Originally Posted by
Gunnarrrrr
I always find it easier to remove the manifold, and just hook the turbo onto an engine hoist to pull it up a couple inches.
I'd recommend replacing those 3 nuts with some smaller 14mm nuts instead of the stock 16mm. I got a pack of them on amazon for $8. they're still M10x1.5, just thinner, easier to get a socket in there next time.
This is pretty much what you're going to have to do if you want to leave the turbo in place though.
I feel like removing the whole manifold just to get that that one nut is getting a bit too far into the weeds lol. I do agree with the smaller nuts though, They're even more of a help with high flow cast manifolds where some of the 12mm nuts are almost impossible to get a socket on where the 10mm ones are a breeze.
There is a good inch of room between the bottom stud and the exhaust heat shield so I feel like the simplest way would be to use a crows foot wrench and a wobble extension (~12") to get your wrench/ breaker bar under the cat, and just reach down through the engine bay to twist it off. It may be a bit tough to turn if it's never been off before but I'm pretty sure that how I did it and mine wasn't hard to get off. I definitely didn't have to go under the car, and I understand not everyone's car is the same but mine being in the rust belt should be on the worse end of stuck and perished bolts/nuts.
