Originally Posted by
OhDavy1
Can you log with unitronic and have them make adjustments?
I don’t know if Unitronic will custom tune, but you can’t log with their cable. The software feature is there but it’s disabled and says it’s in development.
If you compare IE to Unitronic hp/tq numbers, pay attention to IE’s stock numbers. For some reason, they overstate the stock numbers which pushes their tune numbers higher. If you adjust for these higher stock values, you’ll see that both pretty much make the same power and torque. IE low toque is Uni stage 1 and IE high torque is Uni 1+.
Nice thing about IE is they give you more options and files, eg lower octane levels and various launch points. With Unitronic you pretty much get one file per stage and stock files. I believe stage 2 gives you an option for crackle tune, in addition to normal file. If you buy Uni, get their stage 2 right away even if you won’t get there right away. It’ll save you about $100 in upgrades later.
As for DP cat location, I don’t think it makes much difference in terms of performance if at all. It’ll probably have some impact on the sound and how soon cat heats up and start working. Some of the best DPs on the market use stock cat location, besides Unitronic and IE, AWE, Milltek, 034, COBB all use stock locations.
