Results 1 to 17 of 17
    Junior Member Two Rings SauerkrautPower's Avatar
    Aug 20 2020
    SoCalTouge
    Question 01E 6 Speed Transmission Fluid and Diff Change
    https://www.youtube.com/watch?v=6fBcVz1El9Y
    I watched this tutorial on how to change the transmission, center diff, and rear diff fluids.
    The guy skipped the part where you fill the center diff so my question is where is the fill plug on the center diff?
    Or does the fill hole on the transmission also fill the center diff?
    Ive done my research on what fluid to use and the safest, from what I've read is OEM. Any thoughts on what fluid to use?
    Is the viscosity level on the transmission, center diff, and rear diff all the same?
    Thank you for your guys input.
    PLEASE YIELD TO SEMI TRUCK DRIVERS!
    2001 Stage 3 SRM B5 S4 - sold
    2005 B6 A4 USP Avant - sold
    2010 B8 S4 Stage 2 - sold
    2005 B6 A4 USP Avant K04 - sold
    2012 B8 S4 Manual - sold
    2006 B7 A4 Avant Manual - sold engine blew up
    2010 Mercedes-Benz GLK 350 4matic - current daily
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Front diff, gearbox and center diff have all same oil. Center diff doesn't have a fill hole. Just drain all and refiil and you are done.
    Apr 07 2011
    Home of the mighty beaver
    rear diff is not the same fluid as the trans/center at least I dont recall it being the same.
    man i just realized its been ten years since i changed the rear diff oil... lol. put maybe 20k on it so no big deal... Have to remember to change that soon.
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    OE fluid is fine---Audi recommendation - Both trans and rear diff---
    SAE 75W-90 PN G00 500 0 GL5 Synthetic
    IMHO a better gear oil is what was mentioned in Justin's video----
    FUCHS TITAN SINTOFLUID SAE 75W-80(synthetic) GL5 Fluid
    * TRANNY and Center Differential
    (2) Drain Plug- tranny and diff
    (1) Fill Plug-Drivers Side
    10mm HEX, 40 N-M, 2.9L capacity
    As others mentioned- there is no separate fill for the center diff---the oil will flow into the center diff. That's one of the reasons the vehicle needs to be level when filling.
    * Rear Differential
    (1) Drain Plug and Fill Plug- Pass Side
    same tool, 1.9L capacity + 50grams of MoS2 (LIQUI MOLY p/n 2019)
    The LIQUI MOLY can be found at Amazon--DONOT add this to the tranny.
    Apr 07 2011
    meh, i put 200ml of MoS2 in my trans a couple years back. No issues and it helped with shifting.
    Aug 20 2020
    SoCalTouge
    Quote Originally Posted by LJS View Post
    * Rear Differential
    THANK YOU FOR CLARIFYING! I will be getting this done asap. Shops want to charge over $800 for labor. Seems like a pretty simple job.
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Quote Originally Posted by SauerkrautPower View Post
    That is Very high.
    Remember, always loosen the fill plug before the drain plug.... if you cannot get the fill plug out, you’ll never get the fluid in.
    It’s a really simple job and it takes longer to lift the whole car up level than to change the fluids :)
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    Corona, SOCAL
    The guy??? Anyways... fill center diff from front trans fill hole. As other have said, remove fill plugs first. Don’t rush the job, take your time. You can use the same fluid front and rear.....unless you are running LSD or something to that nature.
    Veteran Member Three Rings Protection's Avatar
    Feb 24 2011
    Alfa Romeo Giulia Quadrifoglio, MK7 Golf R, B5 S4, B6 A4, B7 RS4
    Long Island NY
    Quote Originally Posted by jballou View Post
    The guy??? ....
    Established Member Two Rings jonmon67's Avatar
    May 13 2018
    Stage 3 B5 S4 K04 - Stage 3 B5 S4 F21 - E60 528xi- B5 A4
    Connecticut
    Ordered my fluids from ECS tuning a few days ago, gonna run fuchs titan sintofluid 75-90 gl4 in the trans and center diff, ordered 3L and gonna just fill to top, I believe it takes 2.7-2.9L.Also gonna run motul gear300 75-90 gl5 in the rear diff, I believe it takes 1.8L.
    Aug 20 2020
    SoCalTouge
    Well I guess referring to the person who made the youtube video as "the guy" can be inaccurate specially during the times that we live in now.
    Feb 24 2011
    Long Island NY
    He could be a tree for all I care. Or might disguise as a male but want to be labeled as female.
    LOL a tranny working on a tranny...
    It’s not PC thing. “The Guy” in the video is jballou aka Justin Ballou the commenter above. You can thank him for his useful videos and commentary. I know I have found his videos to be extremely helpful. Thanks, Justin.
    Aug 20 2020
    SoCalTouge
    Quote Originally Posted by Protection View Post
    Yes his video saved me labor rates for sure. Thank you jballou!
    Apr 07 2011
    I identify as 1 quart of fuchs titan sintofluid.
    Mar 19 2005
    Corona, SOCAL
    Quote Originally Posted by S4James View Post
    . Haha... which hand do you wipe with?
    Veteran Member Three Rings harryn's Avatar
    Dec 03 2016
    2021 Audi A4, 2000 Audi S4, 1995 BMW M3
    Oh hey Justin!! Love your videos! By the way, have you ever done a video where you replace the rear guide rods on your B5? Or remove a seized brake line in the rear? 🙂👍
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Ha, that shit was funny.
    Justin you need to tell him
    your pronouns.
