about GIAC anymore with all of these other options but GIAC has been here the whole time making great tunes.
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Find a WinOLS tuning wizard and you can go as custom as needed, I've already helped log and tune a k04/Frankenturbo 1.8T and 2.0T to some real nice power levels.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    May 28 2008
    PDX/DEN
    Agreed. I know we have both had great success with GIAC, and doesnt seem to get enough credit. have both of their tunes K03 & K04 on the B7, as well on my B5 S4 & B8.5 SQ. My Shop swears by them and have never looked at any other tuner.
    Apr 01 2007
    houston texas
    Doesnt GIAC white label their tuning?
    2019 SQ5 Prestige
    May 20 2017
    New Hampshire
    Meaning they write tunes for lesser tuners? Yes if that’s what you mean by white label.
