my big turbo on a top mount manifold was fine for a month or so, then i noticed the studs that hold the turbo to the manifold (4 10mm studs) snapped off and caused a massive exhaust leak. so i removed the turbo and went to pull the manifold off the head and noticed the studs that bolt the manifold to the cylinder head were snapping apart with almost no torque to remove the nuts.
since then i've purchased a new manifold, 4 inconel studs for the turbo to mani, but i cannot find any studs that bolt the mani to cyl head that are inconel or any stronger materials. only OEM options pop up.
does anyone know what i can use? arp does not seem to make any for this car, and google searches come up with just oem and OE stud kits.
also, i'd really like to add some sort of turbo brace or support to help keep all the weight from the trubo off the studs so they dont snap from the stress/weight/heat cycles etc.
anyone make any brackets or braces for top mount BT setups for 1.8T? or is this something that has to be fabricated by a welding shop or something?
searching online for turbo braces and supports only show heim joint bars that people ghetto rig to their valve cover which is made of weak aluminum. i cannot see that being a very good option as it would likely destroy the valve cover at some point.
any help would be appreciated greatly!! thanks!
