Well Teknika is special I think he is testing their 800 blend there before it hits the market lol. I haven't gotten anything official as of yet for times, just a draggy run, but for some reason my gps signal isn't great so I lose it often. I did a 170+ run and it was showing me in the quarter at 124ish which is higher than I should be for my power level in the current Arizona temps. So until the tracks open here in September I won't have much solid info. Per Draggy the 0-60 is around 3.2, unfortunately I had to launch on gravel there so it's definitely not a clean launch. As for temps with the ABT intercooler and pump I posted some here a while ago in the radiator thread. They definitely aren't ideal as of right now AZ has not seen a day under 110 and 114-117 has been the solid temps during the day with high 90's low 100's at night. Ultimately cooling wise how far you take it is going to depend on what your use is. Teknika definitely tracks his ride, in that case I would go with the biggest heat exchangers and as much extra fluid in the system I could muster since you only hit high speeds to cool things down quickly in straight and long sweepers. In temperatures like Arizona that we have been experiencing, I will probably opt to get into the Merc Racing stock intercooler replacement unit as well. But if you aren't going to a track and are just daily driving and drag racing once in a while the ABT system would also be acceptable. But again, I don't think you will lose with any of the options. The stock system is just barely up to the task, if you are looking at going further you will need to address that first. Then octane to pump up the boost regardless if you are going replacement turbos or not. The engine is stout but it needs good fuel and good cooling to shine.
Here is the pull with the gravel launch and dragy talking to me.
https://youtu.be/zHuX4HnD5pE
This information was from back in May during the day when it was still below 110..smh.
Ambient Air Temp Reading from Google - 109 F
Vehicle Dash Temp - 112 F
OBDEleven Vehicle Monitored Ambient Air Temp - 48 C (118.4 F)
I drove the car till warm, very easy in AZ. I then conducted 10 pulls 60MPH-120MPH
All of the pulls were roughly the same
65-70 MPH - 61-63 C (145.4F)
85-90 MPH - 57-59 C (136.4F)
70-125 - 70-75 C (167F)
Idle in traffic temps - 68-69 C (154.4) *Expected due to no air flow running through the heat exchangers*
This is obviously not the most scientific observation as I have to go by live monitoring on the OBDEleven but it gives you a general idea of where you would be at if you were running in my god awful conditions. I won't be pushing it again in the same temps as this was a semi-torture test and it's only going to get hotter as we are expected a nice 117 day coming up on the weekend and I don't want to test the limits of heat and my octane limits.
With that said, this is where I go to the seat of the pants gauge and go by opinion. Stock on a hot day like this I could feel the car struggle, this is also due to Arizona only having 91 at the pump so it is two fold, but when temps get high here power sharply decreases on every vehicle I have ever owned. With the current tune it is solid also because I am running 100 Octane blended with 91 to even out at 95, but the power does not seem affected at all by the heat. After the runs coolant temps were stable at 224 F at 65MPH and IAT's quickly returned to the 61-63C range. I also don't have meth injection, so for those of you thinking of using meth this would further bring temps down.
Ultimately, I think this falls under the category of choose which system you want, as long as they are inline and increasing the stock system capacity you will have positive results. Honestly for the temps that we have out here in AZ, I think any of the upgrades are pretty mandatory for this car in hot dry climate.
Originally Posted by
PI5
Thanks for the info joeyoro. Have you timed any runs with your setup? 0-60, 1/4mi etc? I like that induction noise. I used to own 300zx's so was always keen on that turbo spool noise.
Looking at the Pure Turbos website, I can see 700 series, but not 800 series.
So how are your temps with the additional intercooler and water pump?
