Results 1 to 6 of 6
    May 16 2019
    Mississippi
    Water pump union
    Replaced water pump 6-8 months ago. I am having sporadic leaks that started shortly afterwards. Several times it has leaked out of the pump/oil cooler union. Going to replace union with the aluminum one from ECS. Any idea why it would leak on occasion and not all the time? Any thing to watch out for when I pull water pump and replace this time?
    Planning on just pulling the throttle body and not the entire intake as we did on pump replacement. Have read here where that will work, true?
    Jul 16 2018
    Atlanta
    Only thing the repair manual mentions is the two o-rings should be replaced and the two o-rings should be coated in coolant before installation.
    Install the connection piece into the oil cooler, then push the coolant pump onto the connection piece and then onto the centering pins on the block.
    The o-rings are https://parts.audiusa.com/p/48775800/WHT002001.html, and the connection piece (which includes the o-rings) is https://parts.audiusa.com/p/48001637/06H121131C.html
    Veteran Member Four Rings Traptalk's Avatar
    Oct 14 2018
    Buffalo, NY
    I didn’t know ecs made a metal union, but I’ve never had problems with mine so I wouldn’t of been looking for one
    ig: @wastegate_warriors
    i like meth
    Feb 15 2016
    Cambridge,Ontario
    I coated mine with syl glide and the union slipped right in while seating pump. Point is they need to slip in. If part of the o ring " rolls" you will develop a leak.
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    May 16 2019
    Mississippi
    We did it last evening. Let intake on, just removed throttle body. Worked fine.
    Veteran Member Three Rings whats77inaname's Avatar
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    Or tears....which was my situation *lol*.
